Old 08-28-2008, 09:39 PM   #91
joebiii's Avatar
Trader Rating: 16 (100%+)
Just rcv my RB30 also , it looks good and can't wait to try it this wknd.
Only got a very small problem, I think they forgot to include the rubber cover on my motor. . I'll just put stickers on it...
joebiii is offline   Reply With Quote
Old 09-04-2008, 09:53 PM   #92
mytoda5's Avatar
is it can if i install fan to my rb30..?...can anyone tell me how if feel by tuning the timing..i already broke one mamba esc cos i always change the setting..please advice..and one more..i change the lipo cut seting to 2cell lipo then the motor run slower but my lipos is fully charge..why?..
dsm n 2.4ghz....kalu ariel panjang sejengkal..jangan diduga track 400m..
mytoda5 is offline   Reply With Quote
Old 09-05-2008, 01:25 AM   #93
wide_mouth_frog's Avatar
Hi there, I purchased some fans from www.coolcanfan.com, he sells the fans on their own or a really nice carbon fiber mount with 3 fans in it, 2 for the motor and one for the ESC...
There are photos on his website if you need them
As for settings, what motor are you running?? I currently have mine on factory settings and have no problems at all.
Maybe Team Wave will be able to help you out, I know they are busy guys, so give them a little time to reply.
Adam
wide_mouth_frog is offline   Reply With Quote
Old 09-05-2008, 01:58 AM   #94
Out of the box this speedy is awesome but... If you are running spec wind the timing up to max and turn on the turbo... Both of these make a noticable difference to speed and power!
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-05-2008, 05:01 AM   #95
mytoda5's Avatar
wow..cool fan..tq for the link..
i'm using the team magic e4js..its really fast but i got problem when i decide to use 64p 42T pinion and 98T spur..the esc getting hot..and some strange burn smell came out..can some one tell me is that the ratio that i'm using is suitable for the 7.5T motor?..what pinion and spur that i should use?..please advice..
Old 09-05-2008, 07:15 AM   #96
mytoda5's Avatar
e4 fit with 7.5T teamwave..please advise on gear ratio..
Old 09-05-2008, 08:24 PM   #97
TEAMWAVE's Avatar
Hi mytoda5,
correct me if I am wrong, the internal drive ratio of E4 is 2.059, 98T spur and 42T pinion will results 4.8 final which will definitely burn your ESC if running a 7.5T! The proper gear ratio should be about 6.X-7.X depends on track size. Please start at 98T/29T.
TEAMWAVE is offline   Reply With Quote
Old 09-06-2008, 01:42 AM   #98
mytoda5's Avatar
thank u teamwave..now i'm using the 110T verse 33Tpinion..that is rite for the 6.85 gear ratio..but my esc got no problem even it smell burn..but still perform the best..only one problem..turbo mode cant be on..if i do that..the motor will be stop after 3-4 second top speed..please advice..and u got ur pm teamwave..
Old 09-07-2008, 11:30 AM   #99
Hi Max,
I'm Azwan from Malaysia.
Will email and currier you on my RB30 issues. Thanks for a few phone-in supports. I agreed the setting was relatively easy. As a user of team wave product i'm fairly satisfied with its features.
It was smooth and definitely cooler than normal brushed motor. The "Time shift" and "turbo" features are really noticeable. Not to forget the braking setup available.
At the moment I need your supports on my shipments to HK and back. Can't wait to test it again.
Still loyal to team wave! Good job!
Cheers!
crabsteer is offline   Reply With Quote
Old 09-10-2008, 01:41 AM   #100
Ran the RB-30 with 10.5 on a tight twisty track last night.
The car was awsome, I under geared it slightly at a overall of 7.0.... I feel I could have gone up at least 2 pinions and it still safe.
Speedo stayed very cool, motor got warm, but I didnt run a fan on the motor... only the speedo.
If anyone has any troubles or questions, ask away and I will try to help...i did say try!!
Can up load photos of the speedo installed in a Corally RDX Phi if interested?
Adam
Old 09-10-2008, 03:23 AM   #101
decibels's Avatar
ive currently been testing the rb30 on behalf of someone and i have to say very user friendly everything works great its a cheap well worthwile speedy but i have only one problem which im a bit worried about!! twice now it has dropped settings or something cause the motor is like you have a flat battery and when you re program it it is all good again! but to have this happen in one of your a mains would make life a bit stressful!! any ideas?????
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 09-10-2008, 07:33 AM   #102
Hi there decibels,
I had an email from Max saying it could be the "turbo" function that makes it lose its settings but this is only on the prototypes and in hot weather.. turn this off for now and all should be well as far as I am aware.
If any of the above is wrong, I am sure Team Wave will point it out
Give it a go anyhow chap
Adam
Old 09-10-2008, 08:49 PM   #103
TEAMWAVE's Avatar
Hi decibels, I have send you a PM. This is the problem on your prototype sample same as wide_mouth_frog. Later will send you a software upgrade.
Old 09-10-2008, 11:49 PM   #104
joebiii's Avatar
How are we suppose to do the software upgrade ? is the programming box avlbl already or we need to send it back to "teamwave" ?
Old 09-11-2008, 01:30 AM   #105
I personally have not had any problems, and I am sure thefull production esc will be perfect.
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
