Old 03-29-2008, 11:15 AM   #1
blackdog's Avatar
Thumbs up Needed asap stock/foam TC5 (set up)
Looking for a real good set for my AE TC5 for indoor foam at fastcats.Car has 100 tooth 64 p spur and spool front diff .
the car was run as rubber outdoor before I got it so please any help what do real fast too as I need this for the stock/foam class this Sunday march 30 .Everything posted on the web are mainly rubber tire set ups so this is why I am I need . Any threads or personal set up will help out surely .
Thanks in advance
Matt R
blackdog is offline   Reply With Quote
Old 03-29-2008, 11:20 AM   #2
http://www.teamassociated.com/racerh...setups_tc5.htm
Stugots is offline   Reply With Quote
Old 03-29-2008, 11:24 AM   #3
Maybell's Avatar
The 08 Snowbirds Keven Hebert/Juho setup on rc10.com should be a good starting point.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 03-29-2008, 11:30 AM   #4
blackdog's Avatar
Default Needed asap stock/foam TC5 (set up)
Hi
Just wondering .the set ups at AE are with mods or brushless ,they will work pretty good as well with running a stock motor ???I guess they wouldn't be far off from a foam set up ???
Matt
Old 03-29-2008, 11:35 AM   #5
blackdog's Avatar
Thumbs up
Going to be wrenchin for a while thanks guys
Cheers
Matt
Old 03-29-2008, 06:41 PM   #6
Maybell's Avatar
Originally Posted by blackdog View Post
Hi
Matt
that setup should still be a great starting point for any motor...
for gearing, check what final drive ratio the fast guys are running at your track and start there....
good luck!
Old 03-30-2008, 11:19 AM   #7
blackdog's Avatar
Thanks to everyone for the great input .
Matt
Old 03-30-2008, 08:46 PM   #8
robk's Avatar
Trader Rating: 22 (100%+)
You probably can run less camber (like 1.5*) with stock. Also, you may need to fool with the front shock oil. 60wt might be better if the car gets on the nose a lot. A brush stock motor may have more drag brake in it, so that is something to look out for.
2B on the steering link has also worked well for me. It makes the steering more "mellow", but still provides a lot of overall steering. Definitely better for more "human" drivers
Jack the gripper is different from Paragon slightly. If you are on a paragon track, you may need to glue the edge of the front tire. I did so at the ROAR nats (paragon), and it helped a lot.
There is the possibility of moving the front shock in on the arm, but it will make the car steer way more, and you will probably have to play with the oil, and maybe the spring.
The setup is really good, start there. Just giving some tips I have found helps with less powerful motors
Old 03-30-2008, 09:47 PM   #9
Seems some guys in europe run foam on carpet, check here for some setups if you need more http://www.petitrc.com/view_news.php?id=7450
Arn0 is offline   Reply With Quote
AE RC18R foam mounted tires needed asap blackdog R/C Items: Wanted to Buy 2 03-15-2008 07:29 PM
1-WAY NEEDED ASAP hybridom R/C Items: Wanted to Buy 0 07-31-2006 05:42 PM
T3 CHASSIS NEEDED ASAP dado11g R/C Items: Wanted to Buy 3 07-27-2005 10:43 AM
.21 pipe needed asap... 6Cuda6 R/C Items: Wanted to Buy 0 08-09-2004 05:42 AM
needed asap mr barracuda Australian Racing 1 01-13-2004 06:55 AM
