Old 06-13-2010, 08:16 PM   #15091
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
It does not run on the Mac OS, however if you have an Intel mac there are a number of ways to run it. 1) Install Windows XP, Vista or 7 using bootcamp and boot into Windows. 2) Purchase Parallels or VM Ware Fusion and do number 1 but run both OS's simultaneously 3) Purchase Parallels or VM Ware Fusion and install Windows as a virtual machine and again run both OS's simultaneously. Your choice, but I do believe Windows is needed. I have not tried the Windowsless emulators with the Hotwire.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 06-13-2010, 08:30 PM   #15092
To add to option #2, you can use Virtual Box: http://www.virtualbox.org/
It's free and is what I use... works great.
g26er is offline   Reply With Quote
Old 06-13-2010, 09:02 PM   #15093
Still Bill's Avatar
Originally Posted by immrwright7 View Post
Has anybody ran the Tekin ESC at NorCal Hobbies? Any good setups I can borrow? Thanks in advance.
Randy. None of those team drivers typically run 17.5 setups. With so few posts, I have to think that Mr. Wright is probably new to the hobby.
Mr. Wright. What motor do you want a setup for? And what class will you be running? Assuming that you are talking about Tekin setups for the upcoming Asphalt Nats.
Otherwise, we are all waiting for the new 2.08 Tekin software which will require some testing before we have input on new Tekin ESC setups with the different motors.
Bill...A NorCal regular
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 06-13-2010, 10:10 PM   #15094
STLNLST's Avatar
Trader Rating: 21 (100%+)
Actually Derek and I have run a lot of 17.5 and we have some good set up's. We all run Mo's set up. I plan on being out there this weekend to help guys out if I can jiggle my work days since Norcal switched to the 19th. I'll be running 17.5 at the nats.
STLNLST is offline   Reply With Quote
Old 06-13-2010, 10:20 PM   #15095
Still Bill's Avatar
AHHHH...FEELING WIMPY ARE WE!
Old 06-13-2010, 11:25 PM   #15096
Clint161's Avatar
Where can I find Mo's setup? I don't see it on Tekin's site.
Clint161 is offline   Reply With Quote
Old 06-13-2010, 11:40 PM   #15097
STLNLST's Avatar
Yes I am..... Actually have a pretty good reason. You will laugh when I tell you.
end rpm - 10,000 (this number can go up depending on feel)
start rpm - 4XXX
timing boost- 50
turbo- 10-15
throtle profile- 3 (5 if you want it agressive)
drag brake- 20-25
brakes- 85
turbo delay- .2-.3
turbo ramp- 2
Motor timing- 0 on the can
FDR- 6.2
17.5 motor
Need anything else you know where to find us
Old 06-14-2010, 01:23 AM   #15098
Originally Posted by Senna Racing View Post
Randy Heading out to do some testing on this large nitro track
Any suggest for 10.5 novak ss or tekin redline
http://www.youtube.com/watch?v=K1HLXfuvfL4&feature=fvw
Thanks Wayne
I run a Tekin 13.5 on a large 1/5th scale track and i use these settings
End 10,xxx to 12,xxx
start 6,xxx
turbo 14
boost max
turbo delay OFF
gearing of 6.6(70m straight)
throttle profile 5
push control off
brag brake off
motor timing of 8
my motor temps after 7 mins are around the 70 to 80 degrees C and i have loads of power/straight line speed
sidecarphil1 is offline   Reply With Quote
Old 06-14-2010, 07:27 AM   #15099
M-Technic's Avatar
Trader Rating: 15 (100%+)
Has anybody found the Throttle Profile to have any effect on the motor temperature?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 06-14-2010, 07:50 AM   #15100
tc3team's Avatar
You shouldnt have (i've not noticed it myself), but that's not to say it might be possible. Maybe if your gearing was on the edge of being in a comfortable zone it might have an impact but that's only a guess.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 06-14-2010, 08:39 AM   #15101
STLNLST's Avatar
That's something I might play around with this weekend but temp has never been an issue to me running 17.5 or 13.5(R.I.P.) The only temp test I really felt help was running the LRP heat sink/fan combo. My motors always ran 20 degrees cooler using it. The bad thing is that it adds a ton of weith to the cars motor side which is already heavy
Old 06-14-2010, 09:24 AM   #15102
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The Tp setting could make it run hotter if you drive it hard. It's not much though.
The new software is around the corner. If you're looking to test the spec software for now run 183, it's pretty dang close to the spec software.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-14-2010, 09:39 AM   #15103
Is the new software just for spec racing ?? I hope not as I thought it was an upgade for the poor brakes as well. I race 10.5 and need all the timing boost plus I hope new brake software .
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 06-14-2010, 09:44 AM   #15104
jrxs-r's Avatar
+1
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 06-14-2010, 12:15 PM   #15105
Rob long is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
