Old 01-08-2010, 07:52 AM   #766
prhess's Avatar
Originally Posted by Pablo Diablo View Post
Sorry for trying to help.
Most people who race, the people who this ESC is suitable for, would never run their lipo down to 6V. Only people bashing on the street have to worry about this. It is possible for the voltage to drop below 6V, for a very breif moment, when racing when the current draw is very high. Like when on full throttle, using twin turbo, out of a tight corner. Even if the resting voltage of the lipo is over 7V, it can go below 6V momentarily when in use. I assumed you were not stupid enough to run your lipo till it dumped, maybe I was wrong on that assumption. It is common for people with not the latest and greatest Lipo's on the market to have to disable Lipo cut.
Can I suggest you don't over react so much next time you don't fully understand someone else advice??
I have to agree with cherry on this...running no lipo cut off is silly and poor advice to give on a messageboard. If your lipo is dropping significant voltage during a hard throttle pull with an RB-S, try higher c rated lipos. Any you need to chill on your responses to people
prhess is offline   Reply With Quote
Old 01-08-2010, 08:21 AM   #767
cherry2blost's Avatar
Default In rebuttal
Sorry for trying to help. Most people, who race, the people who this ESC is suitable for, would never run their lipo down to 6V. Only people bashing on the street have to worry about this. It is possible for the voltage to drop below 6V, for a very brief moment, when racing when the current draw is very high. Like when on full throttle, using twin turbo, out of a tight corner. Even if the resting voltage of the lipo is over 7V, it can go below 6V momentarily when in use. I assumed you were not stupid enough to run your lipo till it dumped; maybe I was wrong on that assumption. It is common for people with not the latest and greatest Lipo's on the market to have to disable Lipo cut. Can I suggest you don't over react so much next time you don't fully understand someone else advice??
Hi again and sorry for any offense which you may have taken, as none was intended.
In reply, firstly I am “not stupid enough to run your lipo till it dumped” the only time I ever drop my LiPo’s to 6v is when undertaking my monthly balancing regime. I set the cut-off to 6.2v and when the cells are off I deep discharge them to 6v using a balancing discharger set at 1amp. Once 6v has been hit I rest the cells for about 10 minutes to allow the chemistry to settle and then balance charge them, at 1/2C, to capacity. This has allowed me to have the same LiPo’s for a considerable time with no blow ups or loss of capacity.
As you are one of our Colonial cousins I will forgive the assumption that was made, “people who race, the people who this ESC is suitable for”; are we saying that a car park basher will not buy a Team Wave ESC? As we all know our American cousins have a saying about Assuming. The content of the original post was that he was dumping and the car was in go slow, this would normally indicate that the LiPo’s have reached their safe threshold, I just pointed out that if he were to disable cut-off, as advised, there would be a considerable chance of Damage – or worse occurring.
I for one would be worried to pit next to a person who has no cut-off, is possibly using older cells and has had them down below 6v for a period, these things do have the tendency to become volatile once the Lithium within the polymer begins to re crystallize into Elemental Lithium, so my original comment still stands as to the treatment of LiPo cells in this manner.
Good advice to ALL users of LiPo technology should be to follow the guidelines laid down by the various governing bodies (for racing) around the world, I for one have never bought a LiPo pack, or charger, which did not give dire warnings for dropping below 6v.
So for the sake of our ‘car park bashing’ brethren let’s have a little common sense with these things, or else we may be reading in the papers of kids having terrible burns when one goes up on them.
Thanks for your fine reply.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 01-08-2010, 03:15 PM   #768
runinonempty's Avatar
Trader Rating: 19 (100%+)
Originally Posted by TEAMWAVE View Post
ioxqq,
When LiPo cut engage, it will slow down your car and let you drive to a safe area, other ESC will straightly cut your power and that is danger !!
runinonempty:
Did you try "Step 8, notes" on the handheld programmer manual?? (You can download from our website)
The "Linear motor" has a wider gear ratio than other "rpm type" motor. You can use timeshift, turbo 1, turbo 2, drive profile and gear ratio to tune what you need. That will cover all low,mid,high power.
Team Wave tried that and still no luck??????
Dragonfire will you be running at SMA tommorrow?
if you are can you please bring your laptop computer with you and I will come down at lunch and see if you can update the firmwear if thats ok with you.
