23T motor thread >
23T motor thread
23T motor thread
Old 11-26-2007, 08:21 PM
  #1216
Here information from Team orion Japan:
The 4ZSF are adjustable.
Only the 3TLF has fixed timing (ORI20059).
hirosaki is offline
Old 11-27-2007, 03:47 AM
  #1217
mac853's Avatar
But why has released fixed, as i saw in JMRCA both of them are allowed?
mac853 is offline
Old 11-27-2007, 04:38 AM
  #1218
I think maybe some country not follow JMRCA rules for 23T stock class
hirosaki is offline
Old 11-27-2007, 05:18 AM
  #1219
mac853's Avatar
Which country?
Some sites even are more opened rules than in Japan, allow 11.5BL mix with 23T BR like in Speedpassion races in HK and Australia, you could see their series gallery here:http://www.kinggolden-rc.com/gallery.html
mac853 is offline
Old 11-27-2007, 06:34 AM
  #1220
KoE
KoE's Avatar
can't say for other countries, but in Malaysia...our 23T is divided into 2 categories; novice and sportsman. For 2007 series, novice would have to run fixed timing but sportsman could run the latest yokomo cans
KoE is offline
Old 11-27-2007, 06:51 AM
  #1221
mac853's Avatar
You should be right.
But why the latest cans could be beat by old ones, maybe they are not so good?
Could you tell me which motor is more popular in sportsman class of your country, the lastest can ones?
mac853 is offline
Old 11-27-2007, 06:20 PM
  #1222
KoE
KoE's Avatar
We aren't really looking at perfect comparison between old and newer cans. Those motors were not in identical cars driven by identical drivers. Many other factors came into effect.
I'm not sure what the sportsman champ was using the other day; my guess is the newer yok. During one of the finals, the other guy was also super fast and he was using the fixed timing Katana motor. I think it still boils down to fine tuning and proper gearing...and to a good extend...a fresh battery pack.
KoE is offline
Old 11-27-2007, 09:15 PM
  #1223
mac853's Avatar
Thanks for reply.
But somebody could tell me if the all new cans ones are unfixed timing, otherwise which of them could timing?
mac853 is offline
Old 11-27-2007, 09:41 PM
  #1224
Airflow's Avatar
Hey guys, need some tips on how to get the most out of the tamiya rz and the GT tuned motor... both legally and illegaly.
Airflow is offline
Old 11-28-2007, 12:37 AM
  #1225
KoE
KoE's Avatar
Thanks for reply.
so far only the yokomo-based cans are adjustable
KoE is offline
Old 12-01-2007, 09:08 PM
  #1226
2-Bad's Avatar
Trader Rating: 24 (100%+)
need help... I've never run 23t in class racing before... any tips on making them faster would be appreciated....
2-Bad is offline
Old 12-01-2007, 09:29 PM
  #1227
xray racer's Avatar
Trader Rating: 22 (100%+)
2-Bad,
What sort of motors are you running???
I've been racing 23t for a while now, absolutely LOVE the class... prefer it over 27t any day.
Let me know and i'll see what i can help with
Robbie
xray racer is offline
Old 12-01-2007, 09:58 PM
  #1228
2-Bad's Avatar
Originally Posted by xray racer View Post
2-Bad,
Robbie
Robbie... I'm using the HPI Circuit 23T-30S Motor....
2-Bad is offline
Old 12-01-2007, 10:10 PM
  #1229
xray racer's Avatar
unfortunately i'm not too familiar with the motor?... does it use a yokomo or top can... or is it the new gen Checkpoint style can/endbell's,
As a guide from what i've found, yokomo style motors tend to like being geared a little lower and still scream... but you've got to be careful as they are easy to cook. They will still come back after a rebuild and be okay... but they generate more heat than say the atlas cans. Those on the other hand, atlas motors, you can gear to the moon until you find the right performance.
As for brushes, the best brush i've used in 23t's would have to be the Atlas Sprint Silver brush, second to that would be the Katana lay-down brushes. Both will perform well on all tracks.
A very small detail that can help performance is, inside the brush hoods on yokomo style motors, there's a little contact tab that folds down over time... if you pull it back up again it promotes better contact with the brushes.
Other than that, its much the same as tuning a normal motor, make sure the brush hoods are aligned (probably most important), polish the bushes and make sure its well lubed.
Whilst its not COMPLETELY necessary with 23t's as they can usually last a little longer than a standard motor, they always perform better fresh, so i've always just stripped them after each race and taken the smallest skim of the comm and cleaned out the can with copious amounts of motorspray and use again for the next race. Give the arm a good polish too.
I dont know if its applicable to you, but some 23t races as per the JRMCA rules are 8mins long, so getting the motor cold before the start of a race helps alot.
Anything i've forgotten???
Just drop in the motor and go and give it a good thrashing. To prove their tolerance, last year at the ACT indoor titles i melted the plastic shim at the bottom of the winds in my Luna during a race- skimmed the comm, cleaned it out well and re-shimmed it, and its STILL my best performing motor on the track.
Hope some of this helps
Cheers,
Robbie
Old 12-01-2007, 11:44 PM
  #1230
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
There are new cans from Xenon which is also adjustable. Most probably oem from Yokomo.
-KilleR- is offline
