Old 05-07-2008, 10:15 AM   #196
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'd be curious to know why Mr. Hacker opted against a removable sensor harness, and also against solder tabs instead of holes. He's pretty clearly the best brushless motor designer around, so I'm guessing he made these decisions for a reason.
I know Novak has said there's a chance the sensor harness could come unplugged, but many races and championships have been won with motors where the harness can be removed, so clearly it's a viable option at least.
syndr0me is offline   Reply With Quote
Old 05-07-2008, 10:33 AM   #197
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Dude, I'm with you on this one! I have been wanting to try a Hacker 17.5. But the harness issue is annoying. I may still try one because Hacker has been tops in brushless for a while.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 05-07-2008, 10:43 AM   #198
Zagar's Avatar
What is being monitored in the sensor harness? Why is it that some run with and some without?
Zagar is offline   Reply With Quote
Old 05-07-2008, 10:58 AM   #199
Trader Rating: 24 (96%+)
rotor position
check out info here http://www.kendickerson.com/tech_inf...ensorless.html
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
http://www.kolorsbykropy.net
nemix is offline   Reply With Quote
Old 05-07-2008, 10:59 AM   #200
timmay70's Avatar
Temperature and rotor position.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 05-07-2008, 11:04 AM   #201
Zagar's Avatar
Great link nemix! Thank you!! That really explains it well.
Edit: So let me ask this: What is the preferrred ESC to use with the Hacker motors? I am partial to Novak, only because I've used them a good deal. Also, does Hacker make a 21.5 and if not, is one in the works? Thinking of one for the TA racing, but I need a 21.5 to use with LiPo.
Old 05-07-2008, 11:29 AM   #202
I've been using the hacker 13.5 and 17.5 with an lrp sphere comp 2007 (non-tc). Everyone local to me has settled on lrp speedo's and hacker motors. It's a great combo.
JoelV is offline   Reply With Quote
Old 05-07-2008, 11:57 AM   #203
jla8874's Avatar
Trader Rating: 23 (100%+)
The use of purple shows an immediate and definitive lack of style. :-) But, I can find ways around that. It's the fixed sensor harness that's kept me from buying one. Long wires everywhere are fail.
Touché!
Thanks for the backup orbital and syndrome, I knew I wasn't alone in that line of thinking. I agree with you 100% about the sensor harness as well. I didn't find that out until after I bought the motor. Very disappointing. Now I know why every picture you see of the Hacker is from the opposite side.
jla8874 is offline   Reply With Quote
Old 05-07-2008, 12:06 PM   #204
JayBee's Avatar
Trader Rating: 31 (100%+)
I'm currently running my Speed Passion 13.5's @ 5.2-5.4 FDR w/ rubber on medium-sized/ med.-bite carpet. I just got my Hacker motors and wanted to know is this a pretty close FDR to start with?
The attached sensor harness is pretty FUGLY but if the motors perform as rumored, I couldn't care less.
I run for Schuie, so the black & purple is welcomed
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-07-2008, 12:32 PM   #205
Goingfast's Avatar
Trader Rating: 29 (100%+)
Hi JB
My understanding that the Hacker motor like to be geared up two teeth compare the Novak....
temp seems to be the best way i like to keep my motor between 165 and 180 degrees this according from ERTRACHTER
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 05-07-2008, 04:10 PM   #206
Send a message via AIM to kyle478
Originally Posted by jla8874 View Post
Touché!
Hacker Brushless motors has a reputation of being the best performing motor in the industry. Hacker has over 300 different motors, different sizes, series, and winds. Every one of these motors is purple in color which is intended to be a royal color. It is very possible we might do accessories in the future but at this point in time we are concentrating on being the best performing motor.
The pictures you have seen did not come from us and we never had the intention to fool our customers into thinking it had a removable sensor cable.
When this motor was initially created we kept in mind we did not want to have sensor cables coming unplugged while running. We have used sensored motors in airplanes before and have had huge problems with sensors coming unplugged. These planes we are flying tend to cost around $10,000 so a sensor coming unplugged could really be expensive. Now I also understand were not dealing with huge planes and $10,000 in equipment but we still want to keep the sensor problems to a minimum. We have also taken into consideration the suggestions of everyone on this fourm and it seems to be that most want a removable sensor plug. I imagine we will take this into consideration when creating our next motor.
Hacker Brushless USA www.hackerbrushless.com
Aero-Model www.aero-model.com
kyle478 is offline   Reply With Quote
Old 05-07-2008, 04:29 PM   #207
Zagar's Avatar
kyle, does Hacker make a 21.5?
Old 05-07-2008, 04:38 PM   #208
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I asked this in the first few pages, he said the same thing novak did, might come un plugged, I have never had that happen, but either way its a good motor
I have ran XL, and L can hackers in other cars and there nice!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 05-07-2008, 04:40 PM   #209
jla8874's Avatar
Great response Kyle. Sorry for implying it was Hacker that took the pictures. One was from Stormer obviously, and the other one right here was from Petit-RC. Nice to hear you're taking customer feedback in to consideration though.
Old 05-07-2008, 04:46 PM   #210
At the moment we do not make a 21.5T motor. I have had a few people ask about this and we will try to make one in the near future.
Hacker Brushless 17.5 and 13.5 motors for sale Bertetto R/C Items: For Sale/Trade 1 08-19-2008 04:43 PM
13.5/17.5 Brushless motors - Hacker, Losi, Full Throttle BBSpence R/C Items: For Sale/Trade 6 08-13-2008 10:19 AM
--Hacker brushless motors! For E-Revo or large scale! pb4ugo R/C Items: For Sale/Trade 7 07-21-2008 06:26 PM
X-Ray 008 US, Much More, Hacker and Orion Brushless Motors RBLove R/C Items: For Sale/Trade 13 05-06-2008 06:27 PM
Hacker Brushless Motors GundamWZero Electric On-Road 5 08-11-2004 04:21 PM
