Old 06-07-2010, 10:59 PM   #15031
Originally Posted by ShaunMac View Post
Tell that to ALL the guys in 13.5 Rubber at the Snowbirds where Schreff laid it down on a less than 100ft track using lots of turbo!!! Yes, even in 13.5 on a small track you can use turbo to your advantage as long as care is given to gearing, RPM and delay settings.
And believe me, his wasn't the only turbo equipped RS setup out there.
Interesting. Where can I find these settings? I should like to test it out.
Rob............
*Restructuring* :)
Robio is offline   Reply With Quote
Old 06-07-2010, 11:24 PM   #15032
yodace's Avatar
R/C Tech Charter Subscriber
I used Randy P's 13.5 profile this past sunday, For a track size around 120x80 guessing.
outside temp was around 91
after 8min main final motor temp was 200
Only thing i changed was i set motor timing: 32
T3 FDR:4.49
what base temp should i shot for?
yodace is offline   Reply With Quote
Old 06-08-2010, 03:54 AM   #15033
LOSI123's Avatar
Trader Rating: 63 (100%+)
T3 FDR:4.49
are you serious???
way to low number in FDR, and way too much motor timing,
try 4 to 12 on motor (start with 4), and raise the fdr up to say 6.0 to 7.0 have a play around with fdr for your track.
200F is way too hot. you dont want any more than 180F max 160 to 170F is best
LOSI123 is offline   Reply With Quote
Old 06-08-2010, 04:09 AM   #15034
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Originally Posted by Robio View Post
Thanks for the reply. Your track is similar to my regular track. Curious, what's your motor temping at? You have a low start rpm. I was under the impression that a low start rpm might cause high temps.
Thanks again, Rob.....
Last weekend the weather was really hot, I came off from 6 min main 170-180F no fan just a clip-on heatsink with two braking zones on the current track layout.
My drive profile is 4 BTW. Your FDR is 6.0 it might be too high, mine was 8.1~8.3.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 06-08-2010, 04:53 AM   #15035
nerdling's Avatar
Hi guys,
how should I set up the RS Pro for Modified (4.5) on a medium to high grip flowing carpet track?
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 06-08-2010, 02:47 PM   #15036
yodace's Avatar
Originally Posted by LOSI123 View Post
are you serious???
It was FAST LOL...
I had the motor timing at 15 and FDR around 4.6, the second round and the temp came off around 179..after 6mins
Old 06-08-2010, 03:27 PM   #15037
ShaunMac's Avatar
Rob............
I think it's on the Tekin site under set-ups.
Rubber TC class
DUO 13.5 middle hole timing - 10 degrees
FDR - 7.7
TP - 5
NW - 10
Boost - 50
Turbo - 10
Delay - 0.0
S RPM - 5300
E RPM - 18500
Ramp 2.0
ShaunMac is offline   Reply With Quote
Old 06-08-2010, 04:25 PM   #15038
Rubber TC class
FDR - 7.7
TP - 5
NW - 10
Boost - 50
Turbo - 10
Delay - 0.0
S RPM - 5300
E RPM - 18500
Ramp 2.0
Thanks. I'll have a look there.
Looks good. I'm curious about the delay time though. I thought "0" delay was a no-no?
Rob...........
*Restructuring* :)
Old 06-08-2010, 04:54 PM   #15039
ShaunMac's Avatar
Rob...........
It can be if your FDR is too low or the start RPM's are set too low and/or too close.
This setup sorta flips the traditional boost then turbo pecking order. In this setup, the Turbo comes in immediately at full throttle, then boost starts rolling in after the higher set Start RPM is reached. You MUST run a higher FDR when using this setup or it will feel soft and run HOT!!!
There are many ways to skin a cat with the RS.
Old 06-08-2010, 05:15 PM   #15040
yodace's Avatar
Rubber TC class
FDR - 7.7
TP - 5
NW - 10
Boost - 50
Turbo - 10
Delay - 0.0
S RPM - 5300
E RPM - 18500
Ramp 2.0
I may try my current setup but lower the FDR?
are you guys using that setup for outside asphalt ?
Old 06-08-2010, 06:19 PM   #15041
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
some do
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-08-2010, 09:12 PM   #15042
Hmmm. I like the sound of that. I may test drive it. Should be a benefit where I run.
So what are you talking about for a high FDR?
Thanks for the intel.
Rob...........
*Restructuring* :)
Old 06-08-2010, 09:27 PM   #15043
cyanyde's Avatar
Originally Posted by cyanyde View Post
Randy, is V206 available yet?
Need it for this weekends club race as that is the regulation software with zero timing indication through the leds.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 06-08-2010, 09:52 PM   #15044
ShaunMac's Avatar
Rob...........
FDR really depends on track and your motor. I ran around 8.0 with an Orion 13.5 on a flowing 140ft track. I would start a DUO or SP taller than the Orion or LRP motor. I tried the Orion with more gear and it didn't like it. It seems to be an RPM based motor and the lighter gearing really seemed to wake it up and help it run cooler.
Like always, run a few laps and check your temps when trying out any new setups. Run a fan if you can to help combat overheating issues.
Old 06-09-2010, 03:14 AM   #15045
Hi all,
Need some help about where to start on the Tekin RS settings. Going to run a LRP X11 9.5T stock spec motor in an xray t2 009 running rubber tires. Mostly asphalt small and medium sice track racing. Anyone got a good pointer where to start?
minifo is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
