Old 07-15-2003, 10:04 AM   #31
iron chef's Avatar
Calvin,
thats just it, lock in the rear end...
more rear toe-in
longer camber link
front sway bar
maybe 1 step stiffer rear spring
lay shock down, slower weight transfer
I dont think the iron chef winning percentace is that high, its all got to do with practice and dedication and willingness to think outside the box, sounds like a simple lesson applicable to many aspects of life and rc tuning
iron chef is offline   Reply With Quote
Old 07-15-2003, 10:14 AM   #32
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
lay down the shocks for front and rear?
Calvin Ng is offline   Reply With Quote
Old 07-15-2003, 01:16 PM   #33
iron chef's Avatar
probably just start with the rear to make sure you have the traction addressed then work the front to achieve neutral handling
Old 07-15-2003, 09:20 PM   #34
WC
WC's Avatar
Trader Rating: 28 (100%+)
414 should handle quite neutrally out of the box... probably even pushes on entry into corner. Tail should be well planted.
Might be an idea to Reset everything back to the manual's specs, before trying anything out.
And do any changes only 1 at a time.
And don't change both Front and Rear at same time, it defeats purpose and just confuses things.
WC is offline   Reply With Quote
Old 07-15-2003, 09:34 PM   #35
Registered User
Calvin Ng's Avatar
im looking for 2 setups on my car one with a diff and one with a one-way
our track is low to medium traction
prefered tires are yokomo 138's
soft setup for sure
any suggestions?
Old 07-16-2003, 02:58 AM   #36
Cole Trickle's Avatar
Not that I have muc experience with low to medium traction, but personally I wouldnt go for a one-way.
But if I should try it, I would first setup the car with double regular diffs, so it performs very well. Then I would secure that I got the whole setup written down and that I got access to a setup board. First at this point, I would try the one-way and eventually adjust the setup by making the rear softer etc.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Tricks??? jmdv Nitro Off-Road 5 12-18-2007 08:52 AM
M11 TIPS AND TRICKS!!!!!! S-T-R-l-K-E-R Electric On-Road 11 08-11-2005 11:32 PM
JRX-S Set up tips, tricks, and set ups bigdog xxx-s Electric On-Road 5 04-20-2005 10:12 PM
Up to my old tricks again........ GundamWZero Chat Lounge 2 09-09-2004 08:40 AM
esc tricks pro3racer Electric On-Road 6 02-27-2004 02:34 PM
