Old 03-27-2008, 05:43 PM   #1
Default HPI sprint 2 braking problem
Hi,
I've just purchased an HPI sprint 2 sport RTR and noticed that it is not braking at all! However, when I lift the car up in the air and apply brake, it does seem to work... (motor does its braking sound and the wheels stop) the problem is when the car is running, no braking power at all, it just freewheels. Reverse is working.
Could it be the ESC? its a HPI SC-15
the radio?
or maybe the belts?
Anyone else had similar trouble?
I've sent an email to HPI but since their support time is several days away I just thought I'd ask here
Rufus2000 is offline   Reply With Quote
Old 03-27-2008, 05:46 PM   #2
KHoff7's Avatar
You should try to reset the ESC.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 03-27-2008, 05:46 PM   #3
beta bob's Avatar
Trader Rating: 2 (75%+)
The ESC is set up to were when you plug the battery in the first action you do with the trigger is the throttle and then you have to hit the trigger the oppposite way so the sc knows what the brakes are. So when you first turn on the ESC hit the throttle all the way and then go to neutral and then apply full brakes and then the brakes should work.
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 03-27-2008, 05:48 PM   #4
you've tested it in the air, now test it on the ground. full throttle and apply brakes at a certain point until it stops. then full throttle and let go of the throttle and see if it stops at the same point that you used your brakes. did you roll past the stopping point?
bionictony is offline   Reply With Quote
Old 03-27-2008, 06:29 PM   #5
Thanks for the quick reply! I thought this would do it, but it does not. Maybe there is another way to recalibrate or reset this ESC?
I've tried it on the ground and if there is any braking you can hardly notice it... its like if the braking power was set at 5% (you only notice it in the air) on the ground its useless.
Try this... I have tried applying a bit of throttle, then full brakes while on the ground (then I wait for it to freewheel and stop) then I manually give the car a push (while the brake is on) and the car offers no resistance, it just moves... I bet this is not normal right?
Old 03-28-2008, 07:13 AM   #6
beta bob's Avatar
Do you have the manual still for the ESC???
Old 03-31-2008, 06:40 PM   #7
No, it just came with the manual for the car.
Well I sent an email some days ago and still no reply from HPI support...
I have noticed that on pavement going full speed the car does brake but its not a strong brake (barely usable if there's trouble ahead), wonder if this has to do anything with adjusting the belts. In my offroad electrics I'm used to having a very strong brake...
Old 08-26-2009, 12:15 AM   #8
Monsta's Avatar
Hi, did you sort this issue out? im having the same trouble
Monsta is offline   Reply With Quote
Old 09-08-2009, 03:20 AM   #9
Monsta's Avatar
i know its an old thread but anyone?
I wanna stop
Problem with Mamba braking or something? Paul Whalen Electric Off-Road 19 02-08-2008 06:21 AM
MRX-3 Braking help? JInaba Nitro On-Road 7 04-23-2007 01:35 PM
Braking... Nautilian Electric On-Road 24 11-13-2006 12:45 PM
ABS braking stonely0 Singapore R/C Racers 15 10-03-2006 04:28 AM
Braking Problem (Twister2 and Helios) acutts Electric On-Road 10 05-31-2005 11:56 AM
