Old 04-14-2008, 01:02 AM   #1
Default Motor Temperature?
Just wondering what everyone's thoughts are on maximum motor temperature. How hot is too hot? I check my motor temperature from time to time with an infrared thermometer but its not very helpful when I don't have an optimum temperature to go by.
Mike
RCNewz.com
quick5pnt0 is offline   Reply With Quote
Old 04-14-2008, 01:08 AM   #2
espresso1967's Avatar
Trader Rating: 18 (100%+)
If I may add, can also someone include run times with what setups and how long of cooling time in between your practice runs or just having fun?
Good question quick5pnt0 this was just on my mind but was wanting a bit more info.
So lets hear them temps
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 04-14-2008, 01:42 AM   #3
t4m1y4niac's Avatar
70' C is HOT.......don't ever reach that number...
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 04-14-2008, 02:01 AM   #4
Superkarter's Avatar
Depends on the application
Mod <80C
Stock 60-70C
Bashing <60C
Superkarter is offline   Reply With Quote
Old 04-14-2008, 06:14 AM   #5
zenithrr's Avatar
160 f degree is high. my batteries can't even feed enough amp to get it moving when it gets that hot. the lower temp you run the motor the better performance it gets. that's how electrick works.
TA05MS, F201, F103GT, RS4 Mini, TopForce (original), Mini Inferno, **Tamiya BMT 931 K4** "I am a new soul, welcome to the new world, so proud to joint the TEAM MORON. lalalala" We love Onions products, so touching. COL - cry out loud
zenithrr is offline   Reply With Quote
Old 04-14-2008, 06:39 AM   #6
Trader Rating: 16 (94%+)
Nobody's asked this, are you running a Brushed or Brushless motor???
I think everyone is assuming Brushless, but would be good to know.
kn7671 is offline   Reply With Quote
Old 04-14-2008, 08:43 AM   #7
zenithrr's Avatar
my hot water pump's bushless can handle 333 f degree from its spec
Old 04-14-2008, 08:51 AM   #8
Francis M.'s Avatar
I race outdoors so when the outside temp is a little over 90 and the track temp is over 120degrees it will be hard to keep the motor temps under 160..
I had a high of 179 this weekend running a final drive of 4.6 on a 13.5 novak.
I usually run my motors closer to 160 with a final drive of 4.4 on cooler days...
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 04-14-2008, 08:51 AM   #9
Francis M.'s Avatar
...double post
Old 04-14-2008, 10:35 AM   #10
I was speaking of brushed, but I'd like to hear about both.
Also where are you taking your temp readings from? The can? The endbell?
Mike
RCNewz.com
Old 04-14-2008, 12:25 PM   #11
Brushed motors normally come off in between 180F to 220F. Obviously, the lower temperature you can maintain, the better. In hot conditions (over 90F), it is pretty important to run a fan or two along with a heatsink to keep the motors in check. These items will also assist in cooling the motors off quicker once the race is over. In other words, don't let your motors just sit and bake once they come off the track, if possible.
As for where to check the temps, the hottest reading you can find with your temp gun. I usually rely on the temp gun "Highest" reading value, which allows you to move the temp gun all around the motor, and then get the highest reading.
Old 04-14-2008, 02:55 PM   #12
Trader Rating: 22 (100%+)
What if/any damage could occur over 220F on a 27T stock motor?
..... mine got hot during this weekend....
SantozRey is offline   Reply With Quote
Old 04-14-2008, 07:07 PM   #13
TeckLancer's Avatar
Trader Rating: 16 (100%+)
220 in stock pretty much = fried motor, i race stock brushed and im running a blue can, i have it from 145 to 165, but keep in mind i race asphalt outdoors so temps will very with the diffrent seasons. but me personoly i wouldnt run it a stock brushed past 180. that is the limit but for me i try to stay under 170.
hope that helps
Eric Arellano
TC5,RC18-b,PRO4,FS,EIGHT-E 2.0,TLT,TF-5,Nitro MT
Panther tires, Speedtech r/c, Murfdogg Motorworks
check oout my forsale thread http://www.rctech.net/forum/r-c-items-sale-trade/401576-wts-b44-b4-losi-8e-hpi-nitro-mt-few-lipos.html
TeckLancer is offline   Reply With Quote
Old 04-14-2008, 09:32 PM   #14
NickM's Avatar
You'll ruin the brushes. Check them after a big temp, and they'll be discoloured blue/purple at the contact ends. They then don't conduct very well at all, and should be replaced.
TRF 416 | Corally Φ | TOP Scythe | F103GT
NickM is offline   Reply With Quote
Old 04-15-2008, 06:06 AM   #15
timmay70's Avatar
You will probably ruin a lot more than just the brushes. The com copper will also discolor, both brushes and the com will harden. The winds will get darker, which is the lacquer starting to burn off. If this condition persists will lead to shorted stacks. Over heating will also weaken the magnets, as will any heat, really.
Heat is really a bad enemy to any electronic component. 165 should really be the highest temp that any stock brushed motor sees.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Temperature Gun Michael_T Australia For Sale/Trade 1 10-09-2007 06:11 PM
(PCR) Temperature Gun stimcon R/C Items: For Sale/Trade 5 09-13-2006 02:21 PM
motor temperature redlinezak Electric On-Road 2 03-24-2006 01:49 PM
How low (temperature) can I go on a motor D_o_S Electric On-Road 12 01-08-2006 06:48 AM
Motor Temperature BigRon Electric On-Road 6 12-18-2003 11:43 PM
