Old 07-14-2003, 01:45 AM   #16
Cole Trickle's Avatar
Originally posted by Calvin Ng
waht kind of driving style should you have when you enter/exit the corners
With a one-way diff, it's possible to apply throttle way sooner.... but not with a one-way pulley.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 07-14-2003, 01:47 AM   #17
How do you guys determine when to run the relative heavy one-way diff and when to run the light weight ball diff?
Old 07-14-2003, 02:08 AM   #18
WC
WC's Avatar
Trader Rating: 28 (100%+)
hey wc do you turn up your throttle
just asking sounds like your know your one-ways
I'm running my ESC at very low freq... about 3000Hz I think.
Seems to be a bit more punchier than at high freqs.
Ahh, I've only just started experimenting with 1-ways.
Before I ran 2 TA03s, one had a 1-way layshaft in front with
dual-diffs (like a belt-drive car with layshaft one-way).
Then I mucked around with an old Yok, with 1-way diff front
vs balldiff just to see how that handled, but I only had 1 Yok.
This diff type of 1-way drives very differently to the TA03.
Spent some enjoyable hrs on Sat at the track... seeing which
ways of driving is quicker around the track with 1-way Evo3.
Now thinking of testing to go see what's the real difference
between 1-way or front diff on the Evo III... & when got time
to pull the 2nd Evo III off the shelf and put front diff into it.
I prefer to do back-to-back testing with 2 identically setup cars.
Its the only scientific way to discover what the actual change is.
WC is offline   Reply With Quote
Old 07-14-2003, 03:39 AM   #19
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Hello guys,
I use one ways only on large tracks. On small/tight tracks although sometimes it is possible to use one, the fact that the other drivers don't use one makes it extremely difficult to use it!
I like using one way but I have trouble braking with it, so I usually let off throttle earlier. I have read that some of you actually brake! How do you do that???
Thank you
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 07-14-2003, 05:38 AM   #20
Originally posted by nnick
Hello guys,
Thank you
Nick
I'm only running with one-ways. I almost dont brake, but I find it very helpful limiting the amount of brake on my radio. In my case I limit the maximum brake to 80%. That's in stock class, rubber tires on carpet. Tight and technical track. If your radio got an ABS, it'll help also.
Old 07-14-2003, 06:26 AM   #21
Shop Owner
nnick's Avatar
Hello Cole,
I also reduce the brake, 30-40%, but I was thinking what should I do in order to be able and use brakes with one way!
I usually hit brakes hard, if I train myself to be smoother on brakes will I be able to brake with one way?
Thanks again
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 07-14-2003, 10:52 AM   #22
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
how bout carpet trackets. very technical. my tale didnt even slip a BIT on carpet
should i stick with a one-way or go to a diff on carpet
Calvin Ng is offline   Reply With Quote
Old 07-14-2003, 10:56 AM   #23
Registered User
Calvin Ng's Avatar
Default Re: hmmm
Originally posted by dynoman007
try locking the rear end in a lil more (adding traction ) by laying the rear shocks down in the top of the shock tower ...
what does that do?
Old 07-14-2003, 11:05 AM   #24
John_S's Avatar
hi i run a 1 way in my car only because it came with the kit i run on a very slidy linolium track similar grip to polished wood with yelloow mini pins and its very tight and was wondering if u guys thot a front diff wud be beter on this type of track
John_S is offline   Reply With Quote
Old 07-14-2003, 02:32 PM   #25
Hello Cole,
Thanks again
Nick
Sorry, I dont know.... I only brake to avoid crashes in front of me, meaning almost no braking...
Old 07-14-2003, 02:37 PM   #26
seaball's Avatar
Send a message via Yahoo to seaball
yes. oneways are so tough on slippery tracks. think consistency. a oneway will give you a few tenths, but piping it will deduct whole seconds. you decide.
same argument for carpet. yes, people are running them, but most of us that have a good setup get plenty of cornerspeed with double diff setups on ozite. ok, most of them.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 07-14-2003, 04:03 PM   #27
iron chef's Avatar
Since you never really know until you try, I run a MR4 special and have experimented a little with one ways/diffs this summer and have made the following observations
begining with a stock set-up and stock motor.I always set throttle trim so the car rolls forward when set on ground and hold brakes at the start.
The double one way car seemed to perform best on a track with wide lanes where very little braking is required and high surface traction was present. From stock I went to a heavier rear spring, 2-degree toe-in rear carrier, longer camber links, and front sway bar. The 2 degree carriers and front sway bar made the biggest difference overall. The other observation was due to lack of front diff action, you run a higher risk of doing damage to front end components specifically axles and driveshafts if (when) you hit the wall.
The direct drive/front diff combo is by far the lightest option for my car and produced the fastest overall acceleration on tighter, technical tracks. The braking power was way more consistant and powerful and allowed for tighter line into corners. The car would scrub speed on sweepers, making it easier to coast around without thinking of using transmitter brakes.
Although some people can run one-ways on carpet, technical tracks, or low traction situations, I think direct drive/front diff combo would be my first choice. I will have to save the one way parts as options for large, well prepared tracks since you will only have rear braking power.
Cole Trickle posted this link some time ago that helped
http://www.rccaraction.com/articles/oneways.asp
iron chef is offline   Reply With Quote
Old 07-14-2003, 08:27 PM   #28
Registered User
Calvin Ng's Avatar
thanx for the chef
i love your name
i watch that show alot
why the heck does the iron chef win all the time. that pisses me off. and why does that dude bite a pepper
iron chef winning= 99.9%
challenger =0.01
Old 07-15-2003, 07:21 AM   #29
Claydoh's Avatar
Send a message via AIM to Claydoh
If you are getting too much roll with a one way, you can add 5000wt diff oil to the one way bearings and that will slow down the free-wheeling. It works good. I almost slow down as fast as the diff cars but I still have tons of steering and more pull through the corners
Claydoh is offline   Reply With Quote
Old 07-15-2003, 08:31 AM   #30
Registered User
Calvin Ng's Avatar
lets just say i had teh perfect diff setup for my 414mII what would i need to change to make the one-way work really well
Tricks??? jmdv Nitro Off-Road 5 12-18-2007 08:52 AM
M11 TIPS AND TRICKS!!!!!! S-T-R-l-K-E-R Electric On-Road 11 08-11-2005 11:32 PM
JRX-S Set up tips, tricks, and set ups bigdog xxx-s Electric On-Road 5 04-20-2005 10:12 PM
Up to my old tricks again........ GundamWZero Chat Lounge 2 09-09-2004 08:40 AM
esc tricks pro3racer Electric On-Road 6 02-27-2004 02:34 PM
