Yokomo MR4 Rally?!
I was looking out at MR4 cars... and.....
Found THIS pic. IS that the MX4 body and cover? I never knew the MR4 came with a cover!! OR does it?
if it doesn't appear, it's on this webpage:
http://myhome.naver.com/nowingu/mr4rally.htm
(the picture with the cover)
The rally car from Yokomo comes with the inner body dust cover. You can tell the rally car from the touring car by the upside down servo. I have two of the rally cars and I like them alot.
Is it possible to take a YR4 racing chassis, add an MX4 under cover (or an MR4 undercover), and race on dirt for softcore rallying?
(Softcore rallying in my terms = no jumps. Just small bumps and lots of dirt).
Also, will the MR4-TC hold up okay as a rally car?
There is almost no difference in a MR-4TC and the MR-4 Rally, just longer shocks and different steering connections and different front and rear bulkheads. The inner body will not fit on the MR-4TC because of how the servo is mounted on the chassis. If you want to convert a tc to a rally you would have to get a rally chassis and about 60 bucks in other parts to get the job done right. I just converted one of my rallies to a MR-4TC special and I found out that the rally is slightly different than the tc.
As to your other questions I haven't seen a YR4 or a MX4 before, but if they use the same tub chassis that the MR4 uses then you could use the dust cover on them.
