Old 02-23-2010, 10:17 AM   #1036
Hi audriusv,
1st thing to do is to know what is the roll out that some of the drivers are using in that track, even if its from a diferent motor or turns, its just for having an ideia and maybe stablish a starting point for 17.5T. Try and use the Gear Chart site and create a table that fits your pinios and spurs.
ESC Settings - From the stock settings it seems to me that you have to take the step forward in turbo2x, since that will affect the perfect FDR/Roll out for you.
Motor Timing SP V3 - since i'm using a 9.5T SP V3 (since our rules for stock class are this turns), what i experienced is that motor works better in this ESC with timing at maximum, mixed with a change in the FDR from 5.9 to 7.0 (don't remember exactly, but its aproximated) on a Medium/Large track. Always keep an eye on motor temps!!!
That's a wrong ideia that if you use a low gear means low temperature, gear it to much down or gear it to much high and motor and Esc temperatures will be high. I'm talking in excessive diferences from optimal gear.
hope this helps, will be waiting your feedback.
jorgesimes is offline   Reply With Quote
Old 02-23-2010, 10:27 AM   #1037
Hey ho all, has anyone had any experience with an RB30 running RBS firmware? Can it be done? Anything to worry about? I have read that people are doing it with RB50 with no apparent issues. As the tech specs for the RBS are the same as the RB30 (I have added a cooling fan) then I cant see why it wouldnt work.
I am running 10.5 in a TC and our normal track has a long straight so I think the Turbo x 2 may make a big difference!
Ta for any help.
Chris
topher2009 is offline   Reply With Quote
Old 02-23-2010, 12:26 PM   #1038
Danny-b23's Avatar
Ta for any help.
Chris
Since the RB-S is pretty much just a "reboxed" RB-30, I don't see why not. With 10.5 on a long track you might not even need the cooling fan. I see a lot of people here running the ESC fan on a mount pointed at their motors.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 02-23-2010, 12:31 PM   #1039
Danny-b23's Avatar
Found a good setup for a small carpet track with my 17.5 car.
Neutral Brake 3
Brake Force 3
2x Turbo
Time Shift 6
Drive Profile 8
Brake Profile 4
Temp Cut 3
Voltage Cut 2
Motor: SP V3 17.5
Battery: SMC 4000 28c
Danny Buck
Old 02-23-2010, 12:44 PM   #1040
hey guys has any one have any success running the rb-s in 12scale with a single cell and 17.5.
cyrrus is offline   Reply With Quote
Old 02-23-2010, 12:50 PM   #1041
RC MARKET's Avatar
FREE Shipping !
RC MARKET is offline   Reply With Quote
Old 02-23-2010, 10:10 PM   #1042
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by jorgesimes View Post
@Goingfast - send an email to the ones in the site, they will answer you very quickly and help you for sure. Follow the link bellow.
Team Wave
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 02-24-2010, 05:40 AM   #1043
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Well it looks like I'm the second person to blow a Novak 21.5 and an RB-s in the one run.
I just bolted a new motor in and it won't work..... Puling it out now to whack my RB30 in its place.
Not very pleasing really....
fleetmaster is offline   Reply With Quote
Old 02-24-2010, 11:44 PM   #1044
decibels's Avatar
Well i did warn you about to much timing on a novak and this speedy. they don't mix that well. other motors are allright but not novak
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 02-25-2010, 01:32 AM   #1045
revsinc's Avatar
Trader Rating: 15 (100%+)
and your gear ratio is ........
Neutral Brake 3
Brake Force 3
2x Turbo
Time Shift 6
Drive Profile 8
Brake Profile 4
Temp Cut 3
Voltage Cut 2
Motor: SP V3 17.5
Full Speed , Half Price
revsinc is offline   Reply With Quote
Old 02-25-2010, 02:34 AM   #1046
rcmarek's Avatar
Default 21.5
Hi, can you please tell us what were the setting on the speedo & set up of your car when you fried the electronics including the size of your pinion/spur?
I'm running TC5R (internal gear ratio 2) RB-S Duo2 21.5 with 69 spur and 31 pinion, 2x turbo, 2/3 timeshift on the motor and 4-5 timeshift on the speedy (other relevant settings on the RBS are 3-2, 4-5, 5-7, 6-8) and both motor and speedy are around 60 degrees C after 5 minutes race.
The settings on my car are enough to be in the top 3 @ SMA but I was way too slow when compared to the Castle Hills guys. I'd like to know how far I can go with the set up before I join the fried bunch
Marek | SMA | M03 | TC5R | F104
rcmarek is offline   Reply With Quote
Old 02-25-2010, 04:20 AM   #1047
hacker's Avatar
Trader Rating: 141 (100%+)
you can go way lower than 4.45fdr. I've been as low as 3.0fdr but with 0 motor timing. You can take it up to 10c more.
hacker is offline   Reply With Quote
Old 02-25-2010, 04:20 AM   #1048
hacker's Avatar
is this the ss pro series or ballistic?
Old 02-25-2010, 05:49 AM   #1049
Mine was SS, the other a Ballistic .
I honestly didn't feel I was pushing the motor that hard. Timing was at 3/4 on the motor.
Roll-out 42 odd mm. Turbos on. Time shift 3.
Motor didn't bother me , but blowing the esc did.
Trying RB30 with original firmware. Speed Passion V3 21.5.
Turbo on.
Timeshift 1.
Profile 9 (max).
Roll-out 47.95.
This will be my baseline. Motor timing stock. Will not touch unless all other avenues are exhausted.
Looking for top end , so gearing may go up....
Old 02-25-2010, 06:30 AM   #1050
hacker's Avatar
Turbo on.
Timeshift 1.
Profile 9 (max).
Roll-out 47.95.
I found with the ss series motors that you get hardly any gain in top end with more motor timing, but it creates a whole lot of heat. Also dont forget the novak ss motors are 30 minimum timing, so if you had it at 3/4 it would probably be around 40 motor timing, coupled with turbo 1/2? and your looking for trouble.
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
