23T motor thread >
23T motor thread
23T motor thread
Old 09-18-2006, 10:36 AM
  #1111
Talking
Originally Posted by dgullickson
We are also venturing into the 23t Market. Currently we are playing with the Atlas based 23t.
What type of numbers are people seeing on a TD45 Dyno? We are curious as we have gotten some awesome numbers but want to make sure we are in the range that people will be expecting.
The best number I got is 160 Watt @ 30 AMP with 7.0 V
ben2ben is offline
Old 11-30-2006, 07:04 AM
  #1112
need4speed's Avatar
Where's everyone gone?
need4speed is offline
Old 03-04-2007, 01:42 PM
  #1113
Grunta's Avatar
Talking
i dunno, i was hoping at least someone would start coming up with new tricks for this fantastic little motor. we run a 23 turn class in New Zealand and every lil bit helps to stay competitive
Grunta is offline
Old 03-04-2007, 03:33 PM
  #1114
nikkiesteban's Avatar
for a very long stretch is it ok to gear the 23t motor at 4.xx something???
nikkiesteban is offline
Old 03-04-2007, 04:50 PM
  #1115
need4speed's Avatar
Where I come from ratio of 4.xx = smoke = new motor soon.
I've heard from one of the local guys here says it's possible but it means cutting the comm after every run. Also only for high speed tracks where corners are smooth and wide. He was talking of about 4.8x
Old 03-04-2007, 06:59 PM
  #1116
James khoo's Avatar
Trader Rating: 15 (100%+)
Gear ratio 4.xx can be use,but provided that your motor are properly tweak.
James khoo is offline
Old 03-04-2007, 08:41 PM
  #1117
rcdy's Avatar
which of the Katana series motor is faster? the higher rpm for long straights.
rcdy is offline
Old 03-04-2007, 09:11 PM
  #1118
James khoo's Avatar
I always use TSF for big long track,and SSF for small track
Old 03-05-2007, 01:14 AM
  #1119
Hi all
How much off the pace would a 23turn motor with bearings be compaired to a 19t with bearings, both being spec motors and both having fixed timing.
MoonTrap is offline
Old 03-05-2007, 01:56 AM
  #1120
Do you think by putting heatsink and fan will help the motor? so that it won't go smoking? (geared into 4.xx)
Old 03-05-2007, 02:08 AM
  #1121
James khoo's Avatar
I was trying to gear at 4.60,running with heatsink+fan.the motor go smoke in 3 minute of running.the best i can get is 4.80 at my local track.but the comm is showing bit of heat.my motor set-up was Reedy black spring on positive,Reedy red spring on negative,with Reedy 729 brush,the hood is tweaked.
Old 03-05-2007, 02:36 AM
  #1122
ohh. I'm using tamiya 23t RZ and geared it at 4.46 then i touched the motor and it was hot. but not very hot. maybe its already afternoon that's why it didnt smoke. I think if i want to gear like that i have to put fan..
Old 03-05-2007, 04:04 AM
  #1123
GreaseMonkey's Avatar
I'm looking at running a Tamiya TZ motor in a pan car on an indoor carpet track 80' by 32'. Anyone have any idea what sort of rollout I'd need?
I put the motor on a robitronics dyno and got some good torque and power numbers but low RPM. Something like 205Nmm and 160W @26000RPM. Does this low an RPM sound normal for this motor? It is brand new with only a couple of minutes break in time.
GreaseMonkey is offline
Old 03-05-2007, 04:49 AM
  #1124
KoE
KoE's Avatar
somehow i never quite like the newer tamiya's 23Ts either red or blue. RPM readings are about the ballpark figures unless ya willing to polish the shaft, bushings and align the hoods. If not running tamiya sanctioned races, you can consider changing the brushes as well...my preference altas hi-silver
KoE is offline
Old 03-05-2007, 05:08 AM
  #1125
need4speed's Avatar
Koe, where in KL do you get these Atlas Hi-Silver brushes? Is there a big difference in performance when used as compared to the original brush that comes with any motor?
