Old 03-25-2008, 06:36 AM   #1
Jamesalex's Avatar
Default Lipos whats needed
ok stupid question time
I have not paid much attention to lipos but am looking into it now for my next set of batteries so
What appears what is the best lipo so far and what is needed,
charger
equalizer
dis charger
balancer
cut off to add to speedcontrol
Jamesalex is offline   Reply With Quote
Old 03-25-2008, 08:58 AM   #2
Moderator
pc9840's Avatar
Send a message via ICQ to pc9840 Send a message via AIM to pc9840 Send a message via Yahoo to pc9840
As for the "best" LiPo out I don't know if I can answer that but some of the most common LiPo's out with great history are the Team Orions.
Your going to need a charger capable of LiPo charging.
No discharger is needed, unless you plan on balance discharging your cells, which not many car guys are doing with thier LiPo's because its not totally needed.
An equalizer in LiPo terms is a "balancer" There are chargers out thier with this feature and then there are stand-alone units. This is a good investment, however it is not really needed with the orion LiPo's, at least I have never needed to balance, the LiPo's have stayed .01-.02 within each other.
A LiPo cut-off is needed, you could go without one as long as you only ran for a couple minutes and made sure you were not letting your LiPo get below its recommended cut-off voltage. But its worth it just to get one, or get an ESC with it built in. Pretty much any newer high end esc.
Hope this helps you with your next purchase.
[email protected] <><
"The minimum wouldn't be the minimum if the minimum wasn't good enough"
pc9840 is offline   Reply With Quote
Old 03-26-2008, 04:51 PM   #3
t9dragon's Avatar
Send a message via ICQ to t9dragon Send a message via AIM to t9dragon Send a message via MSN to t9dragon Send a message via Yahoo to t9dragon
charger
equalizer
dis charger
balancer
charger = You'll want a "GOOD" lipo charger
equalizer = N/A
dis charger = You don't need a discharger for Lipos.....
balancer = You will need to keep the cells in the battery equally balanced.
cut off to add to speedcontrol = If you are using a brushed esc it is very highly recommended that you also use a low voltage cutoff. If you don't you can cause serious harm to the battery or yourself.
t9dragon is offline   Reply With Quote
Old 03-26-2008, 10:34 PM   #4
Send a message via MSN to ammo
You'll want a lipo charger + lipo balancer.
It used to be seperate items, but now there are some manufacturers who incorporate them into a single unit for convenience as well as price reduction.
This is one of them, a good one in fact. Small and blue backlit
http://shop.radiocontrol-sports.com/...productId=1291
Or they even come in AC/DC version which you can just plug direct to the wall. Saves you on hooking up the external power supply and tons of wires on the put table.
http://shop.radiocontrol-sports.com/...productId=1292
ammo is offline   Reply With Quote
Old 03-26-2008, 11:36 PM   #5
Maxamps for bashing and for racing, Orion seems to be popular.
charger
you can get away with an basic eflite charger for 30 bucks. make sure the charger comes with a CC/CV mode for lipos if you pick another one.
equalizer
Not needed
dis charger
Not needed.
balancer
A good one is an Astro Blinky balancer. serves me well
Novak sells a LVC which I hear good things about. http://www.teamnovak.com/products/li...ule/index.html
Another one you can use is this one. http://www.espritmodel.com/index.asp...OD&ProdID=4383
The latter is designed for airplanes primarily but it can be used in a car. It would act as if the batteries suddenly dumped.
Sabin is offline   Reply With Quote
NEEDED-RC CRAWLER FORUM-NEEDED countryboy4life R/C Tech Site Forum 9 03-11-2010 08:07 PM
Need [email protected][email protected][email protected][email protected] kikcaffine R/C Items: Wanted to Buy 3 08-24-2008 12:16 PM
WTB: 2s or 3s lipos InsaneRC R/C Items: Wanted to Buy 4 05-18-2008 08:08 PM
whats is a good charger to charge 4200mah batt & 1-3 lipos asc0989 Radio and Electronics 0 10-21-2007 10:15 PM
Whats needed to make race spec b4 rtr?? TH691 Electric Off-Road 2 04-11-2007 09:55 PM
