Old 07-17-2003, 01:25 AM   #1
Cole Trickle's Avatar
Default Modified timing
Hi there
I just bought a used modified, an LRP DTM 18x4. I teared it apart and did a comm cut and cleaning. But since it's my first mod., I forgot to mark the can/endbell.
How do I get the timing right?
I've been told to assemble it, put on some batts, and then turn the endbell to max RPM. Afterwards I should turn the endbell sligthly back, to ensure some torque. Preferable I should turn the endbell in the same direction as the armature turns, then go a little backwards. Is this the right procedure, when I aint got access to a dyno?
Edit: The big problem is, this motor aint got a factory mark as a default setting.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 07-17-2003, 02:49 AM   #2
Are you 100% sure it doesn't have zero setting marked on the can? Should look like a filed slot on the end of the can (outside).
Anyway, no worry. The zero line of the can is between the magnets (and between the mounting screws). The zero point on the endbell is where the mounting screws are. Align those 2 and you have zero timing. To get some timing you have to turn the endbell opposite to the rotating direction of armature. 1 mm on the can is about 3 degrees. Good starting point is 4-6 mm (12-18 degrees), but you can go up to 8-10 mm (24-30 degrees) to get more power (the motor will burn up faster though). Sensible maximum you should use depends on the motor and gearing used.
You should NEVER turn the endbell to the same direction that the arm turns, always against the rotation.
olev is offline   Reply With Quote
Old 07-17-2003, 03:31 AM   #3
fatdoggy's Avatar
R/C Tech Charter Subscriber
I think cole means that he dosn't know what timing it came with from the factory and so dosn't know what to set it at. I'm not sure if this will help at all but this picture shows what I think is your motor and it gives you a good view of the timing(what I presume is stock timing).
fatdoggy is offline   Reply With Quote
Old 07-17-2003, 06:20 AM   #4
Thanks guys.
Especially fatdoggys message is usefull. I have to take an extra look at my motor - even though it has another label, than this picture show.
Olev, your suggestion is my fall back, if the label is damaged or something. I think I'll post this info on our club-site, since several guys at our club didnt know.
Difference b/tween ESC timing and timing on motor? Loverc Electric On-Road 8 04-11-2008 05:45 PM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 09:40 PM
timing on a modified motor? whats it do? streetracer745 Electric Off-Road 4 07-14-2007 07:05 PM
any article on modified timing tc3 racer sc Electric On-Road 3 07-05-2004 11:14 AM
Modified Motor Timing Mitch Australian Racing 3 09-03-2003 06:10 AM
