Old 04-11-2008, 01:50 AM   #1
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Default How to remove Team Orion Vortex BL internal Fan?
Anyone tried to remove the internal fan from the Team Orion Vortex BL motors? If so, how do you do it? Any help would be appreciated.
Chirag
Chirag Patel (San Diego, CA)
1/10 2WD Buggy: TLR 22 4.0 SR 17.5
1/10 4WD Buggy: TBD
cpatel529 is offline   Reply With Quote
Old 04-11-2008, 03:52 AM   #2
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
remove the magnet from the motor
hold the magnet nearly vetically with the fan looking at the ground
place a lighter under the spot where the fan is on the shaft (it is glued)
place a calliper between end of magnet and fan to use the leverage effect.
heat shaft and fan simultaneous that way and after a few seconds you can remove the fan with a little force.
it should look like this:
s
h magnet
a calliper
f fan
t lighter
I hope you understood
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 04-11-2008, 01:08 PM   #3
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Chirag
also dont forget to pit in a small brass spacer to take the place of the fan that you just removed
Old 04-11-2008, 02:02 PM   #4
Where do I get a brasswasher that will fit? What size washer do I need?
Chirag
1/10 4WD Buggy: TBD
Old 04-11-2008, 03:55 PM   #5
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I did it the real way I took my dremel and chopped it off, didnt feel like trying to do the lighter way, and I didnt have to use a brass spacer...
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 04-11-2008, 04:05 PM   #6
m3ndo5a's Avatar
What did I miss????Why remove the Fan
m3ndo5a is offline   Reply With Quote
Old 04-11-2008, 04:12 PM   #7
GreaseMonkey's Avatar
Because any added cooling effect is countered by the added drag the fan adds.
Just a guess though.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 04-11-2008, 07:37 PM   #8
I think the drag outweighs the cooling. There must be a reason why Orion's new motors don't have the internal fan.
1/10 4WD Buggy: TBD
Old 04-11-2008, 10:04 PM   #9
SammyZ's Avatar
Trader Rating: 138 (100%+)
cant you just cut the blades off?
SammyZ is offline   Reply With Quote
Old 04-12-2008, 09:55 AM   #10
Super Moderator
Marcos.J's Avatar
yes you can!
Old 04-12-2008, 11:59 AM   #11
StevenOlsen's Avatar
Questions??
s
h magnet
a calliper
f fan
t lighter
does this trick also work on other brands then the Orion vortex ?
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 04-12-2008, 12:11 PM   #12
What motor do you want to do it to?
I dont see why it wouldnt
Old 04-12-2008, 12:38 PM   #13
Trader Rating: 45 (100%+)
1) Take note of the magnet (armature) spacing in the motor.
2) Take the magnet out of the motor.
3) Mount the magnet on something so it's vertical and can stand on it's own. If you look at the magnet and the fan you can see that the fan and magnet are held together by epoxy.
4) Take a soldering iron and some solder a start to heat up the top of fan where the epoxy is. Continue to go around in a circular motion around the fan. Once you see the epoxy start to bubble, take a rag and hold the magnet and then take another rag and pull the fan off. It should just slide off.
5) Then clean up any excess epoxy.
6) Find some shims to replace the space the fan used.
7) When putting the magnet back in do it slowly. If you just let it go it might break the circuit board inside.
8) Put the motor together and you're ready to rock.
Apex is offline   Reply With Quote
Old 04-12-2008, 11:58 PM   #14
on a GM EVO 3 4.5t
Steven Olsen
Old 04-13-2008, 01:38 PM   #15
on a GM EVO 3 4.5t
Same motor as the orion.... Just a different sticker..
It will work
Team Orion Vortex 10.5 and a 6.5!!! theanimaleide R/C Items: For Sale/Trade 12 08-12-2008 08:16 AM
Team Orion Vortex BMS mac853 Electric On-Road 2 08-04-2008 01:13 AM
Team Orion Vortex 13.5 BL motors sohlman R/C Items: For Sale/Trade 2 02-27-2008 11:54 AM
Team Orion Vortex BL 4.5 for 1:12 Scale Apex R/C Items: For Sale/Trade 6 02-06-2008 12:34 PM
Mamba Max with Vortex from Team Orion tomislav Electric On-Road 11 05-20-2007 09:49 AM
