23T motor thread >
23T motor thread
23T motor thread
Old 07-24-2003, 12:22 PM
  #91
Pandora's Box's Avatar
Default Maintenance - 23t
How many cycles(5 min = 1cycle) on average before we should cut the comm and replace the brushes to maintain ''peak'' performance on these 23t stockers?
Pandora's Box is offline
Old 07-24-2003, 12:41 PM
  #92
dandyspashett's Avatar
i cut my 8t every 2 runs , 16t every 3 runs, 23 t every 5 runs,
probably I am fussy.
dandyspashett is offline
Old 07-24-2003, 03:29 PM
  #93
Originally posted by JDM_DOHC_SiR
the Yokomo SR has just a tad bit more rpm( 2000 rpm more ) but the ECHO PQ puts the power down in the infield and my lap times are much faster with the ECHO motor...and I can gear this motor in the 5.5 range and it Rips...but 8 mins is kind of a pinch with the batterys that I have heheheh
-Dave
anyways the Yokomo, Xenon and ECHO new motors just are AWESOME!!!! they really over power the new ATLAS motors....
hey JDM, so is it safe to say that *overall* the best 23T motor at the moment is the ECHO PQ 23T?
and im wondering how's the durability on it?
i noticed that the power output of my Yokomo Tmaxx RSL 23T drops pretty drastically after 2-3 minutes.. durability is quite crap if you asked me.
versa is offline
Old 07-24-2003, 03:56 PM
  #94
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
well I have about 20 packs on the PQ and about 20 on the new yokomo`s.... I really like the PQ Echo and the SR and ST from Yokomo..... but the SR is really picky with gearing....
and Durability with the ECHO is awesome!! I have only cut the com 1 time so I think that it`s due for one more...but I have cut the COm on the SR 4 times allready but that motor just spits out RPM
now for the older T-Man motors...the RSR & RSL were really sensitive to heat... I found out if your motor is loosing power after 3~4 min then Heat is killing it...try gearing down a tooth or two.... they run best in the 80 deg Cel and under
-Dave
JDM_DOHC_SiR is offline
Old 07-24-2003, 11:18 PM
  #95
well, i'm running mr4tc's STOCK gear ratio 7.80 ..
weather here is about 30C-33C during the day? im in Malaysia so its rather hot here..
i think i might be getting the ECHO PQ.. i prefer something thats durable.
hey JDM thanks for the input
versa is offline
Old 07-25-2003, 04:17 AM
  #96
your gearing a RSL at 7.80?? that motor needs more gearing.... around 5.8~6.1 then that motor will fly...it`s more than likely undergeard and getting hot quick
-Dave
Old 07-25-2003, 07:26 AM
  #97
alucard's Avatar
Default Re: Re: kawada 23t
the Black Rotor Kawada 23T`s a re not to bad...you can gear them 1~2 teeth larger on the pinion 48P and still have the same run time and punch....also a bit motr RPM from them..... but it`s still the same arm under the black coating unlike the new Yokomo and ECHO rotors which are new ...but if you do get the new style 23T from Kawada...get the Laydown version....best overall power and RPM
-Dave
Only M1-237 23t is available so i not sure is it laydown or standup brush. too bad i M1-231B,M1-236B and M1 236BL are not available.
alucard is offline
Old 07-25-2003, 04:39 PM
  #98
Default Motors
Hey Alucard
guess which motors will be in stock the end of next week? All three numbers that you mention, so watch the web-site.
www.kawadaracing.com
hardadz is offline
Old 07-27-2003, 08:56 PM
  #99
analyzer's Avatar
Team Luna
any comments for Team Luna new stock motor?
analyzer is offline
Old 07-28-2003, 01:56 AM
  #100
Default Re: Team Luna
Which one there is 4 new ones... that are based of the new yokomo ones..but are balanced much better...
I have the Stand up speed one and Laydown Speed one..but I have yet to try them... I`m having to much fun with the new ECHO PQ and Yokomo SR and ST
-Dave
Old 07-28-2003, 02:47 AM
  #101
analyzer's Avatar
dave, let us know when you have tried out the Luna stocks...
analyzer is offline
Old 07-29-2003, 05:50 AM
  #102
I Gave the new Stand up SPeed version ...a testspin today (5 packs)... so it really has quite a bit of RPM...more than the SR from Yokomo..by 1000 RPM..!!!!!! but I have to gear it differently than the Sr...the final was around 6.1~6.3 for the best overall power and top end..!!
-Dave
Old 07-29-2003, 06:50 PM
  #103
analyzer's Avatar
Wink
the new Luna sounds good....
analyzer is offline
Old 07-29-2003, 07:08 PM
  #104
I`ll take some pic`s od the Yokomo and the Luna together so you can see the differance ...a bit later today.
-Dave
Old 07-31-2003, 05:01 AM
  #105
LeoChan's Avatar
Default Bursh ?
JDM :
Which Bursh in 23T stock motor bester ?
in Tokyo where to buy ?
LeoChan is offline
