Old 02-25-2010, 01:23 PM   #1051
rcmarek's Avatar
Originally Posted by hacker View Post
you can go way lower than 4.45fdr. I've been as low as 3.0fdr but with 0 motor timing. You can take it up to 10c more.
To be honest I did try that (60spur, 40 pinion) but the car felt sluggish and the lap time was slower It seems that in the 21.5 class the gearing is almost counter-intuitive (to quote my friend PDR It feels like the motor is happier to spin with turbo than work hard with high gearing. I believe that the guys @ Castle Hill are also on very short rollouts with their Tekins yet they were doing circles around me on the straight when I had the 3.0FDR.
Marek | SMA | M03 | TC5R | F104
rcmarek is offline   Reply With Quote
Old 02-25-2010, 01:33 PM   #1052
rcmarek's Avatar
Default gearing and set up for TC5R 21.5 RBS Duo2
Hi Darren (decibels), can you please suggest a set up for SMA based on your testing and experience with the RBS? I'm interested in both gearing and set up of the RBS. Maybe I had incorrect setting on the RBS when I was using the long rollout (high FDR ~ 3.0). Thanks Marek
Old 02-25-2010, 01:52 PM   #1053
Originally Posted by jorgesimes View Post
Hi audriusv,
1st thing to do is to know what is the roll out that some of the drivers are using in that track, even if its from a diferent motor or turns, its just for having an ideia and maybe stablish a starting point for 17.5T. Try and use the Gear Chart site and create a table that fits your pinios and spurs.
ESC Settings - From the stock settings it seems to me that you have to take the step forward in turbo2x, since that will affect the perfect FDR/Roll out for you.
Motor Timing SP V3 - since i'm using a 9.5T SP V3 (since our rules for stock class are this turns), what i experienced is that motor works better in this ESC with timing at maximum, mixed with a change in the FDR from 5.9 to 7.0 (don't remember exactly, but its aproximated) on a Medium/Large track. Always keep an eye on motor temps!!!
That's a wrong ideia that if you use a low gear means low temperature, gear it to much down or gear it to much high and motor and Esc temperatures will be high. I'm talking in excessive diferences from optimal gear.
hope this helps, will be waiting your feedback.
Hi Jorgesimes,
thank you for trying to help me. Today was on track to test car. So now my config was: tyres ~56mm, spur 100, pinion 29. Motor timing all the way to max, 10 degree mark. ESC settings:
Neutral brake - 5;
Brake force - 3;
Turbo - 1;
Time shift - 3;
Drive profile - 4;
Brake profile - 6;
Temp cut - 2;
Lipo cut - 2;
Motor type - 1.
At start ESC worked well but after few laps (and I was not driving fast) ESC faded, speed dropped drastically. After turning ESC off and on speed comes back but again after two or three laps fades. I do not know where to look? With that same motor and same battery and Tekin RS Pro everything was working good. Where I have to look? Maybe something wrong with ESC? Maybe I have to put fan back on ESC? Maybe ESC temp cut off works? HELP!!!
Audrius
www.rc-cars.lt - offroad in Lithuania
www.lasa.lt - onroad in Lithuania
audriusv is offline   Reply With Quote
Old 02-26-2010, 04:07 AM   #1054
@audrius - I would always prefer to use the fan. I would never leave the fan out. They have a secure margin, but even so, i would never leave the fan out.
Try to see the capacitor voltage.
From what i've tested in your case i would go for turboX2 and maybe 25 or 26 pinion. Or 1st try with your setup but using 25 or 26 pinion.
Let's see if i can explain better:
1st testing
Spur: 100
Pinion: 27
Tire Diameter: 54 mm
Roll out: 45.80
2nd testing
Spur: 100
Pinion: 29
Tire Diameter: 56 mm
Roll out: 51.02
My bet - turboX2
Spur: 100
Pinion: 24-26
Tire Diameter: 54-55 mm
Roll out: 40.72 - 44.92
What was the pinion and spur that you use with tekin?
Hope this helps.
jorgesimes is offline   Reply With Quote
Old 02-26-2010, 05:30 AM   #1055
1st testing
Spur: 100
Pinion: 27
Roll out: 45.80
2nd testing
Spur: 100
Pinion: 29
Roll out: 51.02
My bet - turboX2
Spur: 100
Pinion: 24-26
Hope this helps.
Jorgesimes,
I will try to look at capacitor voltage. But in parallel I have contacted TeamWave support and they would like to get my ESC back for checking. There could be that the driving circuit may have problem... I think I will send ESC for inspection...
I have asked here about fan and there was post from TW that for 17.5 motor it is safe to remove the fan.
Also I do not think that two or tree laps (it is about 12 sec. for one lap going not so fast, fastest guy do it in 9 sec.) can overheat ESC or motor with my settings? Or can it?
Thank you very much for help! I will need it when my ESC comes back from TW. Then I will try what you have suggested!
Audrius
Old 02-26-2010, 07:09 AM   #1056
@audriusv - But did you check the ESC Temp? Because i have the ideia from your post that you didn't. If you didn't check the capacitor. I had once a problem like that on a LRP SPHERE and it was just the capacitor that didn't mantain it's voltage, have changed it and power on again.
Old 02-26-2010, 07:13 AM   #1057
Yes, I will check capacitor.
Well I put my finger on ESC. So if it not burning I think that temp are in reasonable interval :-)
Audrius
Old 02-27-2010, 12:26 AM   #1058
decibels's Avatar
What software. because i recomend the b. then i can advise settings.
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 02-27-2010, 02:57 AM   #1059
rcmarek's Avatar
Default RBS 21.5 Duo2 TC5R @ SMA
Hi, I have the updated version 1.0b. Thanks
Old 02-27-2010, 03:12 AM   #1060
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Can anyone give me a step by step process of updating this speedie? I had an attempt, but couldnt get it. I need to get rid of the reverse problem ASAP RB-S btw
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 02-27-2010, 03:50 AM   #1061
Trader Rating: 10 (92%+)
install this http://www.teamwaveonline.com/2007/TW_APP.zip
also install this http://www.teamwaveonline.com/2007/P...B%20Driver.zip
read this http://www.teamwaveonline.com/2007/R...t%20manual.pdf
load http://www.teamwaveonline.com/2007/RBS_V%5B1_0_b%5D.frm onto your programmer software
captain stacker is offline   Reply With Quote
Old 02-27-2010, 04:05 AM   #1062
even better, here you have a video that explain everything:
Team Wave Video Software update
Old 02-27-2010, 04:50 AM   #1063
Link dosent work for some reason
Antoni Caretti
Old 02-27-2010, 07:34 AM   #1064
revsinc's Avatar
Trader Rating: 15 (100%+)
link should be
http://www.youtube.com/watch?v=uKIkXYXHAMA
its all in german ........
Full Speed , Half Price
revsinc is offline   Reply With Quote
Old 02-27-2010, 08:26 AM   #1065
isnt the only revisions for the b software was to accommodate for the reversing for the x12 motors, or is there more?
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
