23T motor thread >
23T motor thread
23T motor thread
Old 05-24-2007, 05:30 AM
  #1171
James khoo's Avatar
Trader Rating: 15 (100%+)
Try the Altlas motor or Orion,they are good.
James khoo is offline
Old 05-24-2007, 05:31 AM
  #1172
xray racer's Avatar
Trader Rating: 22 (100%+)
Is there a particular motor you would recommend?
I've played around a little with the different types as you've mentioned, but is there a 'Hot Ticket' motor at the moment? any outstanding models at the moment?
I've got a great Yokomo Motor at the moment, one of the T-max motors, and an awesome Luna. I've only really had experience with those and Atlas motors...
I've heard the Orion motors are good, Katana is it???
WHich models would you recommend, atlas force series??? or a different atlas model? or the Orion motors.
Cheers,
Robbie
xray racer is offline
Old 05-24-2007, 05:42 AM
  #1173
xray racer's Avatar
what about Xenon 23t motors? are they any good... ro stick with Atlas and Orion?
Old 05-24-2007, 06:36 AM
  #1174
James khoo's Avatar
Lastest Xenon motor Illusion is better then Orion,use the high torque version for the track you mention,you'll be please with it
Old 05-24-2007, 06:42 AM
  #1175
xray racer's Avatar
what about the Atlas Force range? are they better???
Whereabouts can i buy these motors online???
The illusions etc
Old 05-24-2007, 06:56 AM
  #1176
James khoo's Avatar
You can buy at www.rcplanet.com.my
Old 05-27-2007, 10:08 PM
  #1177
Hi i am running a yok flt and am wondering what brushes would be great for all out power.
I run on a oval short track 18m corner to corner 15m wide with 1.8m lanes.
We only run short races maximum of 40 laps.
Know the hard part my car is a tc3 weighing in at 3.7kgs no that is not a typo. I am currently running peak sprint brushes and the motor is geared 22/72 for a total ratio of 8.18. I use either foam or rubbers depending on the surface, which can range from wooden floor to polished concrete.
A photo of the car can be seen at rc stockcars and yes that is a steel frame around it. Mine is on the far left with 2nz down the side.
Any other motor recommendations would be good also, 23t fixed timing
Thanks Doug
burnouts is offline
Old 05-27-2007, 11:02 PM
  #1178
KoE
KoE's Avatar
Originally Posted by burnouts
....Know the hard part my car is a tc3 weighing in at 3.7kgs no that is not a typo...
wow! demolition derby sort off the yok brushes that came with the motor are good. However, i normally change to Atlas high silver brushes. If you try google search .... there's a site called motortuningsectets or something pretty close to that. This thread has some pretty decent tricks about brush centering yada yada ....but they are somewhere in the middle
KoE is offline
Old 05-28-2007, 01:53 AM
  #1179
xray racer's Avatar
Can anyone tell me about the Atlas Force range?
I'm tossing up between an Orion Katana and the Atlas force, looking for lots of power+ torque in either motor.
Which one would/do you go for?
Any help will be appreciated,
Cheers,
Robbie
Old 05-28-2007, 02:09 AM
  #1180
James khoo's Avatar
Thanks Doug
Use Reedy 729 for standup brush or Reedy 766 for laydown
Old 05-28-2007, 03:16 AM
  #1181
Rod M's Avatar
Cheers,
Robbie
I believe the Excel Fireblade is the same as the Orion Katana,
I used one on the weekend at MECA to get 2nd in Stock,
and just changed the brushes to XXX laydown,
Rod M is offline
Old 07-02-2007, 01:01 AM
  #1182
Talking My opinion only leh
any1 tried the very old sport tune mabuchi by tamiya? im still using it and will be using it for competitions , especially for longer runtime event with open stock challenge. which i found this can is cooler then the rest, can cope up with latest can and longer runtime with scalable speed performed. most of its cheap . what i found out, it can only be use with mid range track. any track with 30-40 meter straight will do great with this primitive fella.
anyway, my fav are still on Yoks SR and FSR. short circuit will be the ST type.
Just wondering if near future, these stocks can use the V2 endbell. i found it, VERY interesting.... longer then brushless in running time .
ayeen2 is offline
Old 07-02-2007, 04:11 AM
  #1183
i still prefer my old FLT's. Tons of rip all around my local track.
oversquared is offline
Old 07-04-2007, 09:42 PM
  #1184
Trader Rating: 72 (100%+)
Hi guys. The Tamiya Nationals are coming up and the handout motor is going to be the 23t RR motor. I was wondering if you guys that have experience with this motor could share some info; such as gearing, brushes, and springs, thanks.
patrick is offline
Old 07-04-2007, 11:04 PM
  #1185
nino_pohan's Avatar
Try new Yokomo 23T stock motor with new endbell (like checkpoint endbell)
nino_pohan is offline
