nimh is a nimh is a nimh?? >
Old 07-14-2003, 11:25 PM
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Default nimh is a nimh is a nimh??
So I'm charging a pack of Ultra Metals yesterday and one of the cells vents Can I use a Stock Nickel Metal cell to replace the vented cell or does it have to be another Ultra? THANKS
minicooper is offline
Old 07-15-2003, 12:19 AM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
You should be able to do it without problems. You might not get the performance you had with the origional pack though, just try to get the #'s on the new cell as close to the old one as you can.
Randy Caster is offline
Old 07-15-2003, 01:42 AM
NO, that won't work. one of my friends tried doing something similar and that pack blew up 2 chargers, it's not a good idea. i can't prove that it won't work all i have is that evidence if you think it's a coincidence, go ahead and try it but i wouldn't.
if someone else (like an electrician or whatever) knows for sure that it would work, please correct me, i speak from experience only
Trippin Freddy is offline
Old 07-15-2003, 03:19 AM
Cole Trickle's Avatar
Chances for those cells perform equal, are very low. The result is that at least one cell is under heavy stress, since it dump before the others. And then the pack will die very fast.....
Replace with a equivalent cell, then you'll get a much better result.
Cole Trickle is offline
Old 07-15-2003, 02:30 PM
minicooper's Avatar
Thanks for the replies guys. Looks like I have a 4 cell pack for my lathe
