Old 12-12-2010, 02:29 PM   #1711
ATLASCOPCO's Avatar
Originally Posted by ATLASCOPCO View Post
Well up to date we are running the following settings,
1-8
2-5
3-4
4-2
5-1
6-4
7-4
8-4
9-1
I am hooked up to a novak ballistic 13.5 with +5 on the timing end bell ,gear ratio 5.427 and motor temp has not been over 120degF
It is verry quick and is as quick as anything out there it just my driving that lets me down.
I would like a bit more out of the corners so i tried a smaller pinion but it lost all of its shine so i went back .
Im going to try and ajust setting 2 step by step at my next meeting to see if this helps
Good luck guys
I have an update on my settings and it just gets better,
1-8
2-4
3-5
4-8
5-1
6-4
7-4
8-4
9-1
5deg advance on can novak ballistic 13.5 motor 5.427 temp 63degc.
I found it to be a bit smoother on corner exit but more mid power and more top end
this speedo rocks
Good luck guys
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 12-12-2010, 06:34 PM   #1712
hey guys
going to run my RBS with on rug with rubber.
any one got a good starting point for 17.5 with no turbo. thanks in advance. not going to worry about running it in myt 12 scale for now.
so i guess which program update you recommend and which settings
Andrew
cyrrus is offline   Reply With Quote
Old 12-16-2010, 08:04 PM   #1713
hey guys
any one out there might have a basic set up for a 17.5 non turbo. for TC for Rubber on carpet. or even a starting area. going to up date the rbs to the new software very soon.
thanks
Old 12-20-2010, 07:30 AM   #1714
jsr555's Avatar
Trader Rating: 17 (100%+)
Originally Posted by cyrrus View Post
hey guys
thanks
I have been running the latest software with 21.5 on
1 - 7 and 8
2 - 8 and 9
3 - 1
4 - 3
5 - 7
and seem to go fastest with the turbo off. We run on a rather small tight carpet track and I can not seem to make much differene with the turbo, so I leave it off. As long as you have a decent fan, I would be trying Page 1 on 7 and Page 2 on 7 and check the temps as you go (with turbo off) and crank it up if it isn't too hot.
Xray T4 & HPI/HB Pro 5 - Powered by Hobbywing
SQ: HPI RS Pro -HPI RS Pro 2 - HPI Pro 3 - HPI Pro ?? - HPI Pro 5
jsr555 is offline   Reply With Quote
Old 12-20-2010, 10:55 AM   #1715
Hey jsr.
thanks so much for some info. great going to try up dating my rb30 and give it a whirl.
Just a quick question what gear ration should i start with for a 17.5
now if i can only find some one whose had luck running single cell. with a 13.5
lol
Old 12-21-2010, 03:48 AM   #1716
Default RB50 or RB30?
Hi,
have some problem with updating my RBS. Max do not know where it is the problem... with ESC or with my programmer. No one runs TW speedos here in Lithuania so no way to test programmer...
So now I think to buy another TW ESC. Will find model to put it in but it have to support brushed motors as well (so no go for RBS). So question is which one I should buy? I do not run low turn motors, only 10.5T, 13.5T and 17.5T. But would like to have all the turbo and timing things... and firmware updates...
Audrius
www.rc-cars.lt - offroad in Lithuania
www.lasa.lt - onroad in Lithuania
audriusv is offline   Reply With Quote
Old 12-24-2010, 05:17 AM   #1717
jsr555's Avatar
Hey jsr.
I was running a FDR of 4.1 with my 21.5... But not sure if that was the best option. I think for 17.5 I was closer to 5'ish. Around 4.5 to 4.8....
Old 12-26-2010, 11:22 AM   #1718
hey Jsr. I will start with that, And thanks for the info.
Old 12-26-2010, 08:08 PM   #1719
jjfo80's Avatar
Hey I have been running a 17.5 from team wave and was very impressed. I had a fdr of around 4.3 with temps of 120-130 but running no timing on the tekin rs pro but had plenty of battery power which was the key and made it run nice and cool. I am running lrp 5900mah 50c batteries. So what ever the motor was asking of my system it was well up to the task and also running 12 gauge wet noodle instead of 14 gauge which most use. Every little bit helps dont just think gear ratio is the only thing to look at...
Good luck
Owner of Precise Fuels and RC and Podified Fuels
jjfo80 is offline   Reply With Quote
Old 12-31-2010, 10:58 AM   #1720
what is the turbo gain means?
ioxqq is offline   Reply With Quote
Old 12-31-2010, 03:40 PM   #1721
ATLASCOPCO's Avatar
Turbo gain ?
Could you tell me what page you are talking about
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 12-31-2010, 03:41 PM   #1722
ATLASCOPCO's Avatar
Hope this helps
1/ TimeShift: 1-9 (higher value = more timing)
2/ TimeShift Gain: 1-9 (higher value = faster timeshift ramp up to the maximum preset time shift defined at Page 1)
3/ Turbo: 1-9 (higher value = more turbo)
4/ Turbo ramp, 1-9
4-1: Ramp 1, Turbo delay 0.1s (higher ramp = faster turbo ramp up to the maximum turbo defined in Page 3)
4-2: Ramp 2, Turbo delay 0.1s
4-3: Ramp 3, Turbo delay 0.1s
4-4: Ramp 1, Turbo delay 0.2s
4-5: Ramp 2, Turbo delay 0.2s
4-6: Ramp 3, Turbo delay 0.2s
4-7: Ramp 1, Turbo delay 0.3s
4-8: Ramp 2, Turbo delay 0.3s
4-9: Ramp 3, Turbo delay 0.3s
5/ Drive profile, 1-9 (higher value = faster throttle response)
6/ Neutral brake, 1-9 (1=OFF)
7/ Temp Cut, 1-5 (5=OFF)
8/ LiPo cut, 1-4 (4=OFF)
9/ Motor, 1-2 (1=Super stock, 2=stock)
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 12-31-2010, 04:57 PM   #1723
oh, i think i asked what is Turbo ramp? what does it mean?
Old 01-01-2011, 03:03 AM   #1724
ATLASCOPCO's Avatar
It`s the speed that the turbo is applied
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 01-01-2011, 07:46 PM   #1725
If my motor is over heat, should I lower timeshift or turbo?
Timeshift is now 7 and turbo 5
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
