Old 01-05-2010, 12:34 PM   #751
Barry_Hughes's Avatar
Originally Posted by decibels View Post
Yes with turbo 2 on you can produce a lot of rpm and will have to gear down about 9 teeth in gearing which is about 10mm for me but you need to make sure not to have any timing on your motor. but on a tight track you might need to try between turbo 1 and 2 as when you are on full throttle to much it heats up the motor to much and fades!! But this also depends on the motor you run as turbo 2 suits low reving motors a lot and brings new life to them!! and remember when running turbo the time shift setting is to control how revs before turbo kicks in!! Just some starting tips hope they help!!
9 teeth
I have just received my rb-s with the 13.5T Linear motor and going to put in my Cyclone TC, previously running Losi Excelerion 13.5 combo on 67/35 giving 4.13 FDR are you saying I should change to 67/26 or the equivalent to get 5.57 FDR.
Barry_Hughes is offline   Reply With Quote
Old 01-05-2010, 04:22 PM   #752
deanomgwhiteguy's Avatar
Send a message via MSN to deanomgwhiteguy
Thanks slot guys very helpful!
How are the linear motors doing up against others like speed passion and Orion
Dean Mellor
Xray T2'007/KO/ORION
AE SC10
deanomgwhiteguy is offline   Reply With Quote
Old 01-05-2010, 08:51 PM   #753
TEAMWAVE's Avatar
runinonempty:
What is the problem actually? You can't start downloading the firmware or any other problem?
deanomgwhiteguy:
Linear motor is the same as speed passion motors but with 12.5mm rotor. (Some SP motors use 12.3mm rotor)
If you run 10.5T, you need RB-S. Yes, faster and cheaper !
Barry_Hughes:
That depends on your track size, you can keep your ratio if you have long straight.
TEAMWAVE is offline   Reply With Quote
Old 01-06-2010, 01:28 AM   #754
decibels's Avatar
Originally Posted by Barry_Hughes View Post
9 teeth
You can gear a bit more with the linear motor as they have a lot of torque but twin turbo is quite different! i say to gear down because i do not want you to cook your motor on the first run as you need to gear up slowly!! Otherwise it can mean more money!! better safe than sorry but i like rollout better and i went down 10mm on rollout which happens to be about 9 teeth for me but every car works out different but play safe if it is too slow then gear up and check your temps!! But start at around 5.3.
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 01-06-2010, 04:42 AM   #755
runinonempty's Avatar
Trader Rating: 19 (100%+)
Yes team wave I cannot put the new firmwear on to my rb 30 when I go through the correct process on one of the other guys at the track rb 30 as soon as I flick the switch on programing card the new firmwear begins instaling on the rb 30
when I try with mine nothing happens?
Based on the fact that we can get it to work on another rb30 eliminates the possibilty of a doggy USB cable and program card so it must be the speed control
as I mentioned before it stil works fine just a bit slow as it has not had the updated firmwear
what can do to rectify this problem?
Xray T4, Tamiya M05 S-Spec
with lots of dust
runinonempty is offline   Reply With Quote
Old 01-06-2010, 06:33 AM   #756
So you have updated a 30 previously with the same computer/cables/program box using the same com port and settings?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-06-2010, 06:40 AM   #757
Hey all again!
Last question for me, can you update the firmware on the rb s?
Dean Mellor
AE SC10
Old 01-06-2010, 03:07 PM   #758
Yes
with lots of dust
Old 01-06-2010, 06:07 PM   #759
Originally Posted by deanomgwhiteguy View Post
Hey all again!
Yes you can if there is another firmware revision release for it. The new 1.2 is for the 30-50 not the RB-S.
xspower is offline   Reply With Quote
Old 01-07-2010, 08:43 PM   #760
I just installed RB-S, the lipo setting set at 6v cutoff. When the battery is low, I see my car suddenly goes so slow. Just like a ant is walking on the track, I think this this dangerous on the track to put back the car. Is this normal?
ioxqq is offline   Reply With Quote
Old 01-07-2010, 08:47 PM   #761
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
This is what happens when the ESC goes into Lipo cut. Try a lower voltage cut off or no cut off. The RB-S will draw a lot off current and need good fresh Lipo's.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 01-07-2010, 09:27 PM   #762
Team Wave is there any solution to my problem?
with lots of dust
Old 01-07-2010, 09:58 PM   #763
TEAMWAVE's Avatar
ioxqq,
When LiPo cut engage, it will slow down your car and let you drive to a safe area, other ESC will straightly cut your power and that is danger !!
runinonempty:
Did you try "Step 8, notes" on the handheld programmer manual?? (You can download from our website)
The "Linear motor" has a wider gear ratio than other "rpm type" motor. You can use timeshift, turbo 1, turbo 2, drive profile and gear ratio to tune what you need. That will cover all low,mid,high power.
Old 01-08-2010, 01:46 AM   #764
cherry2blost's Avatar
Hey Pablo I am not normally one to criticize but you have just given possibly the worst piece of advice ever!
What happens to LiPo's when we discharge them below 6v, they either become paperweights or, worse still they GO UP IN SMOKE.
Why on earth would you suggest that someone, who is obviously deep discharging there LiPo's, should turn off the protection for their batteries by dropping the voltage threshold below 6v or worse still TURNING OFF the LiPo cutoff altogether.
I am hoping that the above post was meant as a tongue in cheek joke and was not a serious post, if this is the case then I apologise for getting so het up about this.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 01-08-2010, 07:31 AM   #765
Sorry for trying to help.
Most people who race, the people who this ESC is suitable for, would never run their lipo down to 6V. Only people bashing on the street have to worry about this. It is possible for the voltage to drop below 6V, for a very breif moment, when racing when the current draw is very high. Like when on full throttle, using twin turbo, out of a tight corner. Even if the resting voltage of the lipo is over 7V, it can go below 6V momentarily when in use. I assumed you were not stupid enough to run your lipo till it dumped, maybe I was wrong on that assumption. It is common for people with not the latest and greatest Lipo's on the market to have to disable Lipo cut.
Can I suggest you don't over react so much next time you don't fully understand someone else advice??
Paul H
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
