Old 07-21-2003, 09:53 PM   #1
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
Default Discharging question
Hello guys just want to clarify something regarding discharging.
After charging a pack fully are you suppose to discharge them straight away or cool them down ?? Some ppl say cool them down some say discharge them straight away
Im quite confused, you know how racers repeak there batteries before they race to get the best possible performance ?? Well isnt it the same as charging a pack and then discharging them 20Amps straight away ??
Im using 3300GP and Sanyo 3000HV. Hope you guys can help
FUK_WRX is offline   Reply With Quote
Old 07-22-2003, 12:24 AM   #2
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Repeaking is just starting the charger over again to make sure the batteries are fully peaked before you go out on the track. Some people re-peak at a higher amperage. I don't.
Repeak as close as you can to the start of your race.
I also put the batteries right onto the discharger @ 20a right when I'm done with my marshalling duties.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 07-22-2003, 08:06 AM   #3
FUK_WRX's Avatar
Default thnkx
Gee thanks
anyone else ans some of my questions ????? guru's out there share your thought to newbies like me that aint familiar with nihms ??
Old 07-22-2003, 09:26 AM   #4
evaa's Avatar
Default Re: Discharging question
try visiting the smc thread, i got all the info i have now from that thread.
by discharging after charging, what are you trying to do? are you tryin to cycle ur packs? if ur merely cycing ur packs, its better i you let the packs rest for a minute or two before discharging, its more gentle on the batteries as they dont heat up unnecesarily, remember too uch heat is not good for you bats.
however, if your racing, its better if you use the bats within 5 mins from thetime the charge stops as the discharge voltage is higher. Dont u notice, if you run a bat thta was charged the night before and then repeake don the track the pack is not as punchy as a pack that just came out of a charge?
well, hope my inoputs helped, gudluck!
evaa is offline   Reply With Quote
Old 07-22-2003, 12:47 PM   #5
CRASH's Avatar
Trader Rating: 26 (100%+)
Discharge right away or wait?
When I cycle my batteries they get discharged 5 minutes after they are done charging. After a a race I personally do not discharge them, I just put them away.
Later,
CRASH is offline   Reply With Quote
Old 07-24-2003, 02:04 AM   #6
I think it would be better to disharge them immediately after running.
However, if they are too hot, I would wait until the batteries are cool before disharging.
You can also discharge while cooling the battery with a fan.
Hope this helps.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 07-24-2003, 02:48 AM   #7
sup
sup's Avatar
how about amp draw guys? at what amp rate do you guys discharge, 20 or 30 amps? thanks!
sup is offline   Reply With Quote
Old 07-24-2003, 06:48 AM   #8
CRASH's Avatar
AMP Discharge rate?
Most chargers on the market today discharge at either 10amps or 20amps. Some can simulate 30amps i.e. ProTrak, but for the most part the majority of chargers on the market discharge at 20amps.
My 16 x 5 V6 discharges at 20amps.
Later,
discharging Ni-Mh question. Renault_Tech Radio and Electronics 4 09-25-2008 05:14 AM
Pulse vs Linear DISCHARGING (also vs Multi-step discharging) akuhon Electric On-Road 5 01-01-2007 11:58 PM
Discharging and Discharging Question jeffbhhs Electric On-Road 5 12-14-2006 06:34 PM
Quick equalizing and discharging question Stevietd14 Rookie Zone 6 11-27-2005 12:17 AM
Intellipeak discharging question midnight oil Electric Off-Road 1 04-23-2003 03:28 PM
