Old 06-25-2008, 08:08 AM   #331
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
Originally Posted by or8ital View Post
Well he seems to get a lot of 1 lap runs in. I supposed if you can encourage him to gun it the first lap and hope he breaks that might be the best strategy. If he ever makes it past that first lap then you are usually in trouble. I hope to be there on the 5th as well. Not sure if Im going to run Pro Stock or 10.5. Id like to try to avoid the 2 (apparently) top 10 drivers in the nation in that class.
i know where you noramlly race... so running 13.5 is going to be hard for you be the guys here don't want to run rubber tires for some reason...hint the reason why 10.5 is strickly a rubber tire class
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 06-25-2008, 08:22 PM   #332
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Congrats to Kyle and Hacker on their 12th scale NC! The car and driver looked great on the track all weekend. Power didnt look like an issue at all either!
Thanks for the motors this weekend Kyle. Wish I would have tried the 17.5 a little earlier in the week to get it right. I'll be playing with it in the next few weeks and let you know how it goes.
Anyone looking to try Hacker BL motors they are great products and have awesome customer support as well!
EA
EAMotorsports is offline   Reply With Quote
Old 06-25-2008, 08:26 PM   #333
RBLove's Avatar
Trader Rating: 72 (100%+)
Hacker 17.5 w/nimh's made a great combo at the Nats.
I second Eric's comments. Kyle won 12th scale, but he also placed third in super stock tc. Congrats Kyle and thanks for the support.....
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 06-25-2008, 11:06 PM   #334
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Kyle- nice meeting you and Jason E at the Nats. Great job on the Championship and other finishes for both of you.
I stopped by Dave's house and dropped off the motor you gave him from your 12th scale. I handed it to him and he said "what's this for?" I told him KB said "his junk looked so bad, maybe if he has a decent motor, he can build a new car around it!!" LMAO
Not sure if he'll have time to get on rctech, but in case he doesn't, he said thanks a million- you guys are definately a class act.
Oh yea, and next time your "big hair" is blocking the whole sweeper you gotta squat down!!!!
BigDogRacing is offline   Reply With Quote
Old 06-26-2008, 12:15 PM   #335
denver's Avatar
I have been running the Hacker 13.5 and 17.5 since Nats in March and love them. But over the last month both motors with the same gearing as before are coming off at 210 degrees. No lack in performance just super hot. I tried gearing back from (17.5 -3.56 FDR) to (17.5 - 4.2 FDR) and still was in the 170s and way way slower. Wondering if any one else is seeing the same thing? I finally have stopped caring about the temp and just gear them till there sluggish than step one gear back. Figure if it thermals fine. Least I am not slow. Is this normal once they have broke in or did I break them?
"We have upped our standards so up yours"
denver is offline   Reply With Quote
Old 06-26-2008, 12:18 PM   #336
Trader Rating: 38 (100%+)
Same ESC and ESC settings/timing? On my Novak motor last week I got a 40 degree swing (up) just by switching my Tekin RS from hybrid mode to sensored only.
or8ital is offline   Reply With Quote
Old 06-26-2008, 03:36 PM   #337
denver's Avatar
Ya nothing different. I even suspected the same and went through and reset my speed control. Tomorrow I am going to test my Novac 17.5 and see if I get similar results to rule out everything except the motor. Is it possible I could have overworked them and they lost there mojo. Is the super hot temps a common sign off a shot brushless motor?
Old 06-26-2008, 07:13 PM   #338
Send a message via AIM to kyle478
Denver,
It seems you may have got the motor to the point where it started to loose its magnet strength. If the motor looses its strenth it will increase the RPM of the motor as well increase the amp draw. The power will go down if this happens. You might want to consider replacing the rotor. We have them in stock if needed.
The office number is (480) 726-7519. You can call 8AM-4PM MST
Hacker Brushless USA www.hackerbrushless.com
Aero-Model www.aero-model.com
kyle478 is offline   Reply With Quote
Old 06-26-2008, 07:16 PM   #339
If you dont think it is the rotor you could always send it to us to have it checked out.
Old 06-26-2008, 09:24 PM   #340
denver's Avatar
Originally Posted by kyle478 View Post
Denver,
I kind of suspected the that. I thought I had read something that if you got them too hot it weaken the magnet. Thanks for the info. I will hit you up in the am about replacement rotors.
Old 07-03-2008, 06:50 PM   #341
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'm going to borrow a 17.5 for a little racing in a few days. Any suggestions on ballpark rollout? Short track, carpet.
syndr0me is offline   Reply With Quote
Old 07-03-2008, 09:18 PM   #342
What car are you going to be running?
If Sedan are you running rubber tires or foam?
Old 07-04-2008, 08:45 AM   #343
syndr0me's Avatar
Kyle,
I'll be running a sedan (416) with rubber tires on a small carpet track. Thanks!
Old 07-04-2008, 03:19 PM   #344
Kyle,
Depending on how small the track is layed out, I would start around a 5.5fdr.
Old 07-04-2008, 06:15 PM   #345
Grenade10's Avatar
Trader Rating: 37 (100%+)
Denver,
Denver, something else to check is the bearings in the car. My Vintage Trans-Am with the 17.5 has started to show more Temp and slowed down. Pulled all the bearings in the car and found two that were crap!!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Hacker Brushless 17.5 and 13.5 motors for sale Bertetto R/C Items: For Sale/Trade 1 08-19-2008 04:43 PM
13.5/17.5 Brushless motors - Hacker, Losi, Full Throttle BBSpence R/C Items: For Sale/Trade 6 08-13-2008 10:19 AM
--Hacker brushless motors! For E-Revo or large scale! pb4ugo R/C Items: For Sale/Trade 7 07-21-2008 06:26 PM
X-Ray 008 US, Much More, Hacker and Orion Brushless Motors RBLove R/C Items: For Sale/Trade 13 05-06-2008 06:27 PM
Hacker Brushless Motors GundamWZero Electric On-Road 5 08-11-2004 04:21 PM
