23T motor thread >
23T motor thread
23T motor thread
Old 08-15-2006, 12:04 PM
  #1081
akuhon's Avatar
Default Tuned Yokomo F-LR
Just want to let you know for latest tuned 23T stock motor of my new Yokomo F-LR.
It uses only a basic tuning method to manage 37,000 RPM at 7.2V or 31,500 rpm at 6.0V
Later, I will replace the brush (still waiting to arrive those SP ver.) and the spring (got them already but still measuring the FSU for the correct one).
Hopefully I can get some more RPM, above 40,000 rpm.
Enjoy,
Attached Thumbnails 23T motor thread-tuned-flr.jpg   23T motor thread-tuned-flr-6v.jpg
akuhon is offline
Old 08-15-2006, 12:58 PM
  #1082
dgullickson's Avatar
Trader Rating: 45 (96%+)
Originally Posted by Geetoo
23 turn motors are mainly for asian market only since its classified as stock motor that is in between 19t and 27turns in terms of speed. US manufacturers dont make this motor since they follow roar stock rules only. A few Euro countries adopted 23turns too.
Here are 23turn tuners I know of:
Atlas, Orion, Tamiya, Yokomo, Tectro, Xenon, Excel, Dinky, ARD & Excel. (Mostly japanese)
We are also venturing into the 23t Market. Currently we are playing with the Atlas based 23t.
What type of numbers are people seeing on a TD45 Dyno? We are curious as we have gotten some awesome numbers but want to make sure we are in the range that people will be expecting.
dgullickson is offline
Old 08-15-2006, 05:11 PM
  #1083
akuhon's Avatar
Actually, for me, the number is not so important.
The important thing is how the performance of the motor on the track...
These numbers are only for reference.
How about the Atlas motor ? Are they good ? Never play with them...
Give me some info about the tuned ones from your dyno machine, then.
Have you seen any 23T stock motor that can run over 40,000 rpm ?
akuhon is offline
Old 08-15-2006, 07:04 PM
  #1084
I have been looking through this thread to find out some good starting points for gearing for the Ko Propo race, from what I have read you want to stay under 6.0 for gearing and be some where in between 5.5 and 5.8 and use a high silver brush, but that depends on the motor. The hand out motor for the race is going to be the Yokomo T-Max FLT 23T, does any body have any feedback they can give me on this motor?
Thank you
XCELL is offline
Old 08-15-2006, 08:20 PM
  #1085
akuhon's Avatar
I cannot comment on this....
Ideally, you should follow the recommended gearing but if you want more a bit precise, you should inspect (mainly) the track layout (hi-speed or technical) and also your car (BD or SD) type.
This is from what I've learned on this forum....
akuhon is offline
Old 08-16-2006, 12:13 PM
  #1086
edwintklee's Avatar
Trader Rating: 23 (96%+)
hi all,
don complaint about me asking silly question as i am newbie in ep racing...
i was told that yokomo f series motor are the fastest 23t in the market today. so generally i went and get myself a yok FLT motor. using it on my TA05 with ratio 5.9 or 5.76. i found its much slower that my current tamiya RZ, much slower... my Tamiya RZ got more punch andmore top speed.
so can please advise me what actually went wrong? my local track straight length its about 110ft...
thank in advance for your dvise..
general new motor procedure, i run in the motor on my pulsar t 2.0V for about 3 min, than lube bushing, than fix to car and run it....
edwintklee is offline
Old 08-16-2006, 03:07 PM
  #1087
akuhon's Avatar
Originally Posted by edwintklee
hi all,
1st, you have to know that FLT is Torque, RZ is RPM so threat them differently for the gearing.
2nd, Have you cut the comm on your RZ ? the smaller the dia. of the comm, the faster the motor. For me, the optimum size is about between 71-72mm.
3rd, Some racer suggest that new motor should be lathe 1st then break-in untill the brush sits properly to comm (full contact)... I never measure the break in process in minutes .....
That's all I can say at the moment ....
akuhon is offline
Old 08-17-2006, 11:10 AM
  #1088
Can i use the xxx brush on 23t motor? a friend of mine use it on the tamiya rz motor and it seems alot slower than the stock brush.
barry is offline
Old 08-17-2006, 05:52 PM
  #1089
Trader Rating: 15 (100%+)
Can someone tell me where i can get or order the T-max FLT 23t on line??
Thanks,
Larry
Ruby is offline
Old 08-17-2006, 07:43 PM
  #1090
m i g v e a's Avatar
hi all,
The Yok FLT is also geared differently compared to other 23T motors. i find that in a track where i gear 5.7-5.8 with a Orion Katana, the FLT is geared 6.3-6.5. keep runnnig it at that gearing and it will burn
m i g v e a is offline
Old 08-17-2006, 11:53 PM
  #1091
KoE
KoE's Avatar
edwin,
couple of guys experienced that and found that it will come "alive" after several comm cuts as compared against the older yok models
KoE is offline
Old 08-18-2006, 12:40 AM
  #1092
Trader Rating: 17 (100%+)
any one here tried Team Atlas Force MP 23T, are they any good? this motor are torque type.
EngTat
EngTat is offline
Old 08-18-2006, 01:28 AM
  #1093
Geetoo's Avatar
Definitely, it runs three times longer than ordinary brush before you change it. It adds more power overall.
Geetoo is offline
Old 08-18-2006, 05:20 AM
  #1094
edwintklee's Avatar
Originally Posted by KoE
edwin,
thanks for your info....i was sippose to get FLR, instead i got FLT....well have to send it for comm.
Old 08-18-2006, 12:04 PM
  #1095
MrBlack's Avatar
Just an FYI for 23T fans out there. We (Team Orion) have a new 23T Katana and it looks like we will be importing this one into the US. Once I get the confirmaton and specs I will post them here.
MrBlack is offline
