Old 03-27-2008, 12:32 AM   #1
FX Racing's Avatar
Default Xray T1 Problem
My xray T1 left rear wheel has locked up for some unkown reason and it looks like it might be the rear diff but it still spins freely. Has anyone encounted this problem before? any information would be great thanks.
FX Racing is offline   Reply With Quote
Old 03-27-2008, 04:03 AM   #2
part-time racer's Avatar
Have the bearings in the hub been checked?
If the diff is freely rotating then what else could there be?
part-time racer is offline   Reply With Quote
Old 03-27-2008, 04:33 AM   #3
Trader Rating: 22 (100%+)
Default T1
I agree if the diff rotates freely it should only be the wheel bearings.
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 03-27-2008, 05:10 AM   #4
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
While you are at it, check the drive shaft coupling, 2x10mm pin that connecting the drive shaft and drive axle together.
The 2x10mm pin might becoming loose. Also check the screw that go into the upright if you using a wrong size screw it may go all the way through the upright and touching the drive axle or the bearing.
komkit is offline   Reply With Quote
Old 03-27-2008, 09:32 PM   #5
FX Racing's Avatar
Thanks for the information ive checked the bearings and are worn a bit but the diff still spins so im going to replace the bearings as i thought it might of been the problem.
Old 03-27-2008, 10:29 PM   #6
TeamFast's Avatar
could be a lose or broken drive pin.
Why be a member of TEAM TERRIBLES when you me a member of TEAM Fast
TeamFast is offline   Reply With Quote
XRAY M18T PROBLEM MaTt 93 Micro and Mini Scales 2 01-24-2008 10:16 PM
