Old 07-15-2003, 04:20 PM   #16
Thanks a lot, if you have other pictures like that, I take!!!!!!!!
Thanks again,
Hugo
Hugo is offline   Reply With Quote
Old 07-15-2003, 10:55 PM   #17
Neil Rabara's Avatar
Looks like "Barry's Car" has two fans. I see Barry's car all the time at Socal Raceway, it doesn't look like that one. It's most likely a handout car from AE for their factory drivers.
Neil Rabara is offline   Reply With Quote
Old 07-15-2003, 11:25 PM   #18
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Originally posted by cjohnson
Hugo,
Here is a pic of Barry Baker's car. It was taken by kilruf at the nats.
Hmmm... is it me, or are those dogbones waaaay bigger than any I've ever had on a TC3? And there are diff outdrives to match..?
BigDogRacing is offline   Reply With Quote
Old 07-15-2003, 11:30 PM   #19
Matt Howard's Avatar
I believe IRS makes those bigger CVD's and the aluminum diff halves
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-16-2003, 01:48 AM   #20
highwayman's Avatar
Hugo,
chris
i noticed all his tires had grooves in the middle... is that normal wear? or was that done on purpose?
highwayman is offline   Reply With Quote
Old 07-16-2003, 06:05 AM   #21
kt racing's Avatar
Send a message via AIM to kt racing
Sometimes that is how the takeoff tires wear. Every set you get do weird shit like that. But yea that is normal for a takeoff to do that.
kt racing is offline   Reply With Quote
Old 07-16-2003, 06:07 AM   #22
kt racing's Avatar
Most of the AE guys are sponsored by IRS. Those were IRS dogs and IRS out drives. Just about every AE guy out there was using them. Including baker, Mike D, and Scotty E. And that was Bakers car I was with Kilruf there.
Old 07-16-2003, 06:11 AM   #23
kt racing's Avatar
RCInfinity,
Keep in mind during the nats it was in the high 90's and 100 percent humidity. not like out in cali. Also the track averaged about 145 degrees while we were there. So it was alot hotter there than socal.
Old 07-16-2003, 10:49 AM   #24
i was just wondering if this would reduce the power running to the servo and motor? i dont think the motor would loose power but would the servo possibly.
ernieball is offline   Reply With Quote
Old 07-16-2003, 11:21 AM   #25
Default Fans
Hi guys
The reason Barry Baker is runing fans all of a sudden is because of the Krypton motor. With the laydown brush you generate more heat and then after a few mins the motor goes off, so by keeping it cool he can prevent it the arm from getting to hot and going off. The way i got round it over here in the UK is to mill out the hole bigger under where the motor sits and try not to run as many heat sinks so the warm air can escape. I evan use the motor clamp of the racer kit because the heat sink on that is much smaller than any of the others.
Hope this info helps!!!
TC3 RULES!!!!!
simo is offline   Reply With Quote
Old 07-16-2003, 12:33 PM   #26
Send a message via ICQ to Ragman
The groove in the middle of his tyre is probably where he's dremeled it. It is quite common practice over here with Take Off tyres. You will notice on a new set of tyres the is a very small ridge in the middle of the tyre, this is where the 2 halfs of the mould meet. When you first run the tyres this ridge can make the car feels very squirmy, a quick Dremel session cures this.
HTH
//Stu
Ragman is offline   Reply With Quote
Old 07-16-2003, 04:19 PM   #27
JimmyMac's Avatar
Yes Barry B ran 2 fans.. but Mark P only ran one. The pic of his car is posted on the Roar Nats Forum. David Jun made a nice little lexan air scoop for his mini fan. And there were some other nice air scoops out there as well. I've seen this done as asphalt and carpet. Some even point fans at their ESC! Especially if you run a Novak GT7.....
JimmyMac is online now   Reply With Quote
Old 07-16-2003, 05:01 PM   #28
Where is the ROAR Nats forum?
Old 07-16-2003, 05:14 PM   #29
JimmyMac's Avatar
http://www.rctech.net/forum/attachme...&postid=416844 There is Marks Winning car.
Old 07-16-2003, 05:22 PM   #30
Got it.
Bob Barry duckman996 Buyer/Seller dispute and Feedback discussion forum 1 08-30-2006 10:26 PM
Anybody else pissed at Barry? Truggy1 Chat Lounge 54 06-07-2006 09:40 PM
Barry Bakers TC3 TCRacerPro Electric On-Road 13 07-19-2004 10:18 PM
Barry Baker Q&A Jon Carlson Nitro On-Road 90 03-05-2003 04:21 PM
Barry Baker's Spur Gear, as seen in RC Car Action... GKHTC3 Electric On-Road 6 11-09-2002 12:48 PM
