23T motor thread >
23T motor thread
23T motor thread
Old 03-06-2007, 04:55 PM
  #1141
need4speed's Avatar
Which is the best choice for a good Torque Motor?
Yokomo FLT
Yokomo FST
Orion Katana ?
Xenon ?
Tamiya ?
need4speed is offline
Old 03-06-2007, 06:48 PM
  #1142
James khoo's Avatar
Trader Rating: 15 (100%+)
Yokomo FLT
Yokomo FST
Orion Katana ?
Xenon ?
Tamiya ?
Yokomo FLT is the best bet.
James khoo is offline
Old 03-06-2007, 06:49 PM
  #1143
KoE
KoE's Avatar
the best motors are the FREE ones
yok LT would be my preferred choice, ST would be slightly tamer. Where is JDM when we need him most
KoE is offline
Old 03-06-2007, 08:26 PM
  #1144
need4speed's Avatar
The last MNC (which was a disaster for me ), I was using a SR motor for the stock race. I was lost as to finding a suitable ratio. Any suggestions?
Old 03-06-2007, 09:02 PM
  #1145
Geetoo's Avatar
This is a good choice too:
http://www.teamtectro.com/
Geetoo is offline
Old 03-06-2007, 11:00 PM
  #1146
need4speed's Avatar
Heard of it but it's quite hard to come by, last I saw the local importer had no stock of the SP1. Had to make do with what I can find.
Old 03-06-2007, 11:42 PM
  #1147
KoE
KoE's Avatar
i was switching between atlas toyomiti ed. & yok sr during that race. Can't quite remember which i used for final tho. Some st were pushed to about 5 flat. SR at abt 5.5 there. Too bad atlas stops producing toyomiti. Ima hunting for either team luna or team tectro if i'm into 8-min run
KoE is offline
Old 03-07-2007, 12:17 AM
  #1148
need4speed's Avatar
Yup, quite a few also told me they were using 5.0 Maybe that's why I was so slow The best I tried was 5.8, lower than that bogged down the motor. Maybe my batts were also not up to the IB's +1.2V
Old 03-07-2007, 05:30 AM
  #1149
James khoo's Avatar
One of my local guy is using Xenon Illusion stock motor with gear ratio of 7.1,and on main straight,he as fast as my katana with gear ratio of 5.22.
Old 03-07-2007, 07:18 AM
  #1150
rcdy's Avatar
what katana series are you running? i thought they were geared around 6.0. 5.22 should be very fast or very hot.
rcdy is offline
Old 03-07-2007, 09:18 AM
  #1151
ttso's Avatar
I'm doing Orion Katana2/HPI R2 (they are identical motor, just different label) TLF series only right now. The Luna Glory Legend FH-L2 is the tuned version of TLF. I'm going to try TSF series soon as JMRCA open adjustable timing for standup brush.
ttso is offline
Old 03-07-2007, 09:30 AM
  #1152
Tpg racer's Avatar
How do you maintain ur brush??? If the comm is black, the jz cut it but what about the brush??? Do we have to keep on changing it as soon as it turns blackish in colour???
Tpg racer is offline
Old 03-07-2007, 09:59 AM
  #1153
ttso's Avatar
If it's racing and you are in spot to win something, change brush for max performance. If it's normal day, use sandpaper to cleanup brush, runin, play again, until brush get too short causing problem.
ttso is offline
Old 03-07-2007, 05:56 PM
  #1154
James khoo's Avatar
I'm running katana TSF series with Reedy 729 brush.i still can go 4.80 on gear ratio.
Old 03-07-2007, 11:04 PM
  #1155
Tpg racer's Avatar
Yea dats wat i did but the brush remain blackish/greyish in colour......and the surface is no longer smooth.....
