Old 04-15-2008, 01:02 PM   #1
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Default Slapmaster Tools MS3
Hey All,
I've been pretty quiet on the forums lately for a good reason, I've busy in the shop. I am proud to announce the release of the MS3 12th Scale Conversion kit, the successor to the MS2.3. This new chassis is more versatile allowing the racer to choose either the Asc/IRS or the CRC Pro-Strut front ends. Then you can choose between Asc, IRS, CEFX, or CRC t-bar rear ends. I am still working with a molded tubbed carbon fiber chassis. All new, is a shallow off set to the nose. By removing the shim stack, the front ends bolt right on. The foot print of the chassis, if it were to meet the carpet, is smaller then any flat plate chassis could ever be. At 4.05" wide at the edges of the cells, it's narrower then most link cars. All this adds up to corner speed. The cells can be moved fore & aft for weight bias. The cross brace is drilled out for a variety length of damper tubes.
Pre-production MS3's have already captured Roar Regional Titles in stock & 19t! Both of these cars were fitted with Asc/IRS front ends while one had Asc/IRS rear end and the other had a CEFX C12 rear end. Both cars had unmatched corner speed which carried it into the next corner. Both cars tipped the scales at a scant 788g for stock & 817g for 19t.
The conversion kits are now available! I purposely waited to announce the car. I wanted to avoid the "it will be ready in a few weeks" phrase, plus I don't like the pressure of back orders. The kit includes the chassis, rear cross brace, blue hardware, bumper, stickers, instructions & set up sheets. Ordering info should be up on the website soon. www.slapmastertools.com
If that is not enough, the Low Roll Center Sockets (LRCS) are back in stock! The LRCS provides bolt in rear traction to t-bar cars by replacing the rear socket, lowering the pivot center .050" without changing t-bar rake. We have found that a car that gets loose in the final minute of a run can go the distance with the addition of the LRCS. Or it will allow the use of more aggressive front tires. Then the 10th scale oval guys heard about this new part and immediately fell in love. Oval cars that run without tweak screws need to run 2 LRCS. The pivot ball is made of nickel teflon coated aluminum fitted into a one piece delrin socket. The 12th scale kit #116, 10th scale is #117 (which includes 2 sockets).
With the Pro 10 class coming on board, several are scooping up the #110 10th scale thrust kits to keep the diff intact. It's the same design as the popular 12th scale thrust kit but fits the 10th scale axles. Lock that diff down without slippage, get that hole shot and stop worrying about the hub bearing going bad. Many drivers have told me that they don't even work on the diff's anymore. I just smile and say: I know.
Several updates will be going up on the website shortly. In the meantime, you can PM me or email me through the website.
Brian Bodine
Slapmaster Tools
Slapmaster Tools MS3-p1010004_2.jpg   Slapmaster Tools MS3-p1010005_2.jpg   Slapmaster Tools MS3-p1010009_3.jpg   Slapmaster Tools MS3-p1010017.jpg
Slapmaster6000 is offline   Reply With Quote
Old 04-15-2008, 01:04 PM   #2
Some other pic's
Slapmaster Tools MS3-p1010005.jpg   Slapmaster Tools MS3-p1010006.jpg   Slapmaster Tools MS3-p1010011.jpg   Slapmaster Tools MS3-p1010005_2.jpg
Old 04-15-2008, 01:23 PM   #3
fjm9898's Avatar
BB out with another cool design...
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 04-15-2008, 04:00 PM   #4
corallyman's Avatar
Trader Rating: 99 (100%+)
Thumbs up MS3
The Spanker looks nice Brian, even better then the Proto at the shop.
Good job,
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 04-15-2008, 09:10 PM   #5
odpurple's Avatar
Brian,
The new tub looks awesome, so narrow! And eliminating the need for tall spacers for the front arms is brilliant. The OD12 is jealous!
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 04-15-2008, 09:20 PM   #6
skypilot's Avatar
Trader Rating: 14 (100%+)
well look at who has emerged from the darkness.
any ideas on how it will work on the pavement, i'm going to pave nats and may want a second class to run.
skypilot is offline   Reply With Quote
Old 04-15-2008, 09:53 PM   #7
JayBee's Avatar
Trader Rating: 31 (100%+)
NICE!! Brian, NICE!!
JayBee is offline   Reply With Quote
Old 04-15-2008, 10:51 PM   #8
Michael: that was the big inspiration for the MS3.... being able to use the IRS & CRC arms. I still get to keep the "goose neck" and now everyone can break the front! The CRC front end is so adaptable. I can not wait to exploit it to it's fullest.
Jaybee: gonna have to give up the touring stuff. This is a sweet ride.
Steve: you held the pre-production chassis (the ones cut by hand). All the new chassis are cut on a fixture.... very repeatable. I can not even tell the difference one to the next.
Richie: I fully intend to bring it to the asphalt. I know it will be fine. The LRCS told me so. But the "darkness"? That's only because of the countless hours in the shop. I wont even let myself out to be seen. That reminds me that I need razors & deodorant.
Slapmaster Tools MS3-p1010164.jpg   Slapmaster Tools MS3-p1010122.jpg   Slapmaster Tools MS3-p1010030.jpg
Old 04-16-2008, 09:20 AM   #9
crazy5's Avatar
Looks great brian!
YOU SUCK YOU STUPID CLOWN!
crazy5 is offline   Reply With Quote
Old 04-16-2008, 10:50 AM   #10
busman's Avatar
I should have one momentarily, as soon as I get her together I'll let you find out how it is on pavement, weather permitting.
busman is offline   Reply With Quote
Old 04-16-2008, 11:16 AM   #11
You should have it today, Mike. Plus your "buff" t-shirt! I plan on getting on the slab shortly now that the dust is starting to settle.
Here's the pair I drove at regionals. As you can see, I tried a variety of equipment and parts. Both cars felt great. Short of the power difference, I couldn't tell if one was better then the other.
bb
Old 04-16-2008, 01:21 PM   #12
Johnny Wishbone's Avatar
Hey Brian, since your making the cars chassis anyways, why not do the cutout for the transponder like the CRC cars have?? Just a thought, nice piece though.
Old 04-16-2008, 02:47 PM   #13
so how well does a BL speedo fit in there? LRP Sphere or GTB?
crisis641 is offline   Reply With Quote
Old 04-16-2008, 05:36 PM   #14
I have considered chopping a pt hole in the nose of the car, but I want to A vs B that before I send the chassis's out to the racing public. I agree that the pt hole is cool, but I don't want it to affect the chassis first and foremost.
I realize that this is a hack photo and that nothing is wired, but it should give a good example of space. I even threw in an extra rx for giggles.
Brian
Old 04-16-2008, 05:58 PM   #15
Scottrik's Avatar
Trader Rating: 245 (100%+)
Seen it.
Seen it go.
Seen it go by me, oh, three times in the main.
WOW!!
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
1/12th scale SlapMaster Tools MS2.3 fjm9898 R/C Items: For Sale/Trade 17 05-21-2007 12:37 PM
Slapmaster Tools MS2.3 Slapmaster6000 Electric On-Road 128 10-03-2006 11:42 PM
SlapMaster MS2.2 nhra6849 R/C Items: For Sale/Trade 8 03-18-2006 08:18 PM
[FS] Slapmaster MS2.3 Chassis (new) squarehead R/C Items: For Sale/Trade 15 01-03-2006 09:58 AM
SLAPMASTER - 1/12th MS2.2 litespeed-dom Electric On-Road 412 10-29-2005 12:13 AM
