Old 07-13-2003, 07:58 PM   #1
Difficulty of Making Battery Packs
Hi
I am looking at purchasing an Xray T1R, but, because you have to make your own battery packs for the chassis design, I am a little intimidated about making battery packs (soldering, heat shrink, etc). How difficult is it to make them, specifically for someone new to this and should I let it get in my way of owning the car?
Than you very much.
Rocky is offline   Reply With Quote
Old 07-13-2003, 08:20 PM   #2
pkranger63's Avatar
With a battery jig, such as the one from Deans and a good soldering iron its really pretty darn easy. The key is a good soldering iron. I struggled making my own packs for a while but invested in a good iron and from then on it was smooth sailing.
Good luck!
Matt
pkranger63 is offline   Reply With Quote
Old 07-13-2003, 09:02 PM   #3
hellangel's Avatar
if ur soldering iron is not hot enough, it's difficult to get a proper solder joint. i would suggest at least 80 watts for the iron...
hellangel is offline   Reply With Quote
Old 07-13-2003, 09:05 PM   #4
WC
WC's Avatar
Trader Rating: 28 (100%+)
Ask your hobby shop.
If you buy the car & the batteries from them, maybe you can talk them into doing the soldering for you too - if you're lucky free, or maybe for only a few dollars.
WC is offline   Reply With Quote
Old 07-13-2003, 09:08 PM   #5
JohnA's Avatar
The first few pack I made were pretty rough, but now it's a piece of cake. I would suggest not practicing on expensive cells, maybe even get some cheap everreadys to practice on. And like everyone says a good hot soldering iron with a biggish tip will make life a lot easier.
JohnA is offline   Reply With Quote
Old 07-13-2003, 09:31 PM   #6
newracer's Avatar
R/C Tech Charter Subscriber
a Deans jig and a decent soldering iron really makes it easy.
newracer is offline   Reply With Quote
Old 07-13-2003, 09:35 PM   #7
Fully Hopped's Avatar
Things You will Need
1. Good Soldering Iron Like a Weller [60 watts and up]
2. Rosin Soldering Flux form Radio Shack
3. 60/40 Rosin-Core Solder from radio shack
4. Deans Battery Jigg
5. Helping Hands
Resorces That Helped Me.
How To Make The Perfect Solder Joints
How To Use Connectors
How To Build A Battery Pack
How To Install a ESC
Soldering
Fully Hopped is offline   Reply With Quote
Old 07-13-2003, 10:12 PM   #8
Rob Mincey's Avatar
One thing to be aware of - if your cells already have shrink wrap, don't put another piece of shrinkwrap on them. In cars like the XXX-S, it can mean the difference between your cells sitting in the battery "grooves" correctly, or not fitting at all.
Rob
Rob Mincey is offline   Reply With Quote
Old 07-13-2003, 10:24 PM   #9
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Battery packs are really easy to make, I use only a 50 watt iron and have no problems at all. I do have a digital tip temp readout on the iron, so I know when the iron is hot enough to solder another bar (usually takes 10 seconds between bars to regain it's heat) Just practice and you'll get good quick with it.
Old 07-13-2003, 11:11 PM   #10
fatdoggy's Avatar
After a few packs you'll get the hang of it. Don't let the battery building get in the way of getting a car that runs saddles.
fatdoggy is offline   Reply With Quote
Old 07-14-2003, 03:51 PM   #11
Trader Rating: 24 (100%+)
Rocky,
If it scares you to build a pack or you don't want to invest in a soldering gun,jig,connectors and wire. Just order your packs from www.promatchracing.com. They offer assembly of their packs w/connectors.
Evoracer is offline   Reply With Quote
Old 07-14-2003, 06:39 PM   #12
Default Thanks
Thanks for all the help. Definately more than I was expecting
I feel confident now and I am going to give it a try.
Old 07-14-2003, 07:35 PM   #13
Korey Harbke's Avatar
Yeah, battery packs aren't that hard. You just have to take your time when you build them. If you take yourtime they will lmost always come out really nice.
-Sushi boy
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-14-2003, 08:12 PM   #14
pkranger63's Avatar
When you ask a question on this boards odds are you will not be hurting for answers! You found the right place my friend. Good choice on taking the plunge with the battery packs, good soldering skills really make the hobby more enjoyable.
Matt
BATTERY CASE FOR 6 CELL PACKS HOLDS 5 PACKS speedemall R/C Items: For Sale/Trade 2 06-08-2007 03:58 PM
Airbrush difficulty Syxxstring Painting, Designs, Graphics and Photography 1 08-16-2006 11:01 AM
Charging receiver packs, making the connection Cain Electric Off-Road 1 08-09-2005 03:10 PM
10 6 cell battery packs, 3 stock motors and 2 sakio battery cases $52.00 ??? bigoTC3fan R/C Items: For Sale/Trade 1 09-22-2004 06:07 PM
Wanted: Battery making supplies Evil_S10 R/C Items: Wanted to Buy 0 12-27-2002 09:02 AM
