Old 12-02-2008, 10:13 PM   #1486
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Originally Posted by Krio View Post
I was able to test the pre-production software with the new "boost". MAD rip with my 17.5 I need to gear down now because I'm still accelerating at the end of the straight.
What gearing did you end up using and what type of racing?
Have you tried with the 13.5 yet?
I will be doing my testing this Friday with the new software, so any insight would be very useful.
dgullickson is offline   Reply With Quote
Old 12-02-2008, 10:37 PM   #1487
Krio's Avatar
Trader Rating: 150 (99%+)
I used the new software in a b4 with a 120 foot back straight. I originally had an FDR of 5.2 before cranking the timing in hotwire. Unfortunately, we did the update in the middle of the race day so I didn't have time to mess with gearing much...I ran the first qualy with the standard software and updated for the second. I can say that some punch was lost down low, but there was so much more top end that gearing down should recover the low and still have more speed. Rather than scramble to find gears, we just bumped the timing down some until the low end resembled the previous setup and it was still not winding out at the end of the straight.
I haven't tried it with a 13.5 I have a 10.5 I'm hoping to drop in this weekend...
www.kriostasis.com
Krio is online now   Reply With Quote
Old 12-02-2008, 10:51 PM   #1488
mangoman's Avatar
Sounds like you guys have developed a KERS system :P
Are you allowed to say what the boost actually does, or did i miss something back a few pages?
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-03-2008, 12:19 AM   #1489
Sounds nice... Will we have it before the DHI Cup in a little over a months time?
Foodie is offline   Reply With Quote
Old 12-03-2008, 01:02 AM   #1490
jono mad racer's Avatar
Send a message via MSN to jono mad racer
Originally Posted by Randy_Pike View Post
I also recomend the Hotwire. Any new software update will come this way.
No new "esc" of the month. Simple easy to install software updates that keep your Tekin up to speed at all times!
Most 10.5 setups use sensored only, motor timing around 24 degrees or so. Gear accordingly.
Hotwire - Can i download it off the net or do you have to buy it? A link would be great! Thanks for the tip.
Volkswagen Australia
jono mad racer is offline   Reply With Quote
Old 12-03-2008, 01:39 AM   #1491
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Software you download it, hardware you buy it
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is online now   Reply With Quote
Old 12-03-2008, 03:58 AM   #1492
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
I ran the boost at the Champs in 13.5 I had to set the motor timing at 0 and gear down 5 teeth from where I woulda been without the timing boost. I had too much bottom end!! I had to go to a less aggressive profile!! The car lunged in the infield and had the most top speed out of any car there hands down.
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is online now   Reply With Quote
Old 12-03-2008, 06:51 AM   #1493
mangoman's Avatar
There is a software and hardware component to the hotwire. You have to buy the hardware which comes with a software disk, but free updates are provided for the software on line. Does that make sense?
www.smaracing.org
Old 12-03-2008, 10:36 AM   #1494
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The part # for the Hotwire usb interface is TT1450. Then you can download the latest software via the net and you're current!
It also allows for some extra adjustments and finer step adjustments as well.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-03-2008, 10:49 AM   #1495
reenmachine's Avatar
Trader Rating: 26 (100%+)
Can you spill the beans a little more on the boost function? Specifically, will it be effective with a fixed-timing motor such as my SpeedPassion? Hopefully it's a "hybrid mode" feature.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 12-03-2008, 10:50 AM   #1496
Regional Moderator
CarbonJoe's Avatar
Randy -
When is this mythical firmware update (1.89? 1.90?) going to be available to everyone besides team drivers?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-03-2008, 12:33 PM   #1497
Krio's Avatar
I am not a team driver (for tekin at least) and was just given the opportunity to test it so I really don't know what I can or can't say, but it was openly talked about at my track.
It doesn't matter if your motor is fixed timing or not it will work equally well...I'll leave it at that
www.kriostasis.com
Old 12-03-2008, 01:39 PM   #1498
Team Tekin
Randy_Pike's Avatar
The timing boost software works in sensored only mode and will drastically help the performance of the fixed endbell motors.
Check with your loca tekin drivers if you want the software. I'm sure the'll all be more than happy to help you out with it.
Any other questions can be shot at me direct:
[email protected]
Old 12-03-2008, 01:50 PM   #1499
Wow. My fixed end bell SP13.5 is already wicked fast with the RS in hybrid mode and the timing at 90%. Are you telling me it'll be even better if I run it sensored-only with this "boost"?
Pete Waydo
Old 12-03-2008, 02:00 PM   #1500
Kenny L's Avatar
Trader Rating: 16 (100%+)
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
