Old 10-02-2009, 07:29 AM   #451
Originally Posted by DaveG28 View Post
Guys, just setting up my Wave RB50 and 5.5 in my 4wd off road car, what would be food settings for the esc?
Dave
Assuming you are running 6cell nimh or 2 cell lipo the 5.5 is generally a hot motor for offroad. Start with the speedy settings soft (no turbo and timeshift 0) and work your way up from there. i don't think turbo will be useful with that motor in offroad but if your car is dialed, give it a go. I would start with a rollout of around 23mm.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 10-02-2009, 06:30 PM   #452
cheehtae's Avatar
Trader Rating: 15 (100%+)
looking around for a nw speedo, it's either rb30 or sp 2.0. my question is w/c is holding me back in getting the TW RB30 is reliability since I've been reading the threads here that racers that have been using it is having alot of problems but what I like about it is it's Turbo function. BTW I'll be using it mainly in 13.5 1/12 and 21.5 VTA. any advice also where to get it in U.S.?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-02-2009, 09:07 PM   #453
The RB-30 will be fine, and fast.
Powered by Falco
Old 10-05-2009, 07:41 PM   #454
AdminD's Avatar
Default TeamWave RB-50 Brushless Limits
Originally Posted by TEAMWAVE View Post
Hello everyone here, I am glad to info all of you that we are releasing a new brushless speed controller coded "RB-50" (Racing Brushless system 50). This speedo is the smallest sensored brushless controller in the market with highest power and functions. We hope to release to the market in May/2008. More photos and information will be available next month.
TEAM WAVE "RB-50" Racing Brushless Controller Specification:
Brushless Motor : no limit
Brush Motor: no limit
Rated current: 400A Continuous
BEC: 6V, 3A Continuous
Input voltage: 4-6 Cells NiMh, 2Cells LiPo
Protection: Temp cut (adjustable), LiPo cut (adjustable)
Mode: Forward with brake (brush/brushless), Forward/Brake/Reverse (brushless)
Adjustment: Neutral Brake, Brake force, Turbo Drive, Time shift (motor timing), Throttle profile, Brake profile
Cooling fan: High power high speed cooling fan included
Capacitor: Small size super low resistance capacitor included (10mm diameter x 21mm length)
Body size: 34mm * 31mm * 18mm (W*L*H)
Body size with heatsink: 34mm * 31mm * 25.5mm (W*L*H)
Extra features:
*World smallest sensored racing brushless controller
*Easy soldering 2-way bullet soldering post (can accept up to AWG10 wire)
*Direct flow technology
*Turbo drive technology
*Time shift technology
*Updateable firmware
*Optional setup unit
you say that
as mention RB-50 are no limit,...
But not on teamwave site they mention that,
Brushless motor limit 3.5T (5 cells), 4.5T (LiPo),
is it no limit ?
is TeamWave RB-50 able to run 3.5T on 6Cell Brushless?
is TeamWave RB-50 able to run 2.5T/2.0T on 6Cell Brushless?
is TeamWave RB-50 able to run 2.5T/2.0T on 2SLi Brushless?
Sliders
AdminD is offline   Reply With Quote
Old 10-05-2009, 08:30 PM   #455
303slowdown's Avatar
Trader Rating: 24 (100%+)
I run a rb30 in my 13.5 rubber car and have not had a problem with it . Also it is just as fast or faster than other esc's
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 10-05-2009, 08:47 PM   #456
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Originally Posted by AdminD View Post
you say that
is it no limit ?
I am not aware of a competative racing speed control that can handle 2.0t. In summer in Australia people have to be very careful running 3.5T with Lipo with any brand of speed control. On the race track, which the RB50 is designed for, using a 2.0T will only make you slower anyway. If you are making a top speed car then any racing orientated speed control will give you problems.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 10-06-2009, 08:10 AM   #457
you say that
is it no limit ?
I was given one of these speedies to test not that long ago. On paper the speedy looks great but i have heard about failures. If you read this thread a bit most failures seemed to be related to RB-30's or water. Anyway I went out to my local track and tested it at its limit meaning 3.5t with 2s lipo. It was a large track with almost a 50m main straight. I did numerous 6min runs with zero problems and more power and top end than my current speedy which has event titles to its credit. It did get warmer than my current speedy but it is a lightweight and smaller type speedy so I expected this. I also didn't have the fan mounted correctly as the supplier was using it for 10.5 and had removed it. All in all it held up fine and at the end of the day I'm sure I had it overgeared still. I would say a failure would be more a case of bad luck or improper use than exceeding its limits.
Powered by Falco
Old 10-11-2009, 08:06 PM   #458
AdminD's Avatar
Pablo Diablo
Dragonfire
i was hoping TEAMWAVE could answer my question, to be clear for us.
Sliders
Old 10-11-2009, 08:53 PM   #459
R1wurks's Avatar
is there a us distributor?
R1wurks is offline   Reply With Quote
Old 10-11-2009, 08:59 PM   #460
cheehtae's Avatar
ultralinehobbies.com
Old 10-12-2009, 12:16 AM   #461
Is there any real reason to get an rb50 instead of an rb30 if it is going to be used in TC with a 13.5/17.5 ?. Would the rb50 be any faster than the rb30 for such applications?
MoonTrap is offline   Reply With Quote
Old 10-12-2009, 12:21 AM   #462
Ran the RB30 in 13.5 1s 1/12 scale today and it worked pretty well. No problems to report yet.
Ryan Borgheiinck
Old 10-12-2009, 12:43 AM   #463
TEAMWAVE's Avatar
RB50 is designed for 5cells NiMH (3.5T) and 2cells LiPo (4.5T). Like any other ESC on the market, running LiPo 3.5T/4.0T is on the limit and have higher chance to failure.
For stock racing, RB30 is already enough.
RB30/50 can run 1 cell LiPo with receiver battery, we will update the firmware to support 1 cell LiPo cut off later.
For US customer, you can also order in our online shop.
TEAMWAVE is offline   Reply With Quote
Old 10-12-2009, 01:18 AM   #464
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
Is the motor limit lower with 1 cell lipo? Explain the turbo function and firmware advantages in more detail please.
Caster Racing USA Dirt Oval
Hyperdrive
Tekin
THD Custom R/C Products/Team Holy Rollers/Team Terribles
loopedout is offline   Reply With Quote
Old 10-12-2009, 12:17 PM   #465
Ran the RB30 in my world GT Sunday with 1S LiPo and 10.5 motor. Very impressed for the first run, it is very easy to set up and alter the settings.
Tried several gearings from 65mm up to 75mm roll out and basically confused myself as to weather the turbo was effective at the higher gear or not, or if I should go lower still???? Motor did not get hot at all so perhaps higher???
If anybody has any experience a bit of help would be much appreciated.
Looking forward to an update for 1S cutout
Paul
rallybloke is offline   Reply With Quote
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
