Old 06-09-2010, 04:31 AM   #15046
nerdling's Avatar
Originally Posted by nerdling View Post
Hi guys,
how should I set up the RS Pro for Modified (4.5) on a medium to high grip flowing carpet track?
any one?
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 06-09-2010, 04:36 AM   #15047
any one?
try dual mode with a little bit of timing advance (40-50) to start with
CPD Racing
chris_dono is offline   Reply With Quote
Old 06-09-2010, 05:13 AM   #15048
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by cyanyde View Post
Need it for this weekends club race as that is the regulation software with zero timing indication through the leds.
nothing is released yet,go back to 183
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-09-2010, 05:54 AM   #15049
Senna Racing's Avatar
Hi guys,
Mark
I havent tried it but i read some pages back
start with timing boost of 10 check temps After 2mins
then you can add a little more if temps are ok after 5
and final introduce turbo if required angain go slow and temp ever few mins
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 06-09-2010, 06:21 AM   #15050
any one?
there is a sample setting for 4.5R on the team tekin website:
http://www.teamtekin.com/hotwire/ESCsetups/index.html
hardmankam is offline   Reply With Quote
Old 06-09-2010, 02:09 PM   #15051
msxmre's Avatar
I ran Moberly's set up with a 4.5 and it worked flawlessly. I ran it on a large track and all i did differently was run a small fan at the back of my speedo to cool the solder posts down. After 5 min run the motor temp was 74 deg.
Scotty
Oh and the car flew by the way, scary quick on the straight.
Tamiya TRF 201, TRF 416,TEKIN RS PRO (the dogs) Novak Ballistic, LRP X12 Motors, Orion Motors and LIPO (they say it's the future mmmmm) www.falkirkrcc.co.uk/forums
msxmre is offline   Reply With Quote
Old 06-09-2010, 02:13 PM   #15052
syndr0me's Avatar
Trader Rating: 32 (100%+)
So this 208 firmware, or whatever it is that has the stock spec profile, will that same firmware be able to do the timing advance stuff, or will the ESC need to be flashed with a different version? If the firmware can support both, what will it take to move between spec mode and open mode? I'm trying to get a feel for what kind of process will be required to try and run a spec and non-spec 17.5 class at the same race.
syndr0me is offline   Reply With Quote
Old 06-09-2010, 02:45 PM   #15053
20 SMOKE's Avatar
the throttle profile are going away and being replace with what ever is needed to be used for the spec class,so i would say led 1 id for spec and another led # being the standard esc setting.get the idea
Jamie W
Old 06-09-2010, 02:51 PM   #15054
M-Technic's Avatar
Trader Rating: 15 (100%+)
Jamie, pit by me at KRaceway this weekend, I need you to make my car fast despite the raging heat we will be battling.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 06-09-2010, 04:33 PM   #15055
20 SMOKE's Avatar
you have to pit next to me,cause i will be in a 32ft 5th wheel
Jamie W
Old 06-09-2010, 04:50 PM   #15056
nerdling's Avatar
thanks guys.
Old 06-09-2010, 06:51 PM   #15057
Ran my Tekin 13.5 system and it was great at NorCal today! Is it ok to run the esc and motor at max turbo? If not where is a good place to have the turbo timing, and ramp?
immrwright7 is offline   Reply With Quote
Old 06-09-2010, 07:05 PM   #15058
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
NO, you should not run max turbo, max timing boost,etc.
There are a lot of good team driver setups to be found here:
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-09-2010, 07:17 PM   #15059
thanks randy! I'll make some quick changes to save my motor and esc!
Old 06-09-2010, 07:54 PM   #15060
Another question how do you adjust the RPM's on the hotwire?
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
