Old 02-04-2010, 07:27 AM   #931
kp-61's Avatar
this is gonna be a newbie question but how do i calculate roll out?
* VISA * MASTER CARD :)
kp-61 is offline   Reply With Quote
Old 02-04-2010, 07:39 AM   #932
Iceman 69's Avatar
Originally Posted by cvt01 View Post
By upgrading you meant uploading the latest RBS firmware to your RB-50 right? Earlier this thread somebody indicated that you may go down as much as 9-10mm with the rollout when using 2x turbo and lots of timeshifts
yes you right upgrading software, when you say lots of time shift you mean crank that sucker up?
Cyclone TC~SP GT pro~10.5????????
Cyclone ~ RS Pro ~ SP13.5 V3
Cyclone ~ Spare
Iceman 69 is offline   Reply With Quote
Old 02-04-2010, 07:40 AM   #933
Iceman 69's Avatar
i visit www.gearchart.com, and its easy
Cyclone ~ Spare
Old 02-04-2010, 08:04 AM   #934
Rollout = (tire diameter * 3.1416) / ((spur / pinion) * internal gear ratio)
Iceman,
Yes "lots of timeshift" means crank it up (6 or 7). I never tested it myself though just quoted an earlier post...
cvt01 is offline   Reply With Quote
Old 02-04-2010, 08:46 AM   #935
kp-61's Avatar
thank you for the link and the formula!
now got to measure my Jaco rubber tires.
Old 02-04-2010, 10:36 AM   #936
Casey Belarde's Avatar
does anyone have a good base line set up for the RB-S
for WGT 1s 13.5 (duo 2)
track 100x60 high grip carpet
thanks
Casey
Casey Belarde is offline   Reply With Quote
Old 02-04-2010, 10:39 AM   #937
Johnny Wishbone's Avatar
62mm, but now if your talking about rubber tire racing, most make reference to FDR over rollout.
Old 02-04-2010, 10:50 AM   #938
kp-61's Avatar
Yes i am running rubber tires. Once the track switches over to carpet onroad, i will try the suggested 3.9 FDR with turbo 1x and see from there.
Just checked the lap time and my buddy was 2/10ths of a sec quicker per lap over me.
Old 02-04-2010, 11:53 AM   #939
jaco is 62 cs27 is 63 thats not a big difference so FDR does make sense, however we run VTEC 30R or something which is like 65mm. thats a big difference we talk about (enough to burn a motor). They use rollout on foams because the diameter constantly changes but if we compare gearing in this thread, rollout is still much better because of the differences in rubber tire diameters.
Old 02-04-2010, 12:29 PM   #940
kp-61's Avatar
as long as i can chase those tekins I will be more than happy ..
*back on testing*
Old 02-04-2010, 02:28 PM   #941
Originally Posted by tandman View Post
Lanzer, crank everything on the esc settings and then gear for temo of 160-170.....if you need more infield lower the time shift setting. Time shift is the esc timing as far as I can tell it does not seem to be dynamic timing just a preset timing. Turbo is an extra amount of timing that comes on at 95% throttle. Drive profile is punch. Ian tried a RB-S last night and was impressed by the power compared to his LRP TC.....he picked up 3 tenths right away and the motor temp was only 130f.
Me thinks there is more potential in the SC other than maxing the settings, more testing will tell.
Old 02-04-2010, 03:47 PM   #942
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Pablo Diablo View Post
I just tried it with 10.5 and the ESC got warm quickly. I think Team Wave put the fan on for a good reason. Maybe 17.5 would be ok. I will test my RB50 with RB-S firmware tomorrow night. Will let you know how it goes.
Paul, I spoke to Les D late yesterday. Apparently he smoked the RB50 with the firmware upgrade.
This didn't surprise me ,as he tends to be little heavy on rollout with all his escs.I guess he took it too far this time ?
I will try mine , but only with a 21.5 or 17.5. I will be sure to gear it way down. With the SPX + 21.5 on the current Windsor layout, I got down to 45mm approx . rollout. The previous layout I ran around the 52mm mark, so this is a decent step.
Not sure if it's the layout,my aggressive driving or the sheer amount of grip available (all 3 perhaps?) , but people need to be careful witgh ANY advancing esc.
Regards,
Michael.
fleetmaster is offline   Reply With Quote
Old 02-04-2010, 05:36 PM   #943
tandman's Avatar
Send a message via Yahoo to tandman
Lanzer, I am sure you will get it figured out......I like to crnk everything right up and work down from there, Maybe thats why I give the occasional smoke show
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 02-05-2010, 03:40 AM   #944
WOW
xspower is offline   Reply With Quote
Old 02-05-2010, 04:34 AM   #945
decibels's Avatar
Guys if you crank up the time shift then you will be slow when you are feathering the throttle!! because when turbo is activated it seems to only have rip when you hit full throttle!! This is why i am prefering turbo1 and a bit of motor timing!! because the motor naturally wants to perform down low with motor timing and when you hit turbo it wants to rocket! now remember turbo on this speedy is different to every other it seems to ramp current to the motor which produces power and as a side effect seems to give more rpm as well or timing as most people refer. turbo 2 definately adds timing on top as well. but always remember time shift will not give you more timing with turbo switched on. now i have had no success with timing on turbo 2 but i had a test firmware from original prototype which i now have version b so will test a bit more and let you know!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
