Old 07-24-2003, 05:34 AM   #1
Mini-GTR's Avatar
Default Break-in for 540 motor
Hi guys
I was wondering can anyone help me out with the break in procedure for the 540 motor and how can I get more rpm out of it.
Mini-GTR is offline   Reply With Quote
Old 07-24-2003, 06:17 AM   #2
Johnny J's Avatar
Just do a search, this topic has been covered heaps and there is lots of good info in here somewhere
Johnny J is offline   Reply With Quote
Old 07-24-2003, 07:07 PM   #3
I use a 3-volt battery pack, and run the motor until the brushes "seat" or conform to the curve of the armature. This usually takes 2 - 3 hours.
Sometimes I'm impatient, so I submerge the motor in a jar full of water, apply the 3-volt batter supply (directly, not via an esc), and wait for around 1 minute.
This is my personal way of doing it, others may have different methods.
Good luck.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 07-25-2003, 02:18 AM   #4
Mini-GTR's Avatar
thanks for the help guys
Old 07-25-2003, 05:51 AM   #5
i'm new so bear with me please. last i remember electronics + water = not a good combination...
unless of course it was water-proof or something..
and wouldn't the + & - short out in the water?
anybody can enlighten me? or point me to the right direction.
versa is offline   Reply With Quote
Old 07-25-2003, 05:57 AM   #6
SpeedyTC3's Avatar
Send a message via ICQ to SpeedyTC3 Send a message via AIM to SpeedyTC3 Send a message via MSN to SpeedyTC3 Send a message via Yahoo to SpeedyTC3
Water dipping is an old means to break in the brushes on an electric motor really fast. It is used when you really need to get out on the track fairly quick.
What you would do is hook up either a 3 or 4 cell pack to the motor, and dip it entirely into a jar of water. No harm will be done to the motor or anything else. You just have to check the brushes every 30-45 seconds, or else you'll eat right through them.
Afterwards, you have to make sure the motor is completely dry of all water. I use either a hair dryer or my heat gun to do this. Once you dry the motor entirely, re-oil your bushings/ bearings, apply comm drops if you use them, drop the motor in your car with a freshly peaked battery pack and go race.
Hope this helps. Enjoy.
SpeedyTC3 is offline   Reply With Quote
Old 07-25-2003, 06:48 AM   #7
WC
WC's Avatar
Trader Rating: 28 (100%+)
DC motor is more "electric", than "electronic".
There is nothing in a motor that water can damage.
Do NOT get water near your electronic ESC though, it will fry.
Same with RX, TX, servos etc. Remove all that and, heck I
bathe my cars in the bathtub.
Running the 540 in air for hours will break in the brushes, but it
will also wear out the bushings early. Running it in water will
break in the brushes faster, but the bushings won't wear out
so fast. The water also causes resistance for the rotor, and is
a good conduit for heat generated. The water will go grey with
all the brush filings.
As said above, completely DRY the motor and lube the bushings
before reinstalling in your RC car. Wetness will promote rust.
WC is offline   Reply With Quote
Old 07-27-2003, 09:34 PM   #8
R/C Tech Charter Subscriber
I'm curious, has anyone tried it on the newer 27t rebuildable stock motors? (monster, p2k, green machine)
NismoSkyline17 is offline   Reply With Quote
Old 07-27-2003, 10:33 PM   #9
Johnny J's Avatar
People might off, but it's just stupid. All it will do is where down the brushes, so you would have to replace them
motor lathe/motor break in andy_b22 Electric On-Road 4 05-17-2006 06:29 PM
Do I need to break in my new motor? Captjono Electric On-Road 6 03-03-2005 06:25 AM
Motor Break DOES Higher AMP draw = better motor? Travis S Electric On-Road 13 02-12-2005 03:02 AM
New Motor Break-in!!! hicheef Nitro On-Road 10 05-05-2003 11:43 PM
