Old 12-30-2009, 08:14 AM   #706
scoyle's Avatar
Some questions...
I am currently running a Nosram SPX indoors on carpet - I have it set at punch 8 with a ratio of 5.8 in 10.5. Can someone point me in the direction of settings for an RB50 in relation to punch, timeshift and turbo for indoors.
I have seen some people posting about the RB12 for 12th scale - when will it be on general release?
scoyle is offline   Reply With Quote
Old 12-30-2009, 08:49 AM   #707
tandman's Avatar
Send a message via Yahoo to tandman
The Speedpassion V3's only have a 10 degree advance. I always run mine at max 10 degree timing and gear from there. They do make quite a bit more power that way. At 0 timing or even 5(factory set) they run a little flat with no top end. I am running them in touring car rubber tire with the RB-50 profile 7, time shift 2, turbo on. on a 70X36' track geared at 4.09 with a fan on the motor they come off around 130-140f. I am still working on esc setup and gearing but this is the best so far.
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 12-30-2009, 09:58 AM   #708
bukil's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Pablo Diablo View Post
From my experience Tekins and SPX's don't have anywhere near as much rip out of corners as any of Team Wave speedo's!
I own both speedos (TW and TEKIN). You haven't seen my TEKIN in action then .
bukil is offline   Reply With Quote
Old 12-30-2009, 06:35 PM   #709
deanomgwhiteguy's Avatar
Send a message via MSN to deanomgwhiteguy
Hey guys
These team wave electronics look kick a$!. Does anyone know if there is a distributor for team wave in Australia? Also anyone know the cheapest site to get the RB-50 + Linear brushless motor 10.5T combo pack. Really keen on getting on of these has anyone had any slight problems with them?
The motors have ajustable timing right?
Cheers for some answers
Dean Mellor
Xray T2'007/KO/ORION
AE SC10
deanomgwhiteguy is offline   Reply With Quote
Old 12-30-2009, 07:03 PM   #710
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
Hi deano,
yes there are a few shops stocking them in Australia. contact Pablo Diablo as he is the distributor for Oz.
Budget racer is one of the shops in Victoria that stock them.
mild seven is offline   Reply With Quote
Old 12-30-2009, 09:45 PM   #711
Originally Posted by deanomgwhiteguy View Post
Hey guys
Also Windsor Hobby and Race center is prolly the best place to start looking. I am not certain that there are any combo packs being made up but I sure the shop will offer a better than shelf price to make up a combo for you anyway. If you have a local shop that stocks them go for that first though.
The Linear motors do not have adjustable timing just the same as the SP sportsman series of spec motors.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 12-30-2009, 09:47 PM   #712
I would say you haven't got the RB setup properly then. The Tekin can still produce more RPM in racing config but you will need a decent length straight come close to gaining any advantage, unless they have a RB-S in their car, then you will have no chance.
Powered by Falco
Old 12-30-2009, 09:56 PM   #713
Originally Posted by Redwood View Post
Hi guys,
Do any of the experienced guys (Pablo or Dragonfire) know what the best motor timing for the RB-50 is? I have a SP v3 13.5 and with my SP GT 2.0 speedo I set it to maximum motor timing but after reading this thread it seems like I should go for minimum timing but bump up the timeshift, anyone have any experience to share?
Neal
As Pablo said I wouldn't bother with changing the timing on any motor. My brother and myself have played around with timing a bit and find that you tend to create more motor temp for the same top speed with more timing and less gearing. I think you will find that the factory timing on any motor you buy is generally the best place to run it. There are only loses of bottom end or top speed when you make a change. You need balanced performance to win races unless you are drag racing or oval racing.
BTW even though many motors are marked "0" timing at some point it is usually much more than this.
Powered by Falco
Old 12-30-2009, 10:14 PM   #714
Casey Belarde's Avatar
has anyone been running a RB-S with 13.5 and a 1s lipo?? if so how did it work still use a booster or Rx pack?
Casey Belarde is offline   Reply With Quote
Old 12-30-2009, 11:38 PM   #715
tandman's Avatar
I ran the Rb-50 in stock touring again and geared up to a 3.90 fdr, timeshift 2, turbo on, drive profile 9 motor temp with one fan was in the 150's f. Geared at 4.1 fdr it had slightly more infield punch and lower motor temp but the 3.9fdr just felt better and was easier to drive more consistently. The fast lap was the same but was easier to repeat at the 3.9 fdr. I tried different timeshift settings and different drive profiles but this yeilded the best results. Higher time shift took away the infield punch but did give a little more at the end of the straight but lap times were slower.
Dwayne Flodell
Team Mad Scientist
Old 12-31-2009, 03:35 AM   #716
Yes it will work fine. We are running them now. Yes to either the bosster or the rx pack one or the other.
xspower is offline   Reply With Quote
Old 12-31-2009, 03:36 AM   #717
Originally Posted by scoyle View Post
Some questions...
I am running the RB30 in my 1/12 scale now and it is real smooth with all the power you need. Atleast until new products become available.
Old 12-31-2009, 03:47 AM   #718
Redwood's Avatar
Thanks for the replies guys, much appreciated.
Can't wait to see my Team Wave in action!
Neal
Redwood is offline   Reply With Quote
Old 01-02-2010, 03:32 PM   #719
Conrad's Avatar
Originally Posted by TEAMWAVE View Post
For Radio system support, Futaba R153/R133 receiver use 2.5V signal level which is too low for RB series speed controller. All 2.4G system use 5V system already and no problem for RB series controller.
For PCM system, it will work with PCM1024 and PCM synthesizer.
If user found problem with their receiver, please send us an email, we can ship you an extension cable which can boost the 2.5V signal to 5V.
A little shout out to the Team Wave support, Max sent me out a couple of leads for both of my team wave esc's to solve the problem, now they work a treat with my antiquated futaba radio gear
Conrad is offline   Reply With Quote
Old 01-02-2010, 04:14 PM   #720
Some questions:
* Does the TW linear motors deliver the power at lower revs than most BL motors out there?
* And is all brushless linear motors?
* Does anyone have a god page with info about rc dc motors? types of BL, etc.
MatsNorway is offline   Reply With Quote
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
