Old 06-09-2010, 08:20 PM   #15061
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
click the advance button and you will see the end rpm
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-09-2010, 11:03 PM   #15062
^^I see that but how do I adjust it?
immrwright7 is offline   Reply With Quote
Old 06-09-2010, 11:48 PM   #15063
Skitee's Avatar
Start by inserting your end rpm value, then hit the calculate button, after that select your start rpm value from the available start rpm values which were calculated by the software.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 06-10-2010, 02:33 AM   #15064
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by syndr0me View Post
So this 208 firmware, or whatever it is that has the stock spec profile, will that same firmware be able to do the timing advance stuff, or will the ESC need to be flashed with a different version? If the firmware can support both, what will it take to move between spec mode and open mode? I'm trying to get a feel for what kind of process will be required to try and run a spec and non-spec 17.5 class at the same race.
It is simply a setting within Version 208, when zero timing/boost is set there is an LED sequence indicating this setting at Neutral. So if you are running another class you can connect to the hotwire and readjust the settings and be ready to go. Then repeat for the Stock SPEC class etc....
rocketron is offline   Reply With Quote
Old 06-10-2010, 03:07 AM   #15065
Originally Posted by minifo View Post
Hi all,
Need some help about where to start on the Tekin RS settings. Going to run a LRP X11 9.5T stock spec motor in an xray t2 009 running rubber tires. Mostly asphalt small and medium sice track racing. Anyone got a good pointer where to start?
Would any of the asphalt setups from team tekin be usable as a starting point? They are mostly 13.5t and this being a 9.5t.
minifo is offline   Reply With Quote
Old 06-10-2010, 04:48 AM   #15066
This is my setting with a 8.5R in a small/med asphalt track for TC:
FDR ~ 8.5 to 8.8
Sensored mode
Boost = 40
Turbo = 0
Delay = 0
End RPM = 20000
Start RPM = 5xxx
Ramp = 2
motor temp ~ 65C
I didnt set turbo since the straight for this local track is very short. This setup can keep up with 5.5R without turbo.
hardmankam is offline   Reply With Quote
Old 06-10-2010, 04:49 AM   #15067
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Originally Posted by ShaunMac View Post
Tell that to ALL the guys in 13.5 Rubber at the Snowbirds where Schreff laid it down on a less than 100ft track using lots of turbo!!! Yes, even in 13.5 on a small track you can use turbo to your advantage as long as care is given to gearing, RPM and delay settings.
And believe me, his wasn't the only turbo equipped RS setup out there.
i actually agree to both comments..
you CAN run turbo on a track with a < 100ft straight (i'm using it on a 70-75ft straight)..
however, without turbo and diff gear ratio i am no slower and hence could say turbo was a waste.
on the small tracks, i think the only benefit with boosto is being able to run the motor cooler
-Mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 06-10-2010, 05:29 AM   #15068
20 SMOKE's Avatar
with 0 delay your using turbo first as everyone knows but you are wasting the timing boost as it is probable not all being used but with out a data logger know one knows
Jamie W
Old 06-10-2010, 06:36 PM   #15069
Originally Posted by Randy_Pike View Post
NO, you should not run max turbo, max timing boost,etc.
There are a lot of good team driver setups to be found here:
http://www.teamtekin.com/hotwire/ESCsetups/index.html
Randy,
i actually did use max timing and max boost two weeks agoo for a race in Rucphen; http://www.youtube.com/watch?v=DRBQnRHLBLQ
this however is a little nitro movie but does give a indication about the track.
motor became 80 degree C after a 7 min heat, so pretty nice! without this maxed boost and turbo i coudn't get to a proper speed with the LRP 10.5.
i did ofcourse start with a lower value to look at the temps but they never exceeded the 85C... so i think it is possible!
Mark
Markiempje is offline   Reply With Quote
Old 06-10-2010, 07:01 PM   #15070
yodace's Avatar
R/C Tech Charter Subscriber
Is Version 2.08 out yet?
yodace is offline   Reply With Quote
Old 06-10-2010, 07:50 PM   #15071
Default NO CAP?
Hey everyone. I just bought a used Rs-pro. I noticed it did not have a Power Capacitor on it. The instructions say that one must be used. Should I be worried?
wisc-ace is offline   Reply With Quote
Old 06-10-2010, 07:56 PM   #15072
This server is okay I think.
http://softwareoutsourcing.biz
Beankyu is offline   Reply With Quote
Old 06-10-2010, 09:20 PM   #15073
Senna Racing's Avatar
Originally Posted by Markiempje View Post
Randy,
Mark
Nominally the car will bog down with full timing and turbo cause it is to much timing at once
No dont run with out the cap
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 06-10-2010, 09:44 PM   #15074
xray09ACT's Avatar
Randy,
Mark
I generally like running max turbo now. i then use a lower turbo boost value and check the temps.
Found that it give more punch when at 1005 throttle. however remember this does depend on track layout.
Too much timing will make the motor bog down and sometimes even cog at low rpms.
The same principle apply from when randy first introduced this all to us:
1st motor end can timing. low speed
2nd timing boost. mid range
3rd turbo. top speed
start and end rpm determine where the mid range is applied
ramp rate dictates how quickly the mid range timing is applied: smoothness i would say.
Delay determines when the turbo timing is applied: again track size dependant, however i do like to run 0.0, but bare in mind that this only comes on when your finger hits 100% throttle, also depends on your gearing, generally gear for the midfeild which sometimes means that if you have a long straight the motor will mbe at max rpm for longer so watch those temps. increasing the delay generally reduces the temps due to the motor not being at 100% rpm for a shorter period.
NB: this works for me, no i'm not a grand master, i haven't won anything worth writing about (yet) so take it with a grain of salt if you wish.
xray09ACT is offline   Reply With Quote
Old 06-11-2010, 02:02 AM   #15075
MRJRacing's Avatar
I have posted this question on the Tekin forum with no reply,will try it out here,
can anyone tell me who the Australian dealer for Tekin is??
cheers
Michael
MRJRacing.com.au - XRAY - CRC - Serpent - Team Associated - Jaco - Sorex - Protoform
Maitland Offroad/Onroad RC Car Club -www.morcc.com.au
www.hobbyexpress.com.au-www.walterrchobby.com.au
www.flyingfoxrc.com-www.acehobbyaustralia.com.au
MRJRacing is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
