Old 01-21-2009, 08:08 PM   #256
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I think the problem was cause due to people were running timing on the low turn motors. I was running a 4 turn with 2 degree timing when my RB50 gave. I sent mine back and got a new replacement I will be trying it again but with 0 timing set on the motor.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 01-22-2009, 12:49 AM   #257
Tpg racer's Avatar
Shouldnt it thermal or shut down when such things happen rather than just died on the spot without room for error....
Coz to me running some timing on the motor is just a lil minute error that anyone could have accidentally done without realizing it...
Tpg racer is offline   Reply With Quote
Old 01-30-2009, 03:56 PM   #258
KennyClark's Avatar
First night of the season back at my club tonight.
Took TQ by a lap and A main win with the Team Wave RB50 in my TC5.
ESC performed excellently.
KennyClark is offline   Reply With Quote
Old 01-31-2009, 01:27 PM   #259
wide_mouth_frog's Avatar
Nice to see another brit using Team Wave speedo/motors, I have been using the RB30 just before it fully came out and loving it so much, so much better than the prev brushless system
Would have the RB50 by now but the posty decided to sign for it himself and loose the package!!!! Just waiting for Max to ship another out then I will be up and running again!!!
How are you finding the RB50? any settings you find better than others
Adam
Team Wave - absdesigns.co.uk - Selections RC
wide_mouth_frog is offline   Reply With Quote
Old 02-07-2009, 11:16 AM   #260
KennyClark's Avatar
This weekend is the Scottish Indoor Grand Prix. Stock /13.5 today. 19t /10.5 Sunday. Using Sweep 32 control tyre.
I finished 4th in the A main using the RB50 esc, a Novak 13.5 motor and Team Orion 3800 30C Lipo.
My settings on the RB50 were the following,
Neutral Brake - 3
Brake Force - 4
Turbo - 1 (On)
Time Shift - 2
Drive Profile - 7
Brake Profile - 6
Temp Cut - 5 (Off)
Lipo Cut - 3 (6.0V)
Motor was geared at 5.2 with advance set at full.
ESC was very good all day and car was quick.
Tomorrow I will be using the Team Wave 10.5 Linear motor and will post my results.
Muchmore
Team Durango
Old 02-08-2009, 11:32 AM   #261
KennyClark's Avatar
Today I finished 5th overall in A main after 3 legs using the RB50 and 10.5 Linear motor.
Geared at 5.67 with timing as factory setting.
Only settings I changed on the ESC from yesterday was the drive profile to setting 5 and the time shift set at 3.
Motor and ESC were both excellent.
Muchmore
Team Durango
Old 03-02-2009, 04:31 AM   #262
part-time racer's Avatar
Ran the Team Wave RB-50 over the weekend at the Much-More RugRacers series here in England. Was the first run with the speedo as I only received it in the post days before the event from the new UK agent (Much-More Racing), thanks Keith!
Started the day off with the speedo in supplied modes but with the Turbo switched on!
Car was very smooth and for me a little to smooth for 13.5 class so I increased the the timing function to 4 from 1 and also moved the Drive profile from the neutral setting of 5 up to a more aggressive 8.
With my previous Novak 13.5ss installed I would be geared at an fdr of 5.5 for the large in-door hall of 32x16m. This compared to the previous round running a GTB at 5.04fdr is a big help. Main reason being I find the motor stays colder through the run and with a reduced pinion size, I also feel this helps the motor spool up quicker.
Also nice to see Adam Smith over the weekend running the RB-50 in the 10.5 class.
I will add the profile later.
Regards
Richard.
part-time racer is offline   Reply With Quote
Old 03-02-2009, 05:58 AM   #263
Nice to see you Richard as well
As Richard said I was using the RB-50 with Team Wave 10.5... all I can say is wow... I was also starting on the "kit setup" for the speedo.. apart from the turbo on.... after some gearing changing and speaking to Richard, I but the profile onto 9.... what a difference... I came down one pinon.. putting me on to 5.72 overall.... although there were one or two drivers quicker at the end of the straight, I was on well used cells where as they had newbies..
The motor was quite warm, but that was without running a fan on the motor.. but well within the operational temperatures
Old 03-14-2009, 08:00 PM   #264
Any news regarding Hand-held programmer?
chemax_t is offline   Reply With Quote
Old 03-18-2009, 04:18 AM   #265
Well been using the RB-50 for some weeks now, and all I can say it is an amazing bit of kit!
I used it with a different motor for a test, and I could not believe the difference in the speed with the RB50 and the other motor... so much more top end and grunt than with my old system.
I put the turbo function on and profile to 9.... although this got a little hotter than normal, I found I could drop a pinion and still be as fast with less heat...
also put my drag brake to 3 rather than 0-1 as per normal...
Looking forward to the outdoors starting soon!!!
Old 03-18-2009, 08:01 AM   #266
KennyClark's Avatar
I ran a Novak 10.5 SS with the RB50 and the speed was immense.
Im really looking forward to this season starting. My first outdoor race meeting will be in April at the Much More GP track in Stonehaven.
Muchmore
Team Durango
Old 03-19-2009, 02:24 AM   #267
Any videos with cars running this? Interested in the Time boost in action!
RC-DriftNewb is offline   Reply With Quote
Old 03-19-2009, 02:38 AM   #268
The Turbo is just like what it says... if you put your car on the bench, and slowly increase the throttle you get to about 90%-95% max and its just this HUGE burst or power.....
Something you have to see to believe hehehehe
I can not recommend this speedo enough, and for the price, its well worth a go if your thinking of changing!
Old 03-24-2009, 12:20 PM   #269
tomjefferies's Avatar
Thumbs up
i have recently switched to run team wave speed controllers through much more uk, on sunday me and the uk team associated team went to cotswold track for a day testing. i ran the speedo first with the factory settings which was fast and felt really smooth to drive, i then changed the settings a bit. i.e more timing, turbo boost on, turned up brake force... VERY IMPRESSIVE i managed to run a lap 4 tenths off the track record on very old tires on a very cold day. the speedo never skipped a beat. even though i gave it a hard time to see what it would do it was fautless.
TOP RACING---MUCHMORE UK---TIR RACING---RCBEARINGS---CUSTOM BLITZ PAINTS
tomjefferies is offline   Reply With Quote
Old 03-26-2009, 09:06 PM   #270
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
gotta get one of these.
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
