New TEAM WAVE racing brushless system >
Old 02-19-2014, 07:51 AM
  #1921
Conrad's Avatar
Originally Posted by cyrrus View Post
hey max what about a esc for 1 cell
All of the current speedos do work on 1S as long as you keep the battery voltage above 3.5v but they will only supply battery voltage to the rest of the electrics for power. Their is a 1S booster in development along with a 1S firmware but as ever these things take time.
Conrad is offline
Old 02-23-2014, 03:45 PM
  #1922
After owning and running a RB50 in various vehicles for around 4 years, the case has finally let go. Can I buy a spare from anywhere?
Also, over the weekend the capacitor came off and vanished into the abyss. Can you recommend a replacement?
Cheers, Russ.
russmini is offline
Old 02-23-2014, 06:40 PM
  #1923
clint's Avatar
Trader Rating: 24 (100%+)
Cheers, Russ.
I have no clue about a replacement case but you can use any 16-25V capacitor with a capacity of 1500uF and up, I believe the stock TeamWave unit is 16V 1500uF
clint is offline
Old 05-10-2014, 12:56 PM
  #1924
Conrad's Avatar
Team Wave has a new product some of you might be interested in, a high power 1S lipo Voltage Booster, 6v @ 3A. Their is a demo video of the booster in operation on the tube.
+ YouTube Video
Conrad is offline
Old 05-10-2014, 11:12 PM
  #1925
+ YouTube Video
nice thanks for keeping us posted
cyrrus is offline
Old 05-13-2014, 11:20 PM
  #1926
Trader Rating: 27 (100%+)
Anyone had any trouble running these motors with Hobbywing v3/3.1 ESCs? I've got one that's just absolutely stubborn and will work when hooked up to a v2.1 ESC, but not when hooked up to a v3.
hyujmn is offline
Old 05-13-2014, 11:41 PM
  #1927
TEAMWAVE's Avatar
It will work with Hobbywing V3.1, can you see the light on the motor when hook up to V3.1?
TEAMWAVE is offline
Old 07-20-2014, 09:00 AM
  #1928
chasingthepack's Avatar
whats the sweet spot on temp for the 17.5 motors? ive had mine hit flashing red and solid red today in blinky,fdr was 3.25 to start with with 2 in the window,it wasnt fast enough and was flashing red,but after 30 secs with the fan still on it went to a solid green,so geared down to 3.17 and still not fast enough at the end of the straight,tried 0 in the window at 3.09 and after 5 mins its solid green but still not fast enough,so tried same fdr with 1 in the window and solid red,my car is nice and free no binding from bearings,the other top 5 cars seem to have all found the sweet spot at 3.12 with 69/42 i was running 38/39/40/65 ,first time out with this motor and and im impressed with the punch,im just struggling with top speed,getting caught towards the end of the straight,and about 12 cars run the same motors ,at our club they are the fastest motors out there,i was previously running an lrp x20 but couldnt get anywhere near to a car with a tw motor
any help appreciated
chasingthepack is offline
Old 07-20-2014, 11:29 AM
  #1929
hi max,i just checked my motor over and noticed it has alot of play in the rotor,at least 2mm,i took it apart and fitted a shock o ring and a small shim to take out the slop,shouldnt this have been done at the factory? to be able to move away from the sensor board by 2mm isnt right is it?,oh and any chance of a steel/alloy insert for the sensor screws instead of the plastic,ive stripped one side already
Old 07-23-2014, 03:34 AM
  #1930
bump
Old 07-25-2014, 07:12 AM
  #1931
Conrad's Avatar
You want the light to be on solid red at the end of the race, it should then change to flashing red after one minute. I can't advise on 17.5 blinky gearing as I have never run it.
Conrad is offline
