Old 12-01-2010, 06:01 AM   #1696
Turbo is activated when you hit full throttle. It is not RPM related.
Jason
SilverScooby is offline   Reply With Quote
Old 12-01-2010, 07:10 AM   #1697
wide_mouth_frog's Avatar
I thought is was when RPM had hit max, not your stick/trigger?
oh well hehehe
Where abouts do you race chap?
Jason
Team Wave - absdesigns.co.uk - Selections RC
wide_mouth_frog is offline   Reply With Quote
Old 12-01-2010, 11:44 AM   #1698
I am lucky enough to race at Maritime Raceway
Top venue with some really good drivers
Old 12-02-2010, 01:12 AM   #1699
I have raced there in the past.. I know Bryan Loynes
What motor are you currently running?
Old 12-02-2010, 07:01 AM   #1700
I normally run a 10.5t Team Wave motor, been running a 13.5t Team Wave motor for the past 6 weeks. Now going back to the 10.5t.
Old 12-02-2010, 01:08 PM   #1701
jsr555's Avatar
Trader Rating: 17 (100%+)
Originally Posted by wide_mouth_frog View Post
Hi there jsr555.... nice to see some more people shareing their settings and thoughts!!
I have been struggling to find the sweetspot on the 21.5 at the moment as I also felt the care to be guttless with the turbo on. I am thinking that the motor was not reving enough to notice it.
As prev mentioned the turbo 0.1 etc comes in when your motor hits full RPM so maybe your car was not hitting it???
I also found it gained a lot of heat till I turned my settings down and geared up. Next week I might try going up one more pinion and seeing if that effects things, I am guessing more heat, but till you try these things you really never know. I have found the Time Shift Gain makes a BIG difference with the heat, so always worth turning that down a little before much else if temp is a problem.
What was your driver profile set on? 5?? I am currently on 2 as I found that also gained a fair amount of heat when I was struggling getting my temps down
All good fun isnt it!!
Drive profile ended up on 7, when running both non-turbo and turbo. Might have to play with the gearing to see if I can get the turbo to be benificial.
No point being fsatest on the straight, if I loose it all on the infield.
Are you meant to lower your time shift, when running more turbo... or treat turbo as a bonus with high timeshift... temp's dependant obviously!
Xray T4 & HPI/HB Pro 5 - Powered by Hobbywing
SQ: HPI RS Pro -HPI RS Pro 2 - HPI Pro 3 - HPI Pro ?? - HPI Pro 5
jsr555 is offline   Reply With Quote
Old 12-02-2010, 02:52 PM   #1702
Well time shift is advancing the motor, the more you advance it, as a rule, the the faster it will be but the hotter your motor will get.
I turned the profile down and this lost a lot of heat...
I am coming over to Aus on the 11th... see you then hehehe
Old 12-03-2010, 02:59 PM   #1703
ATLASCOPCO's Avatar
Where is Max TEAMWAVE we need you here to clarifie things for us. come on get typeing
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 12-03-2010, 10:30 PM   #1704
TEAMWAVE's Avatar
Hi All,
In the previous firmware (V2.02g), Turbo will kick-in when reaching the preset RPM, no matter where is the throttle position.
In the latest firmware (2.1x), turbo will kick-in after the preset delay(0.1s-0.3s) when full throttle on the transmitter is triggered.
TEAMWAVE is offline   Reply With Quote
Old 12-04-2010, 12:43 AM   #1705
Hi,
wasnīt able to test both software versions, but isnīt the rpm related turbo the better option in theory?
Lutz is offline   Reply With Quote
Old 12-04-2010, 06:57 AM   #1706
ATLASCOPCO's Avatar
Originally Posted by Lutz View Post
Hi,
Why ?
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 12-04-2010, 06:57 AM   #1707
ATLASCOPCO's Avatar
Originally Posted by TEAMWAVE View Post
Hi All,
Thanks Max
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 12-04-2010, 08:08 AM   #1708
TEAMWAVE's Avatar
Lutz,
Yes, kick-in at preset rpm is a very good idea, that's why we have it in V2.02g. The problem is it is hard to set for whole range of motor, not to mention different brands. At the same time, we found motor temperature will be higher if turbo was controlled by rpm.
Old 12-05-2010, 04:59 AM   #1709
ah ok.
And what about a turbo that kicks in at a preset rpm but only after a preset time of full throttle? Like a combination of the last two versions
Old 12-05-2010, 11:41 AM   #1710
Hey guys
has anyone have any luck running on a single cell. I have my rbs and rb30 sitting in my tool box. and would love to run them again. i have a race comming up were i would love to place it my WGT car. so if any one have a great and work good set up for a wgt
I'm also planning on running TC on carpet but it it also with the new rules for 17.5 were no turbo is allowed. so again any set up tips of this too would be great.
Thanks.
cyrrus is offline   Reply With Quote
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
