Old 12-03-2008, 03:00 PM   #1501
I cant chanche the timing on my motor so when i will drive sensordonly will it than also be 100%timed?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 12-03-2008, 03:18 PM   #1502
Regional Moderator
CarbonJoe's Avatar
No, sensored only uses the timing set by the motor. But, you should still set the timing advance to 100% so that if the sensor wire breaks, the ESC will still be able to run the motor to the best of it's ability.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-03-2008, 05:37 PM   #1503
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
What Joe said!
If you're running in sensored only we go off motor timing plus some timing inside which is about 15 degrees. The new boost software adds on top of that.
If you're looking for a reason to have a Hotwire you've now been given one.
Just in time for Xmas, makes a great stocking stuffer!
TT1450
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-03-2008, 05:44 PM   #1504
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
When is the newest version of Hot Wire due out? Will there be a custom throttle curve section, like the Mamba systems have?
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 12-03-2008, 05:57 PM   #1505
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default tekin
Randy uhpm
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 12-04-2008, 12:42 AM   #1506
DriftDreamer06's Avatar
i am very much interested in the rs pro. i have both novak and lrp esc and a range of motors. my question is about the hotwire - i run a b1 in 1/18 scale and fx pro in 1/10 buggy offroad and i am looking to the rs pro for 1/12 and trans am - but does the same hotwire work for all 3(b1, fx pro, rs pro)? and software?
and for 1/12 scale stock(17.5 or 27t) what motors do you guys like best?
and for 1/12 scale ss(13.5 or 19t) what motors do you guys like best?
i look forward to your responses.
Racin'4-Fun
DriftDreamer06 is offline   Reply With Quote
Old 12-04-2008, 01:32 AM   #1507
The Hotwire is compatible with all the speed controls you mentioned, B series, R1 series RS series as well as the brushed FX series.
You WILL be very happy if you tried the Tekin line of motors for sure. 17.5, 13.5, 10.5 etc....
jeffb is offline   Reply With Quote
Old 12-04-2008, 04:45 AM   #1508
Originally Posted by Randy_Pike View Post
What Joe said!
TT1450
Ok but the 10,5 lrp ss will than not be timed for 100%.
Or does the boost tacke care for the rest?
I have the hotwire
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 12-04-2008, 07:20 AM   #1509
mangoman's Avatar
Racin'4-Fun
Just so you know if you want to save some dollars.... you really only need the pro version for on-road modified touring.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-04-2008, 10:10 AM   #1510
Hello, I've just setup my TB Evo 5 MS with the RS Pro and Redline sensored 10.5 but my throttle channel needs to be reversed to run right.
I've checked my connections and polarity, and am out of ideas. Help will be much appreciated! Many thanks.
- Joel
chinjmes is offline   Reply With Quote
Old 12-04-2008, 10:16 AM   #1511
- Joel
not going to lie to you... does this really matter? i fail to see why that would be a problem, thats the reason behind channel reverse.
any idea when the new firmware will be out, a real upgrade in my opinion, seen the cars at the champs with it
i would even run the beta version!
mxzhonkey is offline   Reply With Quote
Old 12-04-2008, 10:18 AM   #1512
Regional Moderator
CarbonJoe's Avatar
- Joel
Not sure what you're asking? Are you indicating that you shouldn't have to reverse the throttle servo setting? Some radios (Futaba I believe) need to have the throttle servo direction reversed in order to work correctly. Sounds like normal operation to me.
Old 12-04-2008, 10:23 AM   #1513
Meaning that when I setup the ESC as per instructions and have the throttle channel setting on normal (Futaba 3PK), trigger forward gives me full throttle and trigger backwards gives me full brake.
Yes it matters dammit I'm anal. Kidding. Didn't have to do that for my brushed setup and since it's my first brushless I thought it best to make sure I wasn't doing anything wrong.
Thanks!
Old 12-04-2008, 10:30 AM   #1514
Adam?'s Avatar
I have the throttle reversed on my 3PK too.
Is it normal for a 13.5 to scream like a 3.5 (on the bench) with the new software? It'll be interesting to see how it does on the track.
Adam? is offline   Reply With Quote
Old 12-04-2008, 10:31 AM   #1515
davepull's Avatar
your fine for some reason with futaba we need to reverse the throttle channel.
davepull is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
