New TEAM WAVE racing brushless system
#346
hi max you have a mail
regards
olivier gremillet
regards
olivier gremillet
#347
well I finally got round to installing my RB50 into my car and went testin yesterday and wow it was quick only problem is after 5 min it came off at about 90 deg.
So a few questions
Is there / is there going to be a update in terms of brakes as I felt them being a bit soft at time (no late braking).
What fan systems are people running on these
What settings are people running?
What temp. should you not go above?
I was running a team wave 10.5 and nosram motor on it yesterday at a out door large tarmac track (cotswold uk)
Any input would be much appreciated.
So a few questions
Idon't know if you have adjusted it but you can set the brake amount and aggressiveness just turn them up to full and back off to 70 % brakes and see how that goes!! increase percentage till you get to a happy median. i also felt a lack of brakes but with the aggressiveness turn up to max the brakes come very strong straight away a bit like a punch control!! hope that helps as i belive this is a very fast speedy. i beleive the fastest for spec racing!!
#348
regards
olivier
#349
Good !
#350
#351
razzor,
Supercap has much higher internal resistance than the battery. The use of the cap is to help the battery for instant current output, if the capacitor resistance is higher than the battery, how can it help to output? The battery not only need to give power to the motor, it also take time to charge the cap. Supercap is useful in application where the resistance of the battery is high. In RC application, the resistance of the battery is very low !
#352
razzor,
#353
We are happy that TEAM WAVE driver Sammy Fung TQ and won Much-More cup Hong Kong in 11.5 pro-stock class using TEAM WAVE RB50 ESC and Linear 11.5T motor !!
In the same race, TEAM WAVE driver Mr Ip kwok wai placed 2nd (A2) in 1/12 modify class using TEAM WAVE RB50 ESC and Linear 5.5T motor !!
Date: 2-MAY-2009
Venue: TRC racing circuit Hong Kong
Pro-stock:
1st: Sammy Fung (Hong Kong , Team Losi, TEAM WAVE)
2nd: Azri Amri (Malaysia, X ray, LRP)
3rd: Hj Irman (Brunei, X ray, LRP)
1/12 on road:
1st: Micheal Cheung
2nd: Ip kwok wai (Hong Kong, Associated, TEAM WAVE)
3rd: Poon Chiu
Thanks for Samuel Chiu (Much-More Hong Kong) supporting this race.
Date: 2-MAY-2009
Pro-stock:
1/12 on road:
1st: Micheal Cheung
3rd: Poon Chiu
#354
We are happy that UK Team Wave driver, Tom Jefferies won 1st place in Pro-Stock at the Much-More UK GP, held in Stonehaven, Scotland between 12th - 14th June. Tom used the TEAM WAVE RB50 and Linear 10.5T motor.
Pro-Stock:
1st Tom Jefferies (UK, TEAM WAVE, Team Associated)
2nd Scott Kenny (N. Ireland)
3rd Mark Musgrove (UK, Schumacher)
Tom will use the TEAM WAVE RB50 at this weekend's UK BRCA National at the Halifax circuit.
Jason Lowe won the Team Wave RB30 in the raffle and local TEAM WAVE driver Kenny Clark won a Team Wave Linear 10.5T motor!
Thanks to Keith (Much-More UK) for supporting this race.
Pro-Stock:
#355
WHats the resistance of the controllers?
#357
I had issues with my RB30 and the temp cutoff, even disabled shows the solid red led and slows the car. Also it only has three setting for the lipo cutoff. 2 cells, 3 cell and disabled. Can be upgraded to the latest version with more voltage options?
#358
Pro-Stock:
Pro-Stock:
Good news !
#359
Hi chemax_t,
Yes, the firmware can be upgraded using the RB-handheld programming unit, which is now available in our online store @ USD20.
Software and firmware can be download from our home page next week.
www.teamwaveonline.com
#360
the software upgrade makes a massive difference to the speedo, at the much more gp i ran the new version of the software and the difference was very noticable. There is a noticlabe improvement in braking feel and power, as well as a fair bit of extra horse power. when i first switched to team wave i used the speedo with a different make of motor but i found that using a team wave motor as well as the speed controller gives large power gain over other systems.
tom
tom
