New TEAM WAVE racing brushless system >
Old 05-13-2010, 02:42 PM
  #1246
Originally Posted by Frankgw View Post
Thanks TEAMWAVE for the quick response.
I have tried holding down the button for longer. No LEDs light up.
Looks like it could be a faulty button.
Is this a common problem?
Is it possible to fix?
Do you have a repair service in the UK and how much would it cost?
Sorry about all the questions. It would be a shame to bin it if it's only a button problem. I would like to use it if possible, the new firmware sounds great!
Thanks again, Frank
This may be a stupid qusstion but I noticed you never mentioned turning the esc on or off. Did you hold the button down THEN turn the esc on? Also I have noticed that sometimes you get rubbish in the switch and it stayz on all the time. Is your switch always on?
Dragonfire is offline
Old 05-14-2010, 06:12 AM
  #1247
TLRacing's Avatar
Default New Firmware
Any update on when the new firmware will be available to the public?
TLRacing is offline
Old 05-14-2010, 09:50 AM
  #1248
err... yes and no.
Sorry I didn't mention it. Thanks for the help anyway. It's going back to Muchmore UK for investigation.
Cheers, Frank
Frankgw is offline
Old 05-15-2010, 04:26 AM
  #1249
ATLASCOPCO's Avatar
Come on guys give us teamwave followers some kind of idea what`s going on with this firmware we just would like to know when we could expect to keep up with others
Cheers guys
ATLASCOPCO is offline
Old 05-15-2010, 04:32 AM
  #1250
Pablo Diablo's Avatar
Cheers guys
Only Team Wave can answer that question. The latest evolution is working very well at the Much More Masters in Sydney Australia. We will give you an update tomorrow after the event.
Pablo Diablo is offline
Old 05-15-2010, 04:36 AM
  #1251
ATLASCOPCO's Avatar
Cool thanks Paul
Old 05-15-2010, 06:59 PM
  #1252
team minkya trf's Avatar
are the rbs escs competitive with the tekin in 17.5 in running lrp spx and its hopeless
team minkya trf is offline
Old 05-16-2010, 02:31 AM
  #1253
ATLASCOPCO's Avatar
Not at the moment , there is a new firmware that is coming out real soon that should be on par with all the top speedos.
keep looking for the update i am
Old 05-16-2010, 04:00 AM
  #1254
Well just finished up the Much More Masters here in Sydney. Surprisingly it was a small field but the quality was still there in the spec classes. Team Waves new software managed TQ and the win in superstock (10.5). In stock it qualified 3rd and finished 5th (3 way tie for 3rd) even with 2 bad finals. Not a bad effort with the driver struggling to get his head around a new chassis. Anyway it lacked nothing.
Hopefully the software is up soon for everyone to play with...
For those interested my settings were
Timeshift-9, Gain-2, Turbo-2, Kickin-3, FDR-5.6
I found turbo of little benefit as the timeshift setting alone was very fast but after I lost a drag with a LRP by 1 inch I was annoyed and turned it on. Temps were in the high 60's with plenty of warm up laps.
Old 05-16-2010, 03:24 PM
  #1255
ATLASCOPCO's Avatar
Well done good to hear it
Im pleased that you had a good day with the TW
FDR-5.6 was it a big track and what motor was you using
Old 05-16-2010, 06:57 PM
  #1256
Motor was a Duo 1. I have found that higher FDR's result in less torque and higher temps due to constantly running at higher timing. Also the lower FDR gives much better grunt out of the turns using the motors natural torque and the ESC simply applies the speed. The BD system (V1 and V2) also seems to work in a similar fashion and gets results too.
Old 05-16-2010, 08:17 PM
  #1257
Trader Rating: 22 (100%+)
What hole was the timming set on for the Duo?
bjspinner is offline
Old 05-16-2010, 09:14 PM
  #1258
0 degrees.
Old 05-16-2010, 11:09 PM
  #1259
So you borrowed a BD V1 for 1 day, and you now know how the BD V2 works?
Besercoe is offline
Old 05-16-2010, 11:13 PM
  #1260
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Brad,
I thought by now you would've realized that Troy knows everything :O !!!
A Ilievski is offline
