23T motor thread >
23T motor thread
23T motor thread
Old 08-02-2006, 12:52 PM
  #1066
KoE
KoE's Avatar
jolly good! nice to hear some development on 23T from the other side of the pond eric was contemplating into 23T earlier when he started ea motorsports but i guess the demand over in states wasn't there yet.
keep us posted
KoE is offline
Old 08-02-2006, 01:05 PM
  #1067
dgullickson's Avatar
Trader Rating: 45 (96%+)
No problem.. If there are other can types you would like me to carry just PM them to me with a link to where to get them and I will see what I can do..
dgullickson is offline
Old 08-03-2006, 04:15 AM
  #1068
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Hi,
I have a Tamiya RZ 23t in my stadium truck and it was running fine till i took it out and cleaned it. I firstly took it out of my truck then pulled the armature out. I got the compressor and blew the dust out of the can and of the armature and endbell. I then sprayed the armature, motor can and endbell with motor cleaner. I reassembled it and oiled the bushings on both ends. When i charged up a pack and went to go it had no punch at all and took a while to wind up. My brothers 2wd buggy with a 540 was beating my truck. It was working good before i rebuilt it and i hadnt even cleaned it even after about 6 runs. What could be the problem?
The comm is starting to get a bit black should i get it trued?
Also how many shims should be on each side of the armature?
Fast XXXS is offline
Old 08-03-2006, 04:26 AM
  #1069
tc3team's Avatar
Fast XXXS- I would definately get the comm cut and new brushes in there,it will help no end. If its not been cut for a while it may need quite a deep cut to bring it back up to its best.
As for the shims,if you have put the same ones on each side that you took out you should be fine. There is always a little movement,so the armature shouldnt be totally rock solid when you pull the end of the shaft with the pionion gear on it,but it should also not be very loose. Look for about 1-1.5mm endfloat.
tc3team is offline
Old 08-03-2006, 04:39 AM
  #1070
Fast XXXS's Avatar
Ok thanks. What could be some good brushes to get that will last me a while cause im only bashing with it?
With the shims as i pulled the armature out they fell out but i think they are back in properly i am just asking to make sure that i havent spaced it wrong. I am pretty sure i have placed 2 on each side. Is this right?
Old 08-03-2006, 05:32 AM
  #1071
tc3team's Avatar
If youre not racing it I would just go for a hard compound brush,these are usually a bit cheaper too. Just make sure you buy the right type as there are laydown or upright- the latter is when the shorter sides of the brush are at the top and the bottom of the brush holder,laydown is the opposite. (upright are | laydown are _ ) Hopefully you understand a bit better now!
The main thing is that a 100% surface area of the commutator is available to the brushes,(the dull part that needs cutting) and that it isnt too loose or tight in the can. If you havent lost any of the shims you should be fine
tc3team is offline
Old 08-03-2006, 05:36 AM
  #1072
Nicadrauspro4's Avatar
Trinity silver brush are good and gives the motor the punch power it needs. They last three times longer too.
Nicadrauspro4 is offline
Old 08-03-2006, 05:33 PM
  #1073
ford_racing's Avatar
definately go the high silver ones, you can get around 30 runs before needing to replace the brushes and they are extremely easy on the comm
ford_racing is offline
Old 08-03-2006, 10:44 PM
  #1074
Fast XXXS's Avatar
What i dont get is the motor was running perfectly fine and i hadnt even oiled it between runs and when i pull it apart for a clean and a spray the performance dropped right off.
But I will get it cut this weekend.
Old 08-05-2006, 12:30 PM
  #1075
akuhon's Avatar
It should go back to normal if the comm and the brush are in good condition.
But I also have some bad experience with some electric motor spray. Since then I never use motor spray. Only use compressor to clean the can inside, from the dirt and re-lube the bushing and give some comm drop.
akuhon is offline
Old 08-06-2006, 04:43 AM
  #1076
JDM_DOHC_SiR
I'm in Japan at Yokota; where are you racing at?
kmorast is offline
Old 08-06-2006, 05:58 AM
  #1077
Trader Rating: 81 (100%+)
Originally Posted by Geetoo
...Here are 23turn tuners I know of: Atlas, Orion, Tamiya, Yokomo, Tectro, Xenon, Excel, Dinky, ARD & Excel. (Mostly japanese)
thanks geetoo still waiting for the techtro's to arrive
marvi is offline
Old 08-07-2006, 10:32 PM
  #1078
akuhon's Avatar
From where, did you order Tectro motor ?
I see somewhere in this thread from the picture that the armature is not 23T but it's 22T ? Any comment ?
Beside, what's the best 23T stock motor up to now ?
Atlas, Flaps, Yokomo F-series, Tamiya or else ?
Comment please...
Thx
akuhon is offline
Old 08-08-2006, 02:52 AM
  #1079
Geetoo's Avatar
Comment please...
Thx
Tectro is rare find and so far the best quality produced. It is 23turns for sure no doubt about that. All 23turn motors are good depends on how you prep and tune it. I also forgot to include Kyosho G-Style and Team Luna on the list.
Geetoo is offline
Old 08-08-2006, 08:49 PM
  #1080
akuhon's Avatar
Why this Tectro so rare ? Do they make only on pre-order basis ?
I hope my friend can find it in Japan or.. buy direct from them...
There are (If I'm not mistaken) 4 types of Tectro 23T stock ... the SP2..
akuhon is offline