Cheers
Xray T4, Tamiya M05 S-Spec
with lots of dust
runinonempty is offline   Reply With Quote
Old 01-11-2010, 06:35 AM   #769
Godbreaker's Avatar
hi guys..has anyone tried the rb-s with a speed passion v3 11.5T motor..?
Godbreaker is offline   Reply With Quote
Old 01-11-2010, 06:52 AM   #770
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
There is a very reputable esc brand that has a voltage cut off lower than 3v per cell to deal with this. Guess who....
dontfeelcold is offline   Reply With Quote
Old 01-11-2010, 07:08 AM   #771
I think everyone who changed from nimh to lipo knows this. I think they use a sudden cut at that voltage rather than a min time under that set voltage before cut.
Anyway I recommend 6.2V or higher cut for spec racers and 6.0v for mod. Anyone below 6.5v on a spec motor will be at the end of the pack anyway. If its happening with a fully charged pack try a different pack. Chances are your lipo has outlived its usefulness and may be unsafe to use.
People should also be aware that the quality of their battery connectors makes a huge difference to the performance of the car. A cheap connector can sometimes work very bad even though it looks like it is connecting fine.
Anyway I thought I might mention my testing from the weekend. For those running a 50 in modified. I tried some different ESC settings looking for a smooth powerband through out the rpm range with good top speed. Testing with 4.5t motors I found timeshift 2 with taller gearing gave better results than lower gearing and trubo. I also found the torque type motors feel much better than the rpm type which were a little soft down low but produced very similar top end. I am really keen to try one of the TW Linear 4.5's on this speedy.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-11-2010, 07:21 AM   #772
ran this setup with ip 5000mah 40C lipos for a recent race... fairly decent... pace was abt the same with the tekins and lrps....
just remember to gear down if you turn on 2X turbo... also make sure you do not gun the throttle too early and too much.... let the motor rev up to 95% throttle to utilise the torque before the turbo kicks in...... motor temps can be pretty high with turbo enabled....
GP On-Road:
Xray NT1 09 // Novarossi 353 09 Tuned // Blitz Altis 2.3 // Spektrum DX3R
EP On-Road:
TOP Photon // LRP SXX TC Spec // LRP X12 4.0T // IP 5000mah 50C // Spektrum DX3R
Sponsor: My good self...
katze is offline   Reply With Quote
Old 01-11-2010, 07:30 AM   #773
Godbreaker's Avatar
hehe thanks katze for the info..greatly appreciated
Old 01-11-2010, 07:55 AM   #774
Any of the new ESC's with torque type motor should be pretty good. The SP motor should have no problem dealing with the heat.
Powered by Falco
Old 01-12-2010, 04:05 AM   #775
duggyload's Avatar
Default Rollout
Hi guys i need some help
my car seems to be slow down the straight infield the car feels fine
straight is about 40m long with a long sweeper at the begining and end so if the car is slow on top end you loose allot af time lap times are about 15 sec
i used the rb50 with a 13.5 epic 2 duo geared to 4.72 timing on zero
turbo on and time shift to max (5) 5000mah 30c flightmax lipo
we will be racing this weekend again and i have put in the tw 13.5 linear motor (which was slower than the epic when we tested in the street)
could somebody help am i overgeared or not. Surely if i gear down the car will be even slower (the motor does not get to hot either)
thanks in advance
duggyload is offline   Reply With Quote
Old 01-12-2010, 05:42 AM   #776
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
try turning your time shift down to about 5. thats what i found best at my local track. (has about 40m straight)
mild seven is offline   Reply With Quote
Old 01-12-2010, 07:01 AM   #777
On the RB 50 I like the feel of timeshift 3 for spec racing as it gives better punch out of the turns and also less heat. Try that along with a little more gearing to get the speed you want. You should find you will get a little more punch too.
Powered by Falco
Old 01-12-2010, 07:15 AM   #778
duggyload's Avatar
Thanks for the replys
i will try gearing up
my time shift only goes to 5
so i will try it on 2 or 3
Old 01-12-2010, 08:18 AM   #779
some news about the RB-12?
youb is offline   Reply With Quote
Old 01-12-2010, 08:33 AM   #780
Yeah I'm keen to hear about that too. I was wondering what motor limit an RB-S would have on 1S? I was thinking if it could handle a 3.5t then it might be pretty good although what we really need is a 1S lipo cut setting.
Powered by Falco
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
