Old 07-22-2003, 01:03 PM   #1
Accord's Avatar
Send a message via AIM to Accord
Turbo 35 GFX Help!
This past weekend at the FSEARA state race I picked up a used GFX for $345 and am totally clueless as to all of it's features, mind you it did not come with an instruction manual. I have never owned Competition Electronics charger before, so I am not familiar at all with any of the features. Is there some sort of users guide that I can download or something along those lines?
Anyways, i've got a few questions:
1) For the motor run in mode, what should I set the volts at? Does the type of motor I use determine the volts I set it at? Also, if i'm breaking in a new motor or new brushes or something of the sort, how many minutes should I set the run in session for?
2) What is the data mode with graphs and all that? How do I use it?
3) What should I set the peak detection voltage to for 3000 and 3300 packs? I'm not familiar with the .03, .04, etc. system since i've been using a Reedy Quasar charger.
4) What is the TurboFlex mode? Do I want it on or off? If on, what should the level be set at?
5) What is "Long Lockout?" Do I want it on or off?
Thanks, and any help is appreciated.
Accord is offline   Reply With Quote
Old 07-22-2003, 01:09 PM   #2
pkranger63's Avatar
You got yourself a great charger! just go here http://www.competitionelectronics.com/gfx.htm there is a link at the bottom of the page for the instructions. Enjoy!!
Matt
pkranger63 is offline   Reply With Quote
Old 07-22-2003, 01:12 PM   #3
Caddzilla's Avatar
Send a message via ICQ to Caddzilla Send a message via AIM to Caddzilla Send a message via Yahoo to Caddzilla
Here you go, I have attached the instruction manual for the Turbo 35 GFX from their website. Hope it helps you out.
Caddzilla is offline   Reply With Quote
Old 07-22-2003, 04:29 PM   #4
Accord's Avatar
Thanks guys, most of my questions were answered, but I still have a few...
1) What peak detection voltage should I set it at for 3000's?
2) I still don't know about the motor run in mode even after reading the PDF file, what should I set the volts at for running in a new stock motor? Does the type of motor I use determine the volts I set it at? Also, if i'm breaking in a new motor or new brushes or something of the sort, how many minutes should I set the run in session for?
Old 07-22-2003, 07:22 PM   #5
pkranger63's Avatar
The promatch website recomends a cut off of .04-.05 which is what I have used and have had no complaints with the preformance of my batteries. As far as breaking in a new motor, in the old days of racing I would use 2 D-cell batteries about 2.4 volts, I carried this over the the GFX and use and use about 2.5 volts for a few minutes. It has worked for me just fine but I am sure you will be able to find a 100 diffrent answers concering motor break in. If you don't already I would check out this board...http://www.rccars.com/forums/forumdi...php?forumid=19 do a search for motor break-in. It is THE board to goto for motor information.
Hope this helps
Matt
Old 07-23-2003, 02:48 AM   #6
highwayman's Avatar
Default Re: Turbo 35 GFX Help!
ACCORD:
DATA MODE: - the data that was gathered like mah, RIR, AIR, input voltage, peak voltage and all that is contained here
3000 NiMH - SMH .02
- UMH / others - .03
3300 Nimh - .04
TURBOFLEX - only used for older NICAD's only. Not for NIMH
LONGLOCKOUT - during the lockout period, the GFX will ignore any voltage drops, to avoid "false peaks" which sometimes occur when the batts are fully discharged. for the batts that don't false peak the standard 60 sec lockout is ok... use the long lock out if the battery consitently "false peaks"
highwayman is offline   Reply With Quote
Old 07-23-2003, 05:05 AM   #7
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
accord
you got one hell of a charger... one of the guys i race with uses it and its hell a sweet!!!!
good luck with it!!!!!
S-T-R-l-K-E-R is offline   Reply With Quote
Old 07-23-2003, 07:09 AM   #8
dtm
dtm's Avatar
Send a message via ICQ to dtm
There is no exact answer to your question on using the motor mode...everyone does it slightly different. The principle of the mode is that it will put X volts out for Y seconds...whilst doing that it will measure the amps being drawn by the motor. For run in I normally use 3v 180sec...check that the brushes are fully seated after that....if not then continue with a second run. For powering a lathe you may want to use 4.5v etc......
dtm is offline   Reply With Quote
Competion Electonics turbo 35bl stealth ed, turbo 30, Pitbull x3 & Novak Millenium Pr pablo101 R/C Items: For Sale/Trade 29 10-27-2008 09:44 AM
Competition Electronics Turbo 35 BL stealth Edition And Turbo Flex 30 NIdaho Mudder R/C Items: For Sale/Trade 1 06-10-2007 07:55 AM
FS: NIB TOP .12 3port turbo motor, NIB RD Logic Turbo II exhaust rossiRocket R/C Items: For Sale/Trade 19 12-06-2005 10:10 AM
Wanted, metal lathe, milling machine, Turbo matcher, turbo Zapper lazarus Other Items: For Sale/Trade or Wanted to Buy 1 05-15-2003 12:20 PM
Tunning issue with MR12 turbo and RD turbo pipe PG Nitro On-Road 12 05-05-2003 10:19 PM
