Old 04-09-2008, 09:21 PM   #1
cliferton's Avatar
Trader Rating: 21 (100%+)
Default LIPO WHAT KIND OF PLUF IS THIS
ok here is my problem. I just made the lipo switch. I purchased a trakpower 4900 2 cell 25c (ROAR legal) and a imax b5 lipo balance/charger. the lipo balance uses a 2mm banana plug and then you run the + and - into the charging leads to balance. I got that figured out the problem i'm having is finding out what type and where to buy the plug that goes to the charger. in the pic it is top left slot (for 2 cell) and the second pic is of a soft pack lipo that i found online that I believe has the correct type of plug. the reason i think this is it is because when i researched this charger i found that many rc aviators use this charger and the b6 version which has a built in discharge and their batts plug right in. any help would be great. post on here in case someone else happens to run across this same problem.
LIPO WHAT KIND OF PLUF IS THIS-p1020536.jpg   LIPO WHAT KIND OF PLUF IS THIS-lipo-plug.jpg
Forget the small things I'm just here to wheel!!!!
Part of the tripod
cliferton is offline   Reply With Quote
Old 04-09-2008, 09:40 PM   #2
Trader Rating: 198 (100%+)
Just find an extra balance harness for 2 cell. And make one with 2mm banana plugs.
Hope this helps.
LIPO WHAT KIND OF PLUF IS THIS-imax.jpg   LIPO WHAT KIND OF PLUF IS THIS-balancinginstr.jpg
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-11-2008, 06:52 AM   #3
Plug looks like a JST-XH. May also be called Align/equinox/hextronik/electrifly.
Can get adapters for some connector types, like this
You will want a male JST to female trakpower adapter. If you can't find one you could make one using this, just make sure you wire it correctly.
Cornelius is offline   Reply With Quote
Old 04-11-2008, 09:40 AM   #4
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Or if your lazy like me
TrakPower makes the V balancer which has the right connectors... But if you have a normal balancer, then def make it, looks nice and easy
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 04-11-2008, 10:20 AM   #5
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
this may help ya out, ( i too am new to lip, i am pretty sure that the white plug on the battery will only plug into one slot on the charger) as for the power you can make you own with this http://nexusracing.com/product_info....oducts_id=1394
and a set of Bananna Plugs
JasonC is offline   Reply With Quote
Any kind of ESC Creepy 2 R/C Items: Wanted to Buy 8 11-06-2007 05:40 AM
What kind of car is this? Aoplayo Chat Lounge 5 01-18-2006 08:27 PM
RDX one of a kind Keith Billanti R/C Items: For Sale/Trade 14 12-04-2005 11:45 AM
One of a kind xxx-4G+ Driver1 R/C Items: For Sale/Trade 10 11-13-2005 04:24 PM
What kind of car is this? FL_Racer R/C Items: For Sale/Trade 22 02-27-2004 01:10 PM
