Old 08-12-2010, 07:20 AM   #1516
Gary_UK's Avatar
This may be a good time to ask for a new CARD layout at the same time you bring out new firmware as mine is totally out of date so if you bring out firmware v5.0 then a lay out card with v5.0 on it because trust me this is getting so confusing
Originally Posted by TEAMWAVE View Post
The handheld programmer can recognize your ESC firmware and show all tunable parameter.
at the moment I have ver1.3 for my RB30's but this is the card ?
So if i put the RBS firmware on it its deffo wrong
And as of this moment I have ordered an RBS So has any one got the RBS v1.0 pit card info that has reverse on it
Many
Thanks Gazza
RB30 2s lipo 13.5 brushless firmware v1.3 3Racing F1
RBS 1s Lipo 13.5 with booster firmware v1.0 Mardave with reverse
Gary_UK is offline   Reply With Quote
Old 08-12-2010, 11:38 AM   #1517
Johnny Wishbone's Avatar
That is the wrong card for the most current update.
If you go back several pages someone posted a pdf with the proper layout for the card. Sorry you'll have to page back as I can't remember how far back it is or which post number, but it is back there.
Old 08-12-2010, 03:43 PM   #1518
Gary_UK's Avatar
Thats what I mean we want card updates to go with the firmware
I really would like to see the forward and reverse on the new update please along with 1s Lipo cut off
Old 08-16-2010, 01:27 PM   #1519
Still Confused! I`ve downloaded V202 and then when I load the firmware it says the filename is V1.03? What am I doing wrong?
benTC5 is offline   Reply With Quote
Old 08-16-2010, 05:51 PM   #1520
Gary_UK's Avatar
When you say v1.03 Ben where is that ?
Old 08-18-2010, 04:17 AM   #1521
Gary_UK's Avatar
My New RBS has arrived . . . im a happy bunny
Right its loaded with RBS 1.0 firmware so it has the reverse in it
Now I have seen all the post re gearing 4.5 to 5.0 FDR ( final drive ratio )
My question is. In a car with a ratio 1.1 no gear box etc Mardave / 1/12th with tyre size of 53mm and a 13.5 motor and 1S Lipo what should the gearing be ( dont want to blow it up )
Thanks Guys
Old 08-23-2010, 06:50 AM   #1522
Gary_UK's Avatar
So where has every one gone
Old 08-23-2010, 09:25 AM   #1523
Hi Team Wave people,
when are you thinking to relise the new firmware?
Ciao
Max
mtaddei is offline   Reply With Quote
Old 08-23-2010, 02:13 PM   #1524
cannon's Avatar
Trader Rating: 35 (100%+)
Have a look at their sigs. They have changed brand ESC's
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 08-23-2010, 02:33 PM   #1525
So where has every one gone?
Busy with the RB50 and 2.02g Software. Finally got it right. Gary that sheet you posted is wrong !!! page 9 is superstock "1" and sportsman "2" i.e the added feutures are switched off in sportsman mode. Now if someone can help us with the different profiles. My wave 13.5 is rated at 3000 KV so very little to play with on a tight track with about 12m straight. Roll out at 32mm/rev. Temps OK 50 deg Any Help?
Old 08-23-2010, 02:44 PM   #1526
Gary_UK's Avatar
no its correct
Thats what I want . . . When I bought my ESC it had forward and reverse now with the latest firmware it has not
So the updates are no good for quite a few of us . . we WANT reverse
and for us 1cell lipo the cut off is needed as well ie 3.2 / 3.1 /off
It would be nice if they release two 2.02g stock and reverse
and they call it 2.02S and 2.02R one has stock / sportsman and the other forward / Reverse
Old 08-23-2010, 02:53 PM   #1527
Gary_UK's Avatar
Well with all the posts and e-mails I have sent I would have thought some one would be kind enough and replied to help a customer out
Cannon. . . you may be right if they treat people like this Im not a happy bunny at the moment.
I would have thought a reply to my questions would be nice tho
Old 08-23-2010, 03:29 PM   #1528
ark
I left team wave because they wanted me to pay $74US for a near new RB50speedy when mine caught on fire from normal use :-(
ark is offline   Reply With Quote
Old 08-23-2010, 11:15 PM   #1529
I use a TW 13.5 motor on a RB50 running 2.02G, at my local track (Meyersdal - MMRC)
When I first started setting it up, I used the settings posted here on the forum when the 2.02G software first was released.
While the car was fast, I found it lacked kick out of the corner.
Since then I have dropped my rollout to 25.4 (I use to run a rollout in the mid thirty's) and now make use of the following settings.....
Time Shift = 7
Gain = 2
Turbo = 7
Kick In = 6
Drive Profile = 5
Now the car is just as fast (if not faster) down the straight and it has awesome kick out of the corner.
Temps when I come off after 5-6 min of running are in the 60 degree celsius.
In a nutshell, I find that running a lower rollout with higher turbo and drive profile settings, makes for a faster car on my local track.
The settings and rollout I use, are very similar to what the fast guys are using with their Speed Passions.
SeanV is offline   Reply With Quote
Old 08-23-2010, 11:33 PM   #1530
Since then I have dropped my rollout to 25.4 (I use to run a rollout in the mid thirty) and make use of the following settings.....
Time Shift = 7
Gain = 2
Turbo = 7
Kick In = 6
Drive Profile = 5
This is.correct, lower FDR's usually offer more power but eventually more heat. The reverse was removed from the software during development as every track I have ever been too dose not allow the use of reverse. If you get the option to switch reverse back on then you lose another function.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Novak Racing Brushless System (3.5) andy85 Electric On-Road 2 07-12-2007 07:24 AM
Novak 3.5R Brushless Racing System TRiN Australia For Sale/Trade 2 04-02-2007 04:56 AM
Novak 3.5R Brushless Racing System Wolverini R/C Items: For Sale/Trade 2 03-04-2007 03:28 PM
tekin brushless racing system??? streetracer745 Electric Off-Road 7 01-16-2007 01:46 PM
Team Wave - Lightning Discharge / equalizing system TEAMWAVE Electric On-Road 271 11-19-2006 08:06 PM
