Old 07-05-2008, 08:15 PM   #346
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Well I bought a Hacker 13.5 today
This thing is sick, matches my cyclone perfect, and is really quiet
Where should I gear this thing? Im running on a pretty big track, im thinking just run the same gear I did with my Novak? At 4.6?
thanks
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-05-2008, 08:24 PM   #347
Trader Rating: 38 (100%+)
thanks
I think people usually gear the Novak motors a little more. I would drop down a couple of teeth and check temp and go from there.
or8ital is offline   Reply With Quote
Old 07-05-2008, 08:27 PM   #348
I was under geared with my Novak though, people at Reedy were gearing them at like 4.4-4.2
But I will watch temps close, cant afford to burn it up lol
Old 07-06-2008, 02:37 AM   #349
peetiewonder's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to peetiewonder
how do the hacker e40 series motors line up to say the speed passion/ fiegao/ orion etc... brushless motors?
Got a tax policy that'll break ya neck BYAAAAAAH!
Buy my stuff.
peetiewonder is offline   Reply With Quote
Old 07-06-2008, 08:08 AM   #350
adamge's Avatar
In front of them on the grid ;>
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 07-06-2008, 08:03 PM   #351
denver's Avatar
Originally Posted by Grenade10 View Post
Denver, something else to check is the bearings in the car. My Vintage Trans-Am with the 17.5 has started to show more Temp and slowed down. Pulled all the bearings in the car and found two that were crap!!
Thanks for the advice. At first I was convinced thats what it was.. but it rolls like a champ. I even went through and cleaned/replaced all bearings. Also tested my Novak 10.5 to rule out speedo and drivetrain and it was no problem. I order a couple new rotors last week and a backup 13.5 so once they get here I will know for sure.
"We have upped our standards so up yours"
denver is offline   Reply With Quote
Old 07-06-2008, 11:13 PM   #352
Kajman's Avatar
Quiet & fast, ubelivable, but even motors with paper more KV and more power are weaker and slower, really great motors. Only problem that magnets fall down sometimes
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 07-08-2008, 11:05 AM   #353
denver's Avatar
Received the new rotors yesterday. So I went to the track to test. Same thing. Didn't help a bit still hot (210) and sluggish. I guess now I have to send them in for repair? What will that cost? Maybe it is time to junk them and get some now motors before I spend $100 each on fixing these.
Also again to confirm I stuck my Novac 17.5 in with same gearing and came off at 130. So I know it is the motor.
Old 07-08-2008, 11:44 AM   #354
m3ndo5a's Avatar
I know the losi and the Hacker are not the same motor,,,if that correct. But notice in the spec's Hacker states very low cogging and Losi states no cogging... Would this effect the temperature and perfomance?
m3ndo5a is offline   Reply With Quote
Old 07-08-2008, 12:02 PM   #355
Trader Rating: 16 (94%+)
You obviously haven't seen my pics in this post comparing Losi and Hacker.
http://www.rctech.net/forum/showthre...44#post4447344
All your reading is marketing. If the marketing material between the two were 100% identical, they would seem too much alike.
kn7671 is offline   Reply With Quote
Old 07-08-2008, 12:03 PM   #356
Have you confirmed that the timing ring did not move at all, therefore advancing the timing? A new rotor should have cured the problem if it was a weakened magnet. Otherwise, I would suspect timing or bearings in the motor.
Old 07-08-2008, 12:35 PM   #357
denver's Avatar
I checked the bearings and cleaned and lubed them. They seem good. (from what I can see) So you think my timing ring may have advanced. So to check/fix I need to loosen the three screws on the back of the motor and then try and rotate the back of the motor. < This correct?
Old 07-08-2008, 01:25 PM   #358
Yea, but mark where the timing is now. Next, loosen the three screws, then gently turn the timing ring each direction (shouldn't move more than about 1/4" in either direction) and mark the full advanced and retarted positions, then compare to where timing is currently. I think most BL motors are 4-deg advanced from the factory, so it should be turned slightly further clockwise.
Old 07-08-2008, 03:11 PM   #359
denver's Avatar
Ok it looks like it was about 1/2 way so I moved it back about 1 so I will go to the track and test and post in the morning with my results. If it is still not right I will play with the timing at the track and see what I come up with. Thanks for the help. I still love my Hacker motors over all others.
Old 07-08-2008, 06:39 PM   #360
Send a message via AIM to kyle478
Denver,
What ESC are you using?
Hacker Brushless USA www.hackerbrushless.com
Aero-Model www.aero-model.com
kyle478 is offline   Reply With Quote
Hacker Brushless 17.5 and 13.5 motors for sale Bertetto R/C Items: For Sale/Trade 1 08-19-2008 04:43 PM
13.5/17.5 Brushless motors - Hacker, Losi, Full Throttle BBSpence R/C Items: For Sale/Trade 6 08-13-2008 10:19 AM
--Hacker brushless motors! For E-Revo or large scale! pb4ugo R/C Items: For Sale/Trade 7 07-21-2008 06:26 PM
X-Ray 008 US, Much More, Hacker and Orion Brushless Motors RBLove R/C Items: For Sale/Trade 13 05-06-2008 06:27 PM
Hacker Brushless Motors GundamWZero Electric On-Road 5 08-11-2004 04:21 PM
