Old 10-23-2009, 04:53 AM   #481
Originally Posted by kerk View Post
Just a suggestion which is stated in the manual, did you reverse your throttle output on your transmitter? It is stated in the manual that you have to do that if you are using a Futaba Tx.
I run mine on a 3PKS with either a 75Mhz module/rx combo or Spektrum Pro HRS combo. Both with HRS "ON". They work fine.
Cheers!!
Already reserved the throttle.. but still had those problem..
nietzbatik is offline   Reply With Quote
Old 10-23-2009, 04:55 AM   #482
Originally Posted by TEAMWAVE View Post
1/12 speedo RB-12 is on the way, stay tuned!
ok!! very interesting!
youb is offline   Reply With Quote
Old 10-23-2009, 06:05 AM   #483
Originally Posted by nietzbatik View Post
I'm usually running my RB50 with TW Linear 3.5R 2S Lipo (factory default setting with Turbo On, my gearing 11.2)
but it seem i only get it running right just for 4 minutes then it cut off..
any setting advice will be appreciated..
Also what is the best setting for RB50 with 11.5R motor?
WOW! With a 3.5 you already have crazy power, there is no need for turbo as it will just make everything hot.
Its important to note that the RB series turbo is NOT the same as turbo on many other ESC's which simply advance the timing for more top end. The RB turbo forces more current through the motor to give you more of everything (power and speed). When you run spec turbo and correct gearing will give you a big advantage but with modified turbo is only going to create lots of heat with no usable beifit. From my testing I find timeshift 3 is as high as you need to go on a 3.5 with around 19mm rollout. This will allow you up to 6min runs without problems.
Note: So far this speedy has generated some crazy top end from any motor I have thrown at it so if you race mod I suggest a 4t or 4.5t with timeshift up to 5. This gives very good power and race pace and you won't have problems with heat even on a warm day.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 10-23-2009, 06:26 AM   #484
actually i want the 4.0R better.. but my LHS just have it as a package with TW Linear 3.5R..
Dragonfire: thanks for your advice set up.. will try it on my next race day..
Do you have any set up for RB50 using 11.5R?
Old 10-23-2009, 06:58 AM   #485
decibels's Avatar
with 11.5 you should run boost and time shift 4 to 5. Gear at around 36mm roll out and adjust according to temperature and lap speed. you can also turn up the drive profile for more punch but find the balance to suit the motor you run!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 10-23-2009, 09:04 AM   #486
kp-61's Avatar
Hi,
I am looking to purchase the RB-30 (RB-50 too expensive for me) and will be using it with a 21.5 for the VTA class. Since been away from RC for a loooong time. Will i suffer against the new tech of the SPX stock Spec and Tekin RS? (they are what most drivers use in the track). I will be using a 2S 4000 28C pack.
I will be using my old T2 '06 with the track being 90 x 40 what gearing would you recommend? any good store where i can buy the RB-30 at a reasonable price?
oh yeah.. was never an A main driver
Thanks !
kp-61 is offline   Reply With Quote
Old 10-23-2009, 09:23 AM   #487
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Originally Posted by kp-61 View Post
Hi,
Thanks !
You won't suffer they will. In Australia we have proven that the RB30 can race competitively in 10.5. 21.5 will be a walk in the park for this speedo. The turbo will give you the same top end as a SPX but much more punch than a SPX could dream of.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 10-23-2009, 09:24 AM   #488
RC MARKET's Avatar
Hi,
Thanks !
you can add a fan cool down your RB-30 !
RB-50 Free Shipping NOW !
RC MARKET is offline   Reply With Quote
Old 10-23-2009, 09:36 AM   #489
Team Wave had some good results tonight at a club race in Sydney Australia. In the premier class, 10.5, 1st, 2nd and 3rd were all using Team Wave RB speed controls. In fact the win was with the RB30 proving just how capable the RB30 is for any class of spec racing.
On a tight and technical track it seems Time Shift of only 2 or 3 gives more punch than 4 or 5. Top speed is still great thanks to the Turbo feature. There should be no doubt that Team Wave speed controls are as fast as any other speed control on the market.
Paul H
Old 10-23-2009, 11:43 AM   #490
kp-61's Avatar
This is very encouraging.... now to get the right price with the shortest shipping tim..
thanks !
Old 10-24-2009, 09:08 PM   #491
mikelee's Avatar
Have any setup for 4.0 R or 4.5R.
I play 416we and use Li-Po 5000mah 40C, (RB-50) Brushless system.
THX!
mikelee is offline   Reply With Quote
Old 10-27-2009, 08:58 AM   #492
THX!
I did some testing on that subject yesterday. I found that you can actually MATCH the power and speed of a 4.0 with a 4.5 by using the turbo feature of this speedy. My best results were with....
22mm rollout
timeshift 3
turbo on
drive profile 3
I found that you can have as much (if not more) power and speed than a 4.0 with your 4.5. It also runs cooler and you have the advantage of power at full throttle (turbo) an driveability when you lift of the throttle. This was all tested on a BIG track where power matters.
Scary thing is I know what is coming and how much better it is!
Powered by Falco
Old 10-27-2009, 06:26 PM   #493
New software update? New esc?
I now of the they are working with a 12th scale esc, is there something else tooo in project
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 10-27-2009, 06:41 PM   #494
No one knows anything more than Team Wave have said. I only found out about the 1/12th speedo by reading it here. They have already released one firmware upgrade and I guess its always possible another one will be released one day.
Paul H
Old 10-29-2009, 12:22 PM   #495
bukil's Avatar
Trader Rating: 39 (100%+)
I'm planning on getting the RB30 with 17.5 motor for my RCGT car. Does anyone have a base setup for this motor combo?
Thanks in advance
bukil is offline   Reply With Quote
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
